rallycross prep...halp! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 11-27-2010, 03:06 PM   #1
PARKINGLOT
PARKINGLOT's Avatar
Fan#: 31916
What I Drive: 2001 Sangria Red ZTS
FF Reputation: 1 PARKINGLOT Good Standing Member
I'm looking to get into SCCA rallycross, either stock or prepared. Using my 01 ZTS. Where should I start? Car is basically stock right now....
01' Sangria Red ZTS, 2.0, MTX...
SEDAN REVOLUTION #123
95' Grand Cherokee 4x4. Wheeler, Tow Pig, & DD
"It's much more fun to drive a slow car fast, then a fast car slow..."
PARKINGLOT is offline
Old 11-28-2010, 01:32 AM   #2
eliaslincoln
Black Mesa Racing
eliaslincoln's Avatar
Fan#: 6025
What I Drive: 2010 C30 R-design & 2002 ZX3
Points 8,916, Level 63
Points: 8,916, Level: 63 Points: 8,916, Level: 63 Points: 8,916, Level: 63
Level Up 56% Completed
FF Reputation: 11 eliaslincoln Great Standing Member
Buy-Sell-Trade Rating: (8)
thats all you really need. run in the stock class if its stock. What all is on the car?
2009 FocusFest 2nd Place Slalom Finish
2009 NRSCCA ST Class Champion and Rookie of the Year!
2011 & 2012 Lincoln ProSolo Bonus Challenge Winner
eliaslincoln is offline
Old 11-28-2010, 06:54 PM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
You should do just fine with a stock car. Hopefully the car hasn't been lowered and you have some resonably fresh shocks on it. Remove all loose items from the interior and trunk before going to an event (includes things like floor mats, etc). Air up the tires a little. I like carrying a portable air tank with me so I can play with pressures a little but a plug in inflator will work as well. On a soft dirt course you want a little more air to prevent from rolling a tire off the wheel. An all season tire with an aggressive tread or a snow tire can help but if it's your first time, you can make anything work. Use your first event to get use to the car and then go from there preparation wise.
Geezer is offline
Old 11-28-2010, 07:13 PM   #4
PARKINGLOT
PARKINGLOT's Avatar
Fan#: 31916
car is stock other than a Steeda short shifter and a cheap CAI....new shocks and stuff are probably a good idea, as are new tires...
Old 11-29-2010, 03:08 AM   #5
Tyler T
Tyler T's Avatar
Fan#: 42066
What I Drive: two '02 SVT's
Points 974, Level 16
Points: 974, Level: 16 Points: 974, Level: 16 Points: 974, Level: 16
Level Up 74% Completed
FF Reputation: 2 Tyler T Good Standing Member
First go over the whole car for a thorough tune up and to make sure everything is in good reliable order. Next just add a big rear anti-roll bar to dial out understeer and aid rotation in the tight slow speed corners (if that doesn't move your car up in class.) And 42+psi tyre pressure, as mentioned, to avoid rolling the tyre bead off the rim. And if you are running long/often enough to experience brake fade, flush your system with Motul 5.1 fluid. Other than that just have fun and practice car control. Let me know if you have any questions.
tyturnbull.com
understeering? visit FealSuspension.com
for quality repairs and modifications in the LA area: StevesAutoClinic.com
Tyler T is offline
Old 11-29-2010, 03:36 PM   #6
PARKINGLOT
PARKINGLOT's Avatar
Fan#: 31916
That sounds like a pretty decent starting point...
suggestions on a rear bar?
Old 11-30-2010, 05:29 PM   #7
Geezer
Fan#: 1427
I suggest competing a few times before playing with the bars and find out if you have any significant push (understeer) that needs to be addressed. Disconnecting the front bar may be all you need while retaining a stock rear bar.
As far as brakes I have never seen or heard of brakes fading at a rally cross event. Events are just too short to generate a heat problem. Braking on dirt is easier on the system than stopping on pavement as you don't need to apply the same amount of pressure as they will lock up sooner than latter. In my opinion, race fluids are complete overkill for rallycross. Yes, you should have fresh fluid (whether you're rallycrossing or not) in your brake system. Castrol LMA is a step up from stock replacement fluids and costs about the same (which is still quite a bit less than race fluids). I (and lots of other people) have used Castrol LMA in stage rally cars.
Geezer is offline
Old 11-30-2010, 07:31 PM   #8
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,663, Level 48
Points: 5,663, Level: 48 Points: 5,663, Level: 48 Points: 5,663, Level: 48
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 2%
FF Reputation: 36 thenorm Great Standing Member
if you are serious about SCCA events, then you need to have a good read of the rulebook. I'm not certain, but your STS and CAI might bump you upto prepared.
other than that. all you really need is tires. some 14 or 15" steel wheels with some beefy winter tires and you're good to go.
i recently bought a beater escort GT to use for rally-x. it has no interior so that would have put me in SCCA 2wd mod class, but locally there are only 2 classes. 2wd, 4wd.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 12-01-2010, 03:03 PM   #9
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
FF Reputation: 23 wrc_fan Great Standing Member
Left foot brake, no bar needed
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 12-01-2010, 05:30 PM   #10
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 02 SVT, 2 7.3 L Diesel Excursions!
Points 28,017, Level 98
Points: 28,017, Level: 98 Points: 28,017, Level: 98 Points: 28,017, Level: 98
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
don't pull out the rear, the rally foci (for staged events just pull out the rear, else you'll bet a bit too much understeer as mentioned!
Now I rive 2 7.3 L diesel trucks!
mlbbaseball is offline
