#1 | ||||
Hi i am new to focus fanatics and need help
I own a mk1 ford focus 1.8 zetec petrol T reg 1999 when the car as been standing overnight or trough the day when i am at work i go for start the car and wont start first time unless i press the accelerator pedal and once started it will start first time after that. I have changed spark plugs , ht leads , coil pack , fuel filter, and air filter and cleaned out the throttle body and also had car plugged in diagnostics but no faults found or stored in memory . Any ideas cheers |
Remove Advertisements |
Fan#: 1
#2 | ||||
OK if I am understanding you correctly. The engine is cranking over but wont start. Then after you hit the gas pedal it will start right up, and every time after that. Try this. The first time you go to start , turn the key to on, not crank position, and listen for the fuel pump, ( a humming or whining sound) should last a couple of seconds. It pumps up fuel pressure. Sound like you are losing your prime. silly question but is the fuel filter pointing in the correct direction. It will have an arrow on it...
#3 | ||||
Have you cleaned the idle air control valve as well? This valve is a bypass around the throttle body, and can accumulate gunk and stick in the wrong position, causing idle and/or starting problems. The fact that depressing the gas pedal helps overcome the starting problem indicates this valve may be causing issues. Does the car idle OK, or does it have idle issues?
#4 | ||||
#5 | ||||
#6 | ||||
I have the same problem sometimes, at times it will start right up but after a cold night tapping the accelerator is needed to give the car a push into start heaven !!! should be a minor issue... G L
#7 | ||||
The IAC ( idle air circuit or control) valve is under the intake manifold. You can remove it and clean it with carb and choke cleaner. Easiest way is from under neath the car. Jack the front end up and put on Jack stands. If I remember there are two 10 mm bolts holding it to the intake. And you can reuse the gasket again if you are careful. But it would be good insurance to get a spare. Before you disable the car. It wont run with the iac out..
#8 | ||||
#9 | ||||
anyone had trouble with there ignition of a ford focus, 1.8 LX. when i try to start my car, it cuts out and i put my foot on the gas pedal when starting ignition its tick along but i took my foot away from gas pedal car cuts out. i try give a bit of gas still wont start and few hours later i try again, start ignition with my foot pedal on the gas its fine and give couple of day car playing up again.I have replace, sparks plugs including leads, oil filter, air and drain oil and replace it
please help |
#10 | ||||
| Thread Tools | |
| Display Modes | |
