Focus Engine removal - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 12-07-2010, 09:27 PM   #1
Trouble in El Cajon
Fan#: 81013
What I Drive: 2003 white focus SE
FF Reputation: 1 Trouble in El Cajon Good Standing Member
I am the unfortunate owner of a blown up 2003 2.0L SOHC engine in my Focus. It appears tha the piston failed and the connecting rod destroyed the piston and gouged the cylinder wall of #4 cylinder. I have the engine stripped down almost to the short block stage and I'm planning on replacing it with a remanufactured block and head. Is it possible to remove the engine without dropping it with the transaxle? Will it come out the top??
Trouble in El Cajon is offline
Old 12-07-2010, 09:32 PM   #2
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
I know on the DOHC 2.0l that the axle is connected to the windage tray and if it is still connected to the block, then no you would have to go under and undo the oil pan and windage tray to pull the block out. Also it's the fact of, to undo the connecting rods and pull the pistons out, you would need to get to the crank. So you would have to eventually take the windage tray out. Also I think the there are bolts on the windage tray that connect to the block that you can not get out without pulling the windage tray and axle bearing carrier on the back of the motor.
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 12-07-2010, 09:38 PM   #3
Trouble in El Cajon
Fan#: 81013
I don't know if the SOHC and DOHC engines are similar in regard to this. The biggest obsticle that I see is that if I seperate the engine from the transaxle, will there be enough clearance for the flywheel to clear the transaxle housing to lift it out the top.
Old 12-07-2010, 09:49 PM   #4
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Ah okay, but isn't the trans axle for the passenger side have a bearing carrier that is connected to the windage tray?
Like this.
HN #17
D23 crew-#1
Djzx3 is offline
Old 12-07-2010, 09:54 PM   #5
l_estep25
Fan#: 79682
What I Drive: 2010 Flame Blue Metallic ZX4
FF Reputation: 1 l_estep25 Good Standing Member
Pulled one out of the top last week. No big deal. Took 3 hrs for engine removal.
l_estep25 is offline
Old 12-07-2010, 10:01 PM   #6
Trouble in El Cajon
Fan#: 81013
Yes. There is a cast iron bracket that is bolted to the block. It holds the bearing carrier. Maybe I don't understand what a windage tray is?!
Old 12-07-2010, 10:02 PM   #7
Trouble in El Cajon
Fan#: 81013
Did you need to remove the the dampener pulley for clearance?
Old 12-07-2010, 10:02 PM   #8
l_estep25
Fan#: 79682
Neither do I and I'm a Ford mechanic lol. Probably a different term for something we really do know about.
Old 12-07-2010, 10:09 PM   #9
Trouble in El Cajon
Fan#: 81013
windage tr4ay is the stamped metal plate that bolts to the bottom of the block inside the oil pan. It is for oil control.
Old 12-07-2010, 10:20 PM   #10
l_estep25
Fan#: 79682
Not sure why you would take it out before removing the engine...?
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
