frustration over power steering fluid - Page 3 - Focus Fanatics
Old 01-03-2013, 06:31 PM   #21
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
FF Reputation: 21 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (14)
Just buy mobil1 ATF. Sold everywhere.
I now drive a Japanese Ford.
macdiesel is offline
Old 01-03-2013, 06:38 PM   #22
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 270 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Originally Posted by Magus2727 View Post
Thought that the numbering is just the "version". Most systems if it calls for a previous Mercon the V (5) will work. Its backwards comparable. I think the Mercon V is the only type you can get now days anyway.
Is their any thoughts on running something like Royal Purple MAX ATF or similar full synthetic "performance" ATF fluid in the rack?
Nope, Mercon ATF is the transmission fluid labelled "ATF" or type F. It is exactly the same fluid as generic power steering fluid except that it has red dye in it, and used to be less expensive than generic PS fluid. I've been telling people who ask on this forum for years that you're better off using ATF than Mercon3 or 5. It might be backwards compatible in transmissions (IDK really), but it is not for PS pumps. What happens is that you develop that Ford PS groan. How'd I figure that out? A couple of lifetime warranty PS pumps, and a couple of gallons of Mercon3 until someone finally told me that was the wrong fluid to use. They were right.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-03-2013, 07:47 PM   #23
Magus2727
Magus2727's Avatar
Fan#: 62897
so basically Mercon ATF, or any ATF labeled transmission fluid. So Mobile 1 ATF, or any similar full synthetic would work.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 01-03-2013, 09:33 PM   #24
amc49
Fan#: 96610
FF Reputation: 23 amc49 Great Standing Member
ANY ATF will work. Mass confusion on this post. I've switched fluids on so many cars it's not funny. Power steering fluid is ATF without the red dye, ALL ATF fluids have the dye to tell you what the leak is from when you find the puddle under the car. Been that way since the fifties. ALL cars and brands used to use type A which was Chrysler ATF through the sixties until dealers realized they can use whatever ATF is kept in stock to service their own ATXs. Ford used F when their predominant fluid used in trans was F, they went to Mercon when most of the trans went to that, easier to have the power steering fluid already be on the shelf and one less part to have to keep track of. Now Ford uses V, why? They already carry it........the difference between regular Mercon and V is that V is synthetic, so more resistant to heat. More profit too, anybody notice the $1/qt. price increase? I wouldn't hesitate to put V in place of regular Mercon, in fact I have three cars now INTERMIXED, running like that. Power steering systems are not high tech, the same basic systems used design wise since the fifties again, only refined. The seals would have no difference from seal used in ATX, and certainly the fluid will not affect them. The seals cook from heat, no oil type known on the planet stops that. You can get better oil as far as heat but you're stuck with your seals. Getting lifetime power steering pumps and then having them go out is most likely bad pump reassembly, many of those parts become matched in operation, switching them around to make 'new' (RIIIIGHT!) pumps is just asking for at least groaning noises and the fluid has nothing to do with that. We were taught at the store to blame new pump noise on that though, a typical example of how you get garbage parts and then the lies for why begin. Anything you can point a finger at to blame the user and all that.......one should try rebuilding some of those pumps and then you would see just how critical correct reassembly is to proper function. On many the ends of pump cavity can easily be reassembled backwards or not indexed like before, if the part brand new doesn't matter, but they often reuse any slightly worn endplates and then the noise begins. They have to be PERFECT or you get noise even with only couple thousandths wear, even though pump will run up to full pressure and may well work for years like that. I've rebuilt some pumps and racks to find that out.............one whines but has been doing it for 25+ years and still works fine.
Regular Mercon is not type F but they both work fine in power steering. V won't hurt as an upgrade. Mercon is usually labeled in stores as Dex/Merc...........
Mobil ATF would work fine.
The only car you have to be careful with power steering fluid for is Honda, not all of them, but some have plastic impellers that damage easily if wrong fluid is used. That's why you don't see specific GM, Ford, or Mopar power steering fluid on the shelves but you find it for HONDA.
If you want to lower troubles with power steering on cars, CHANGE THE FLUID occasionally. Look at the fluid color as it ages, it turns dark grey, that is finely ground up METAL suspended in it, get that out and the systems last forever unless you simply pop a hose, nothing can prevent that. The metal particles are what eat your seals to leak. I partially change my fluid on a regular basis by the turkey baster method someone mentioned earlier, somewhere at around 75K miles I pull return and run all of it out to completely replace it. I've never lost a rack or pump in 40 years..........
Since power steering fluid IS ATF, I suspect that since the requirements are not as rigorous that fluid vendors may start cheaping out by cutting some of the valuable additives ATF has. I only use labeled ATF in anything I have, I think the actual 'power steering' fluid could be gutted of additives to be not as good a product. After all, the CEO of the oil company does not care about you, all he cares about is the next quarter's performance.................besides that, PS fluid is more expensive, how stupid is that????
amc49 is offline
Old 02-28-2013, 07:49 AM   #25
Cuabn04
Fan#: 106867
What I Drive: 2006 Red ZX4 ST
FF Reputation: 1 Cuabn04 Good Standing Member
I can't tell you how long I've been looking for someone to address the horrible Ford PS groan...so what would you recommend I use for my power steering fluid? I hate to seem stupid but after so long my degree of bluntness is necessary. I'd really appreciate the insight!
Cuabn04 is offline
Old 02-28-2013, 07:55 AM   #26
Magus2727
Magus2727's Avatar
Fan#: 62897
Welcome to Focus Fanatics!
Your question would be answered in the previous posts of this thread. Do a flush / replacement of your fluid replace with ATF and see how that helps.
One thing not mentioned in this thread is the use of Lucas Oil additive. I have found this cuts down the noise but also due to its thicker state cold driving requires more muscle.
Hatch Nation #42
Old 02-28-2013, 06:42 PM   #27
amc49
Fan#: 96610
Change to any fluid you want, they are all the same basic oil weight and the noise will not go away, only by possibly changing the basic weight by using like Lucas will the noise possibly change. But the steering effort will be affected too..........
The noise if constant is from wear, or a badly remachined rebuild, or air in lines. If noise is only at rack limit it is normal, and an expectation of no noise there is abnormal. Pumps that are tight and have running surfaces that fit right on are quiet. Solid oil with no air in it helps too.
amc49 is offline
Old 03-01-2013, 08:01 PM   #28
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
FF Reputation: 9 Lscman Good Standing Member
Originally Posted by stormy View Post
I can't find the blasted stuff, I found motorcraft mercon V on amazon.com but according the manual, that's only for the actual transmission, it says nothing about mercon V for the power steering. But I seem to remember an article saying that mercon V is replacing the regular mercon ATF but is that just for the trans or power steering too? lol this is so annoying, just so one company can make more money over the other...grr
Every auto parts store in pittsburgh carries genuine Mercon V. Autozone and advance auto both carry multiple brands of it. I know there are at least 20 of these stores in the pittsburgh area. NAPA also has it.
Lscman is offline
