EGR(?) w/ Volant question... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-08-2004, 06:15 PM   #1
l88m22vette
Fan#: 2184
What I Drive: 2001 Twilight Blue ZTS
FF Reputation: 1 l88m22vette Good Standing Member
Unhappy EGR(?) w/ Volant question...
Ok, I just installed my Volant, but you know the little hose you have to plug into the corner of the Volant, near the MAF hole? Well, tried to plug/snap it in, but it just kind of goes and, and can fall out anytime. Is this normal? Any ideas?
Full SVT brake swap, indiglo gauges
http://www.ebaumsworld.com/honda-ad.html
l88m22vette is offline
Old 09-08-2004, 06:18 PM   #2
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
No, mine was really tight when it fit into my VOLANT.
You could probably crazyglue it in place (temporarily). Does that 'angled' piece look damaged or old? I had to push pretty hard in to get mine to fit and my VOLANT was a used one so it's had one in there before. You can also buy that tube with the rubber 90 degree angle piece from FORD also.... pretty cheap.... or the junkyard....
Chad (S2)
S2 is offline
Old 09-08-2004, 06:39 PM   #3
whiteboyslo
whiteboyslo's Avatar
Fan#: 180
What I Drive: 04 Pontiac GTO - Yellow M6
FF Reputation: 2 whiteboyslo Good Standing Member
Buy-Sell-Trade Rating: (11)
i'm assuming you're talking about the crankcase ventilation filter hose, the one that runs from the valve cover over to the box? if so, i'd recommend just sticking a breather filter on the end and be done with it. won't pass smog that way in some areas, though.
Mike
just visiting now....
whiteboyslo is offline
Old 09-08-2004, 06:58 PM   #4
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
Yeah..... I have seen guys with a small filter on the end also but why not put that hose to where it's ment to be (attached to the VOLANT air box).
Chad (S2)
S2 is offline
Old 09-09-2004, 01:20 PM   #5
osiris_vdc
osiris_vdc's Avatar
Fan#: 10486
What I Drive: 2003 Silver ZX5 ATX Disco Potato
FF Reputation: 5 osiris_vdc Good Standing Member
I have the exact same problem with my Volant. My mechanice told me the secret to a nice fix. The problem is the tube isn't long enough and so over time the tension of the tube pulls the end out of the Volant. To fix it go to some place like Pep Boys and find a plastic piece that is used to join two pieces of tube. Cut the tube and put the joiner in the middle to slightly lengthen the tube and it wont pull out of the box anymore. Hope this hleps.
-B
osiris_vdc is offline
Old 09-09-2004, 01:21 PM   #6
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
Why not just replace the entire hose with a longer one, that is what I did. What you said above would work also but then you have more 'joints'.....
Chad (S2)
S2 is offline
Old 09-09-2004, 01:32 PM   #7
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
um....so if you sucked up some dust in your Volant box, won't that go in to the breather tube since there's no filter/screen to block anything from getting into your crank case?
Just reading.....
microtonal is offline
Old 09-09-2004, 01:37 PM   #8
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
Microtonal, who are you talking to?
Yeah that makes sense what your saying.... so you would recommend the 'filter' on the end of that hose rather then just hooking it into the air box?
Chad (S2)
S2 is offline
Old 09-09-2004, 03:16 PM   #9
osiris_vdc
osiris_vdc's Avatar
Fan#: 10486
If you look in the original air box you will see Ford used a little square of foam to filter air comming in that tube. I thought about transfering this piece of foam from the stock air box but decided I wanted to keep the original parts in tact.
-B
Old 09-09-2004, 03:32 PM   #10
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
I was just asking if particles could get in to the engine from the Volant box through the unfiltered crank case tube.
I wasn't sure and didn't know the answer so I bought a breather filter and plugged the hole in the Volant.
Just reading.....
Similar Threads
egr question ZXthrizzle05 General Technical Chat 14 12-11-2009 02:02 PM
volant intakes question darkstar4100 ZETEC Performance (2000-2004) 7 06-13-2008 09:35 AM
Question about Volant and Ice-Man CAI (not about which to buy) ZX3 Type R ZETEC Performance (2000-2004) 10 10-18-2003 01:41 PM
Intake Question - Heat affects - Focusport please comment pitchblackab ZETEC Performance (2000-2004) 10 09-14-2003 11:05 AM
Volant Question PizZel ZETEC Performance (2000-2004) 7 09-09-2003 06:03 PM
