Replace master cylinder clutch - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2012, 04:12 PM   #71
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,945, Level 87
Points: 18,945, Level: 87 Points: 18,945, Level: 87 Points: 18,945, Level: 87
Level Up 19% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
So the brake master cylinder are actually the clutch master to?
badazz2010focus is online now
Old 02-15-2012, 11:37 PM   #72
Notorious0ne
Notorious0ne's Avatar
Fan#: 70375
What I Drive: 05 Saleen Focus, 04 Saleen Focus
Points 7,492, Level 57
Points: 7,492, Level: 57 Points: 7,492, Level: 57 Points: 7,492, Level: 57
Level Up 72% Completed
FF Reputation: 15 Notorious0ne Great Standing Member
Buy-Sell-Trade Rating: (6)
Brake master cylinder and the clutch use the same fluid. They are not the same though
2004/2005 Ford Focus Saleen
The cops are here to keep us safe.............I'm here to keep them busy!
Hatch Nation #43
Notorious0ne is offline
Old 02-15-2012, 11:55 PM   #73
badazz2010focus
Fan#: 78166
Forum Activity 7%
the clutch master is where by the pedal?
Old 02-16-2012, 11:57 AM   #74
Notorious0ne
Fan#: 70375
Yes it is. The fluid container has a divider in it. Where half goes to the brake master, and half goes to the clutch master. If you look through the photos you will see the clutch master.
Hatch Nation #43
Old 02-16-2012, 06:49 PM   #75
badazz2010focus
Fan#: 78166
Forum Activity 7%
ah ok
Old 04-07-2012, 07:19 PM   #76
DirtyKnux
Fan#: 88209
What I Drive: 2005 Pitch Black zx3
FF Reputation: 1 DirtyKnux Good Standing Member
i have a 2005 zx3 and after driving off a small curb the clutch pedal no longer fully depressed. It sinks to a certain level but then just stops. I cant start the car, though I'm still able to get it into gear. I looked underneath the pedals and while my clutch pedal was clean, there was a small amount of fluid dripping down the brake pedal. Does this sound like a cmc problem, or something else?
DirtyKnux is offline
Old 04-15-2012, 03:51 PM   #77
MisterJohnson
M0derator Monkey
MisterJohnson's Avatar
Fan#: 51724
What I Drive: '04 ZX3 D23
Points 62,373, Level 100
Points: 62,373, Level: 100 Points: 62,373, Level: 100 Points: 62,373, Level: 100
Level Up 0% Completed
FF Reputation: 30 MisterJohnson Great Standing Member
Buy-Sell-Trade Rating: (18)
Great write up! Rep added
I'm almost done, i just have to wait for my brother to come over and help me bleed it. Only took me about 1.5 hrs to get this far!
A few tips for those doing this in the future...
- When removing the CMC, remove the white retainer from the brake pedal (to disengage it from the plunger) so you can remove the whole bracket and CMC as one unit.
You DON'T have to remove the clutch pedal from the assembly. After removing the assembly as one piece;
- Remove clutch return spring.
- Unbolt the CMC from the bracket.
- Bump it loose (it has to slide down a little).
- Pull the white plunger off.
Install new CMC onto the bracket in reverse order;
- Approximately position CMC on bracket.
- Slide plunger onto pin.
- Slide CMC into place, then bolt it in (may take some finagling).
- Re-install return spring (easiest method - put spring onto the pedal first, then using pliers put the other end onto the bracket.
If you DO unbolt the clutch pedal, put some loc-tite on it when putting it back together. This will prevent it from coming loose (some people have had that problem).
In the engine bay;
To remove/replace the hard to reach bolts or clips without dropping them:
- Buy a cheep extendable magnet. It's worth it's weight in gold.
15.07 @ 93.49 Team Duratec #149
MisterJohnson is offline
Old 05-24-2012, 08:12 AM   #78
B@biGirl
Fan#: 99405
What I Drive: 2004 Gray zx3
FF Reputation: 1 B@biGirl Good Standing Member
Wat tools do I need to do this repair?
B@biGirl is offline
Old 05-27-2012, 10:07 PM   #79
Snowfan
Fan#: 73308
What I Drive: 2003 Yellow SVT
FF Reputation: 1 Snowfan Good Standing Member
Smile Wow.
Amazing guide. I did all of this with minimal tools. Took me a grand total of about 6 hours. I feel proud. Cheers!
-Snowfan
Snowfan is offline
Old 05-28-2012, 01:21 AM   #80
MisterJohnson
M0derator Monkey
Fan#: 51724
^^Sorry to hear it took you 6 hours, but it's still better than paying shop labor to have it done!
Tags
clutch master cylinder
