heater blower wont work - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-03-2011, 04:10 PM   #1
linksubsea
Fan#: 81562
What I Drive: 2001 silver focus tdi
FF Reputation: 1 linksubsea Good Standing Member
hy, everyone im new on here, nice to join you all, my ford focus tdi that i have just bought keeps blowing fuses everytime i turn the heater blower on, can anyone help me please?
linksubsea is offline
Old 01-03-2011, 05:19 PM   #2
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
Welcome.
I'm assuming the fan blower fuse is the only one that blows, although you mentioned 'fuses'. Excess current is the reason fuses blow, caused by a short or in your case, probably by a siezed motor. Are you able to remove the motor and check to see if it is free to spin? Excess current could also be caused by damaged wiring or extreme wear on the motor brushes or a faulty motor, or a faulty resistor unit for the speed control (if you have one fitted). Investigation is required.
If you think I've been able to help, just say
niggly51 is offline
Old 01-03-2011, 05:21 PM   #3
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,300, Level 67
Points: 10,300, Level: 67 Points: 10,300, Level: 67 Points: 10,300, Level: 67
Level Up 63% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (42)
Sounds like motor no good
pasta is offline
Old 01-03-2011, 05:57 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Even if the motor turns, it might not pass an electrical test- test for continuity or ohms between the pins. If you get .01 ohms, or your tester reads continuity- that will tell you that the fan is bad whether it turns or not. Now if you find resistance, like 1-10 ohms, on the motor- you should check for resistance and continuity on the wiring side. Wiring might have been damaged somewhere.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-03-2011, 06:02 PM   #5
niggly51
niggly51's Avatar
Fan#: 74542
Continuity in the motor will not blow fuses. Excess current will.
A siezed motor is one possibility I mentioned, that will cause excess current draw. Worn brushes/damaged commutator will cause excess current. Damaged/faulty blower resistor assemblies are known to cause problems too. Out with the multimeter!
niggly51 is offline
Old 01-03-2011, 11:45 PM   #6
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
^^^ Yes, to the bad resistor packs for the blower motors...Seen many of them burnt out..Also, just make sure something isn't jammed in it... I had an old mustang inhale part of a sock ( long story)
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 01-04-2011, 06:30 AM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
Continuity with no resistance such as .01 ohms= dead short, and yes that will blow a fuse. It's low resistance that causes high current.
Be eclectic.
Old 01-04-2011, 12:24 PM   #8
linksubsea
Fan#: 81562
thanks for your help, will try and let you no how i get on.
