Proper way to disconnect Battery? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-31-2010, 12:25 PM   #1
daigle
Fan#: 81494
What I Drive: 2007, White
FF Reputation: 1 daigle Good Standing Member
My fan belt blew because the tensioner plastic peices shredded. I replaced the part and the fan belt and the car runs again, but the check engine light is still on.
I was told that if I disconnect the battery for 15-30 minutes, the computer should reset if there is nothing else wrong with the engine. However, i was informed that there is a correct procedure to do this, such as removing only the negative coupling and not the ground/positive.
Is this correct?
I have a 2007 Focus, and apart from this one incident has been the absolute best vehicle I have ever owned.
daigle is offline
Old 12-31-2010, 12:29 PM   #2
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
YES, always remove the ground (black) cable first . You dont have to take off the (red) positive cable. And it should only take 5 -10 minutes to reset the PCM.
iroc34 is offline
Old 12-31-2010, 12:34 PM   #3
DanUSVT
Fan#: 80691
What I Drive: 2013, White ST1
Points 501, Level 10
Points: 501, Level: 10 Points: 501, Level: 10 Points: 501, Level: 10
Level Up 2% Completed
FF Reputation: 1 DanUSVT Good Standing Member
If you put drain on the electrical system it can reset much faster. Disconnect battery, turn on the headlights, put your foot on the brake, and cycle the key a few times. ECU will reset fast that way.
100% agree on remove neg cable first on battery disconnect, BTW. You can't arc neg to chassis, and once neg is off, you can't arc the pos side either.
DanUSVT is offline
Old 12-31-2010, 02:26 PM   #4
PiSTOLpete717
PiSTOLpete717's Avatar
Fan#: 81212
What I Drive: 2002 Infra Red SVT FOCUS #2294
FF Reputation: 1 PiSTOLpete717 Good Standing Member
Remove ground first, and connect ground last
I Got this On Lock
PiSTOLpete717 is offline
Old 12-31-2010, 02:49 PM   #5
daigle
Fan#: 81494
are you saying to remove both capables in the proper order, OR only remove ONE cable???????
daigle is offline
Old 12-31-2010, 02:52 PM   #6
DanUSVT
Fan#: 80691
Disconnecting the neg cable is sufficient for performing maintenance or restting the ECU
DanUSVT is offline
Old 12-31-2010, 06:44 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,363, Level 75
Points: 13,363, Level: 75 Points: 13,363, Level: 75 Points: 13,363, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
Posted via FF MobileThe proper order is for safety only, and as mentioned once one cable is off nothing will get power. The idea is that if your wrench contacts anything while removing the negative first, it won`t spark since it contacts the chassis anyways. If you do the positive first, anything you touch by accident will cause a BiG spark, and batteries can even blow up this way from hydrogen gas given off while charging....
sailor is online now
Old 01-02-2011, 03:10 PM   #8
daigle
Fan#: 81494
It worked! Thanks to all. Happy New Year!
daigle is offline
