p0193 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-20-2011, 04:40 PM   #1
andysouza3235
andysouza3235's Avatar
Fan#: 78989
What I Drive: 2005 Black ZX4 ST
Points 648, Level 12
Points: 648, Level: 12 Points: 648, Level: 12 Points: 648, Level: 12
Level Up 96% Completed
FF Reputation: 1 andysouza3235 Good Standing Member
p0193
Hello fellow focus owners. This a bit of a lengthy story so please bear with me. I've had my 05 zx4ST for about 6 months with no problems. Then about a month ago my check engine light came on. I immediately ran to Autozone and had them pull the code. The guy explained the p0193 code and gave me the little sheet they print out for troubleshooting. Since the cheapest possible fix was to replace the fuel filter, that's what I did. After that I went back to Autozone to have them reset the code. Of course it threw like 7 more codes from running it dead to change the filter, so I had the guy clear everything. Then it came back about 3 days later. Next step was to check the fuel rail sensor, which was nice and clean inside and out. Maybe a week later the light went off and has been off till today. So i went back to Autozone to have it read and it came up with the same thing. The car always runs great and didn't really change when i changed the fuel filter. The only problem I have is the long crank problem that a lot of people seem to have. Other than that it's great. Thanks for listening, any help is greatly appreciated!
andysouza3235 is offline
Old 01-20-2011, 05:12 PM   #2
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
Location: People's republic massivetwoshits, United States
What I Drive: 2004 svt focus EAP
FF Reputation: 22 alex62390 Great Standing Member
p0193- Fuel Rail Pressure Circuit High Input
the voltage going to the PCM from the sensor is to high.
i don't know why they told you to do a fuel filter.
according to Michell on demand, the possible causes are a bad Fuel Rail Pressure sensor (electrical malfunction not a cleanliness issue), or FRP open/ shorted circuit.
2004 svt focus EAP #658
Former Hatch Nation #08
alex62390 is offline
Old 01-20-2011, 05:31 PM   #3
andysouza3235
Fan#: 78989
So in other words, there is nothing wrong with my fuel pressure? Its just an electrical thing either wiring or sensor malfunction. Is there any relatively easy way to test for this without sending it to a mechanic?
Old 01-21-2011, 07:40 AM   #4
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
If you have a DMM you could test the circuit. but that requires some electrical knowledge. I am going to have to find some more information on circuit specifics for you.
Old 01-21-2011, 10:22 AM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Well you can never go wrong by changing a fuel filter. Those have a 25k mile service interval, and are commonly over looked. Typical fuel pump life is 100-150k miles, and I wonder if it would last longer if the filter was changed regularly since mine is full of black crud every 20k miles. 130k and counting.
That being said, the problem is most likely the fuel sensor. To change it you'll have to go through the fuel pressure relief procedure like when you changed the fuel pump, then remove the Fuel sensor, and replace. IIRC, it's about a $160 part from a Ford dealer, RockAuto has it for $112. We also have dealers that we work with for discount prices. One in WI and another in NC. Their discounts are often surprising. I'm not sure if the NC dealer is still doing it or not. The one in WI is Tousley Ford, and you call up the parts dept, ask for Steve, tell him you were referred to him from Focus Fanatics. Then he'll tell you the price.
Personally, I think it's the part itself, but I'm surprised that you're not experiencing other fuel related codes- lean or rich codes. Have you noticed any change in fuel economy? What kind of fuel economy do you get?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-21-2011, 06:29 PM   #6
andysouza3235
Fan#: 78989
I get around 27 mpg. That's mostly back roads. It went down a little once it got cold, especially with driving really slow on slick roads (i have street tires, not all seasons). So lately I've been getting around 24 or 25 depending on how often i have to drive really slow. I'm pretty good with electronics so testing it wouldn't be a problem. I just need to know what to look for since its variable. The code says its out of range but what IS the range? Also, I wouldn't think that if it were a problem with the pump it would have fixed itself for a week and then come back. I just wanna make absolutely sure before I start throwing money at it.
Old 01-24-2011, 07:47 AM   #7
andysouza3235
Fan#: 78989
Also..... just minutes after I posted on Friday I left the house and to my surprise the light was off. It's got to be the sensor, just wanna find a way to test it first.
Old 01-24-2011, 09:52 AM   #8
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
That fuel economy might be slightly low. As I recall ST's get similar mileage to the smaller engines when driven sanely.
Be eclectic.
Old 01-24-2011, 06:05 PM   #9
andysouza3235
Fan#: 78989
27 is what I've always gotten but then it went down a bit when it got cold. I thought it was normal since the highway estimation is 31 so mostly back roads at 27 was pretty good. I would say I drive sanely but not putt put. I came from a Saturn Sl1 with 230,000 miles so I tend to enjoy the pep of the ST. However, there is no difference in the car's behavior whether the light is on or off. Just another thing that leads to sensor problems I guess. If the pump was miraculously getting better and worse I would think there would be a change in how it ran. The light has been off since Friday evening so we'll have to see how long it lasts this time.
Old 01-31-2011, 03:31 PM   #10
andysouza3235
Fan#: 78989
Well now it's going on and off every few days. I think I'm just gonna wing it on the sensor. I've looked at all the wiring and it all seems in perfect shape so it's got to be the sensor itself. Thanks to everyone that helped, it's greatly appreciated!
