o2 sensor questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-18-2011, 12:02 PM   #1
eliaslincoln
Black Mesa Racing
eliaslincoln's Avatar
Fan#: 6025
What I Drive: 2010 C30 R-design & 2002 ZX3
Points 8,822, Level 63
Points: 8,822, Level: 63 Points: 8,822, Level: 63 Points: 8,822, Level: 63
Level Up 24% Completed
FF Reputation: 11 eliaslincoln Great Standing Member
Buy-Sell-Trade Rating: (8)
o2 sensor questions
I dont know a lot about the o2 sensor so can some of you fill me in?
1) How often do they need replaced? (im not running a cat)
2) I have a cheater on the one o2, but would it still need replacing? (how exactly does the cheater work?)
3) Can an old/going bad o2's effect mpg? (this is why im asking questions)
my car has the stock o2's with 93,000 miles.
thanks!
2009 FocusFest 2nd Place Slalom Finish
2009 NRSCCA ST Class Champion and Rookie of the Year!
2011 & 2012 Lincoln ProSolo Bonus Challenge Winner
eliaslincoln is offline
Old 01-18-2011, 09:45 PM   #2
eliaslincoln
Black Mesa Racing
Fan#: 6025
no one?
Old 01-18-2011, 10:17 PM   #3
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
My stock o2 needed to be replaced around 130k. The one after the stock cat.
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-19-2011, 01:50 AM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
You usually replace them only when they fail; they're not generally a regular maintenance item. When they fail, they usually throw some sort of DTC code. It seems, judging by comments on FF, life expectancy varies greatly - 60K miles on up.
To understand how a cheater works, you need to understand how an O2 sensor works. The upstream (of the catalyst) sensor measures the proportion of O2 is in the exhaust immediately upon exiting the combustion chamber and, put simply, converts it into a voltage signal. The upstream sensor feedbacks to the ECU and the air/fuel mixture, timing, etc is adjusted accordingly to get the best compromise between power, economy and emissions. Theoretically, after the exhaust gases have been through the cat, the 02 readings between the upstream and downstream sensors should be different. That difference (voltage diff) is read by the ECU. (The second O2 sensor is there primarily to measure the "cleaning" efficiency of the cat.)
If you have no catalyst, the readings between the upstream O2 sensor and downstream O2 sensor should be the same. So "cheaters" fool the ECU by creating a "fake" voltage difference where none exists, usually by introducing a resistance into the sensor circuit somewhere. Other cheaters work by simply moving the O2 sensor out of the exhaust stream with some sort of extension (plug anti-foulers).
An O2 sensor with a cheater attached theoretically should not need replacing; it's actual readings are being altered anyway. Some cheaters simply integrate into the O2 sensor wiring harness and bypass the downstream O2 sensor altogether, I've read.
3) Can an old/going back o2's effect mpg? (this is why im asking questions)
Not sure what you mean by "going back."
An old or worn upstream O2 sensor can effect fuel economy by making the ECU think the a/f ratio is a value it isn't and can consequently cause the engine to run too lean or too rich as it tries to compensate. A failing downstream sensor shouldn't affect how the car runs but should generate a "failed catalyst" type CEL for emissions purposes.
BC_ZX3 is offline
Old 01-19-2011, 02:04 AM   #5
eliaslincoln
Black Mesa Racing
Fan#: 6025
^^opps i meant going bad o2
thank you for your response. +1 rep
Old 01-19-2011, 10:09 AM   #6
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
I am a firm believer in replacing the front sensor about every 25k miles.... and I will NOT use anything but a Ford sensor.
Why you ask??? Because the Ford sensors are calibrated differently than the Bosch generic sensors and they do effect performance (found that out with the Turbo car)
Not only will it effect performance it also effects mileage.
With the cheater there is no reason to replace the rear sensor... its only there to tell the ECU how efficient the cat is anyways.
I know alot of people wont change out the front sensor until it fails, but we have datalogged fairly new sensors that were already getting slow and not responding as they should without throwing a code.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 01-19-2011, 10:49 AM   #7
deezx5
deezx5's Avatar
Fan#: 72153
What I Drive: 2011 Gray Hyundai Elantra GLS
FF Reputation: 3 deezx5 Good Standing Member
Bosch recommends changing the sensors every 100k but as far as I know Ford has no replacement interval on the Focus. I had my cat off last fall and both sensors looked like new (02 zx5) so I don't plan to replace unless I have a cel or drop in mpg.
deezx5 is offline
Old 01-19-2011, 10:59 AM   #8
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,057, Level 79
Points: 15,057, Level: 79 Points: 15,057, Level: 79 Points: 15,057, Level: 79
Level Up 42% Completed
Forum Activity 3%
FF Reputation: 17 BLRich1 Great Standing Member
Andrew I need to do my front sensor too. GARAGE DAY!
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 01-19-2011, 11:19 AM   #9
eliaslincoln
Black Mesa Racing
Fan#: 6025
^ben it will take like 2 mins to change it, i have other things we can do on garage day!!! sub/suspension.
i think i'll go get a ford one today.
Old 01-19-2011, 11:57 AM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,859, Level 100
Points: 51,859, Level: 100 Points: 51,859, Level: 100 Points: 51,859, Level: 100
Level Up 0% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
This is again where a xcal3 flasher datalogger would come in handy it can check the o2 sensor and tell you if your running rich/lean at idle and cruise and tell you if the o2 sensor is slow responding and needing changing
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
