Strange Turn Signal Issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-13-2010, 03:18 PM   #1
TruePCs
TruePCs's Avatar
Fan#: 80449
What I Drive: 01 Ford Focus ZX3 AT Purchased new
Points 138, Level 2
Points: 138, Level: 2 Points: 138, Level: 2 Points: 138, Level: 2
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 TruePCs Good Standing Member
I have a 2001 Ford Focus ZX3 AT that we bought new, but am having a strange issue with the left turn signal. The light on the dash along with the front light do not work, but the rear one does, it flashes at normal speed (not fast), and also do not work with the hazards. Ive replaced and switched all bulbs and replaced the turn signal switch and am now at a loss to what to check next. I did have a local garage look at it that were at a loss and said they could not figure it out either. I could bring it to a dealer but they are too expensive seeing that i am unemployed at the moment. The car needs to be inspected in a month so this issue needs to be resolved. Any clues would be helpful. I did a search on the board but did not see anything like this issue. I'm Desperate, Thanks.
TruePCs is offline
Old 11-13-2010, 06:55 PM   #2
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
Between the turn signal switch and the l.f. turn signal stands the hazard switch. It uses inputs from the stop light switch, the turn signal switch, and it's own status (pushed or not) to decide which of the signal lights should be on, off, or blinking. Since the switch is new and you've confirmed the bulbs are good, I would begin by looking there.
I'm looking at a wiring diagram here, and according to it, when the L turn signal is blinking, voltage should be present at the terminal with the blue/white and the blue/black wire (both on one terminal) the blue/white wire is feeding the LF light, the blue/black wire is feeding the tell-tale.
If no voltage is present at that terminal, the switch is probably bad. I don't think this is a problem with fuses or wiring, since the two lights affected have no wiring in common.
Often wrong but never in doubt.
Blurvfocus is offline
Old 11-16-2010, 09:52 AM   #3
TruePCs
TruePCs's Avatar
Fan#: 80449
Points 138, Level 2
Sorry for the late reply, I will try and look at the switch today or tomorrow, have been busy looking for work and the Focus had been busy, I really appreciate the help. Do you thing I should purchase another switch from eBay?
TruePCs is offline
Old 11-16-2010, 01:17 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,705, Level 73
Points: 12,705, Level: 73 Points: 12,705, Level: 73 Points: 12,705, Level: 73
Level Up 64% Completed
Forum Activity 99%
Posted via FF Mobile Try a local junkyard if handy, switch should be very cheap that way and they`re usually guaranteed (as in take it back and grab another to try if it doesn`t work)
sailor is offline
Old 11-16-2010, 04:38 PM   #5
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
FF Reputation: 68 TerryB Excellent Standing Member
Tascaparts.com has them locally. They are $32.08. But I think the shipping is $10.00.
I just reread your first post. Being out of work, stick with eBay or junk yard.
TerryB is offline
Old 11-20-2010, 08:03 AM   #6
TruePCs
TruePCs's Avatar
Fan#: 80449
Points 138, Level 2
Ordered a used switch from eBay for $8.90 shipped, this is a top rated dealer that i have used before. Will update the thread when i get it and install it. I am just hoping it is not a computer issue or something expensive like that. It does have me stumped tho.
TruePCs is offline
Old 04-27-2011, 06:23 PM   #7
TruePCs
TruePCs's Avatar
Fan#: 80449
Points 138, Level 2
Ok it has been a while, the car has been sitting but just replaced the emergency/hazzard flasher switch and that was the problem. For future reference for anyone with this type of strange directional issue that all the directional wires connect to this emergency/hazard switch, now I have a extra directional switch as that was not the problem. Thank you Blurvfocus!
TruePCs is offline
Old 05-01-2011, 07:35 PM   #8
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
You're welcome, comrade.
Old 04-21-2014, 07:41 AM   #9
TruePCs
TruePCs's Avatar
Fan#: 80449
Points 138, Level 2
3 Years later and the switch went bad again, lost the turn signal on one side again in the front and dash only and replacing the switch fixed it again, very strange.
TruePCs is offline
Old 04-21-2014, 01:28 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Check this recent one for a possible related issue:
http://www.focusfanatics.com/forum/showthread.php?t=404946
Your repeat bad hazard switch could be a fluke, this came to mind as a possible contributing factor.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
