Focus RS Build.....For the Occasional Track Day! - Page 67 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-29-2013, 02:22 PM   #661
thielt1
thielt1's Avatar
Fan#: 32005
What I Drive: Focus RS Rep
Points 10,590, Level 68
Points: 10,590, Level: 68 Points: 10,590, Level: 68 Points: 10,590, Level: 68
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 2 thielt1 Good Standing Member
Buy-Sell-Trade Rating: (8)
I figured while I have everything out, why not fit a new pump as I don't know the mileage of my other two pumps.
Comparison of how close the Deatchwerks (dw65) pump is to oem: (even the rubber covers fit)
Modified Fuel basket:
Back in place, hopefully I can get the lines to fit in there so I don't have to raise the cover to much. I will Probably use some type of rubber seal so fumes don't enter the car:
Focus RS Conversion In Process.
http://www.focusfanatics.com/forum/showthread.php?p=3517025#post3517025
thielt1 is offline
Old 10-29-2013, 02:23 PM   #662
thielt1
thielt1's Avatar
Fan#: 32005
Brake lines are now all fitted for the most part.
For the rears I used an existing bolt location so part of the line had to be pre-bent before it was put into the car while the second part was bent and flared after:
Here is where it comes through:
Together:
I ran the main electrical through the car now as well. It will come up to one of the center air vents where I am going to have my master cutoff switch. It then goes through the firewall where it will end up near the standard batter location where I am going to have a central hub.
thielt1 is offline
Old 10-29-2013, 02:29 PM   #663
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,469, Level 57
Points: 7,469, Level: 57 Points: 7,469, Level: 57 Points: 7,469, Level: 57
Level Up 60% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
FF Reputation: 10 Blue5ive Great Standing Member
Coming along nicely.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is offline
Old 10-29-2013, 03:17 PM   #664
Eastwood
Eastwood's Avatar
Fan#: 62095
What I Drive: 2001 zetec premium zx3
Points 4,797, Level 44
Points: 4,797, Level: 44 Points: 4,797, Level: 44 Points: 4,797, Level: 44
Level Up 24% Completed
Forum Activity 3%
FF Reputation: 1 Eastwood Good Standing Member
Buy-Sell-Trade Rating: (20)
I am wondering, what is the reason to relocate brake lines ?
Eastwood is offline
Old 10-29-2013, 04:01 PM   #665
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,173, Level 41
Points: 4,173, Level: 41 Points: 4,173, Level: 41 Points: 4,173, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
I'm guessing for a track car, not having fuel and brake lines under the car might be beneficial.
I now drive a Japanese Ford.
macdiesel is offline
Old 10-29-2013, 04:21 PM   #666
thielt1
thielt1's Avatar
Fan#: 32005
Brake Bias (you can see it next to the tunnel in the pics), also ford no longer makes brake lines and they are safer running through the inside of the car.
thielt1 is offline
Old 10-29-2013, 04:23 PM   #667
thielt1
thielt1's Avatar
Fan#: 32005
Correct, I was going to run the fuel lines through the car but people seem to be very mixed on this idea whether it is safe or not so a majority of the fuel lines will be run under the car.
thielt1 is offline
Old 01-06-2014, 01:45 PM   #668
thielt1
thielt1's Avatar
Fan#: 32005
Wrapped my Header, what a PITA!
Also needed to modify the PS Bracket in order to fit the Top Speed Header.
I will probably fill it in with some aluminum on the backside to make sure the strength remains there.
thielt1 is offline
Old 01-06-2014, 02:34 PM   #669
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
I'm sure track rules would be firewalls and no fuel lines inside of cockpit also might want to put rubber grommets where the battery cable and brake lines pass though the channels so no hole are rubbed into them from all the G's. Nice work...
Seminoles is offline
Old 01-06-2014, 02:57 PM   #670
thielt1
thielt1's Avatar
Fan#: 32005
Rubber grommets are used on all lines passing through, and the whole fuel area will be firewalled.
thielt1 is offline
