ABS & ESP Warning lights are on - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Regional Forums > Overseas Fanatics > Fanatics: Europe
Fanatics: Europe Europe & UK Global Forum
Old 12-01-2010, 05:10 PM   #1
rigg68
Fan#: 80900
What I Drive: Ford Focus 2.0 Ghia
FF Reputation: 1 rigg68 Good Standing Member
Hi Everyone,
Due to the bad weather here in north of England the Traction control system and the ABS on my Focus has been working overtime for the past week and now the yellow indicator lights are illuminated continuously on both the ABS & the ESP (Electronic Stability Program).
Sequence of events as follows
The traction control was working fine as proved when stuck on compacted ice and I managed to get it moving after about 10 secs you could feel it kicking in and out. Also the light was flashing on and off when the wheels slipped slightly on normal driving on snow covered roads.
The following day my daughter was driving down hill on a clear section of road and the ABS & ESP & Handbrake warning lights just all flashed on together, this is without touching the brakes or handbrake.
When arriving home and switching off the ignition the lights all went off. But today the ABS & ESP lights are back on in other words indicating a malfunction.
Going to check the fuses tomorrow 21 & 11 in the engine compartment, and fuse 30 for the ABS module in central fuse box.
Cannot find any fuse for ESP ?
Dont think I am that lucky to be a simple blown fuse, more likely water ingress as it's been running through ice, slush, rain, snow, for 10 days now. or just the fact that these brake parts only get tested once a year. There is close to 100,000 miles on the clock so its getting on a bit but it has been a good car.
If anyone has any ideas or experienced similar problems or can tell me what else to check please post a reply.
Ford Focus Ghia 2.0 l Zetec-E Manual Transmission Hatchback UK reg 2000
rigg68 is offline
Old 12-02-2010, 04:13 AM   #2
Z_interactive
Z_interactive's Avatar
Fan#: 69219
What I Drive: 2007 blue 1.6
Points 5,402, Level 47
Points: 5,402, Level: 47 Points: 5,402, Level: 47 Points: 5,402, Level: 47
Level Up 26% Completed
FF Reputation: 2 Z_interactive Good Standing Member
which model is it? MkI or MkII
On MkII ESP problems are not somethnig strang I know few people that have ESP problem, all I can recomended to you is go to ford dealer to fix it.
Also try some UK focus forums because here are mostly US people!
Good luck
V8, 4.0 L, 420 hp, 6 speed manual, rear wheel drive, coupe, REDLINE AT 8400 rpm = 2007 BMW M3 E92 - new will be turbo, shame
Visit http://zinteractive-fordfocus.webs.com/ for all informations about ford focus! / UPDATED at 27/07/2012
Z_interactive is offline
Old 12-02-2010, 04:14 AM   #3
Z_interactive
Fan#: 69219
ups, just saw
thats all i can help you!
Old 12-02-2010, 04:46 AM   #4
rigg68
Fan#: 80900
Cheers, just dropped it off at the garage today.
"Just in case anyone has the same fault the Diagnostic check found Fault code C1234 O/S/F Speed Signal missing, so new sensor to fit"
rigg68 is offline
