Heater not working at all! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 10-29-2010, 09:08 AM   #1
frankie420
Fan#: 79973
What I Drive: 2001 Ford Focus ZX3 Blue
FF Reputation: 1 frankie420 Good Standing Member
I have a 2001 Ford Focus ZX3 (119,000 miles), Here's what I know about the problem:
- The heating/ac system isn't working on any blower setting (1,2,3, or 4)
- After the car warms up when I drive fast warm air will leak out eventually warming the car slightly.
- The fuse is blown for the heating/ac system, replaced fuse, blew when I turned on the car.
- Replaced the Blower Motor Switch, didn't work.
It's getting to be winter and I'd like to figure this out and maybe fix it myself before the snow flies. My girlfriend (it's her car) and I appreciate any help. Thanks you!!!
frankie420 is offline
Old 10-29-2010, 09:18 AM   #2
Notorious0ne
Notorious0ne's Avatar
Fan#: 70375
What I Drive: 05 Saleen Focus, 04 Saleen Focus
FF Reputation: 15 Notorious0ne Great Standing Member
Buy-Sell-Trade Rating: (6)
Well it looks like you have a short which would cause your blower settings not workings. the warm air that blows through when driving is just from your engine bay it happens on all cars. unless you switch it over to the cold side.
If its definitly a short you might wanna take it somewhere to get it looked at cause wire shorts are a bitch to find.
2004/2005 Ford Focus Saleen
The cops are here to keep us safe.............I'm here to keep them busy!
Hatch Nation #43
Notorious0ne is offline
Old 10-29-2010, 09:29 AM   #3
SanduskySerpents
Fan#: 78065
What I Drive: 02 Silver Focus SE
FF Reputation: 4 SanduskySerpents Good Standing Member
Sounds like the resistor went bad. No resistance when applying power will blow thr fuse every time.
Posted via FF Mobile
SanduskySerpents is offline
Old 10-29-2010, 09:41 AM   #4
frankie420
Fan#: 79973
Is there a way to diagnose this myself? Would it be specific wires that run from the heater core to the "Heater Panel"? How would I figure out what wire is shorted out?
Just a little about my mechanical history...with direction I can usually fix things...I've replaced all the stereo equipment...removed door panels...replaced headlight bulbs. Is there a chance I can fix this?
Old 10-29-2010, 09:42 AM   #5
frankie420
Fan#: 79973
I'm going to NAPA to get the replacement part (Blower Resister) ...I'll post when I fix it up and see what happens.
Old 10-29-2010, 10:37 AM   #6
SanduskySerpents
Fan#: 78065
Remove everything from.the glove box, squeeze the sides to bring it down farther, there will be a bright blue box looking thing with wires on the right IIRC . (if its been replaced before it will be black) remove connector and unbolt with 8mm . It's a Ford only part so you need to go to a Ford parts department to get it . about 15-25
Posted via FF Mobile$
Old 10-29-2010, 10:44 AM   #7
SanduskySerpents
Fan#: 78065
Left side
http://4.bp.blogspot.com/_edmURbisrb...0/resistor.jpg
Old 10-29-2010, 10:50 AM   #8
SanduskySerpents
Fan#: 78065
I don't know what the values are for voltage but if you have a multimeter you can test the resistance. If 12v getting through then there isn't any.
Old 10-29-2010, 11:36 AM   #9
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
Location: People's republic massivetwoshits, United States
What I Drive: 2004 svt focus EAP
FF Reputation: 22 alex62390 Great Standing Member
shouldn't there be 12 volts available for fan speed 4?
2004 svt focus EAP #658
Former Hatch Nation #08
alex62390 is offline
Old 10-29-2010, 12:16 PM   #10
SanduskySerpents
Fan#: 78065
Im not sure, the purpose of the resistor pack is to lower the voltage before it gets to certain components so they dont fry. i would need the schematic to be sure.
