*Massive Zetec ULTIMATE CNC Ported Head V1.2 Released* - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Massive Speed
Massive Speed Discuss about forced induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Massive Speed
Old 12-16-2010, 07:37 PM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 15,918, Level 81
Points: 15,918, Level: 81 Points: 15,918, Level: 81 Points: 15,918, Level: 81
Level Up 14% Completed
Buy-Sell-Trade Rating: (19)
Simply the best head money can buy. Massive has made continual improvements to the world's greatest Zetec since it's original release in 2006, but in recent month's has received a major overhaul enough that it warranted an updated name and re-release. Presenting the Massive ULTIMATE V1.2 Cylinder head:
Massive has created the worlds TOP FLOWING ZETEC CYLINDER HEAD.
5 Axis CNC machined for the best in consistency and flow!
In our quest for power superiority, an OE head was flow tested on a Superflow SF-600 flow bench at 28” of water to determine base line flow numbers. After the initial flow test the heads were ported by hand to develop a working port shape and volume. The head was then reflowed after hand porting to verify the increase in flow. The heads are then reverse engineered using 5-axis digitizing to acquire the port shape of the finished port. This makes for the greatest possible flow capacity and consistency.
Heads begin as production cores which are fully disassembled and washed. The heads are then glass bead blasted clean to remove any rust or scale. They are then CNC machined using 5-axis simultaneous machining. All ports and chambers are machined then hand finished to blend out any unwanted tool marks. All valve guides are honed to size and a multi-angle valve job is cut into the head. The valve job is cut using Newen single carbide insert style cutters of varying profiles. The valve job is hand lapped in then blended to the finished port and chamber. The heads are then surfaced and reflowed again to confirm that the finished product performs as expected. Outflows ANY production Zetec head without sacrificing velocity. Substantial chamber modification for superior flow dynamics and greater resistance towards detonation. NEW on 2011’s version 1.2:
  • Crower high rate valve springs allow for elevated RPM usage without float. High boost applications WON’T force force them open.
  • Crower lightweight Titanium retainers. This reduced valve train weight allows faster revs and avoids valve float while maintaining strength.
  • SuperTech OVERSIZE +1mm undercut stainless steel black nitride hardened valves. Undercutting, in addition to reducing the valve weight (which provides benefits in opening rate and RPM limits) the radius of the head is such that is significantly improves air/fuel flow. Fully swirl polished. Nitriding reduces guide friction and increases surface hardness.
  • Fel-Pro PREMIUM valve stem seals standard
  • Includes Massive Cam Cap Bolt Kit standard. Does away with odd reverse torx head bolts Ford provides, far superior strength fasteners employing separate washer.
  • CNC Big Cam Clearancing program allows for usage of ALL commercially available cam profile with no further modification. Even Crower stage 2’s have been known to hit stock castings. Previously this would need to be done by hand, and of course that welcomes inconsistency and potential for lifter damage. Often this condition would not be discovered until head was installed on vehicle making a clean procedure all but impossible.
Find it Here!
REMEMBER TO USE CODE MSSISBEST TO RECEIVE 10% OFF ON ALL MASSIVE PRODUCTS UNTIL THE END OF THE YEAR!
Core return required or $200 core fee must be collected.
K Dog is offline
Old 12-16-2010, 08:18 PM   #2
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Looking very good Karl!! Wish you had come with this 4 months ago, guess for my next rebuild, maybe you can fab billet main caps in the meantime;)
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is online now
Old 12-17-2010, 09:29 AM   #3
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
This head has been out since '06 duuuuuude?!?!??!?! :D
K Dog is offline
Old 12-17-2010, 10:07 AM   #4
Mother Focus
Fan#: 73292
Ha! First news for me, thought the FR was the only head out there.
PTE 6262CEA
Old 02-22-2011, 06:55 PM   #5
WhiteLionBlackFocus
Fan#: 63798
What I Drive: Black Focus
FF Reputation: 1 WhiteLionBlackFocus Good Standing Member
If I sent you 3 heads, could i get 600 credit??
WhiteLionBlackFocus is offline
Old 02-23-2011, 09:09 AM   #6
Blackcatn2o
soon to be turbo!
Blackcatn2o's Avatar
Fan#: 48278
What I Drive: 06 silver ZX4 ST
Points 8,020, Level 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 48 Blackcatn2o Great Standing Member
Buy-Sell-Trade Rating: (13)
If and when i find a job can you do this to my Duratec head? i'll buy the valves from over seas and such, i just need someone to do the work.
Blackcatn2o is offline
Old 02-23-2011, 09:41 AM   #7
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
uh. no.
K Dog is offline
Old 02-23-2011, 09:42 AM   #8
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Yes, we already have a Duratec head.
It includes SuperTech vavles and Crower springs/retainers.
K Dog is offline
