Accelerator sticking. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2010, 06:36 PM   #1
beekeeper
Fan#: 79880
What I Drive: 2005 ford focus ZXW
FF Reputation: 1 beekeeper Good Standing Member
We have a Ford Focus, 2005. There is no problem during the summer, but when winter comes the accelerator will begin sticking. When my wife leaves for work it will be fine, but down the road, 3 to 15 miles the accelerator pedal will begin to stick, bad enough to make driving scary. My guess is that it is the cold that affects it. I've had it happen to me and it is a problem. We have to press hard to make it go (slowing down is not a problem) but pressing hard it will break free and speed up too fast.
There is nothing in the way of the pedal and we have taken it to two mechanics and neither have been able to solve the problem. I had the last mechanic put in a new cable thinking there might be moisture in the old cable, it did not help.
Any ideas?
beekeeper is offline
Old 10-26-2010, 06:46 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
We've had lots of people experience this problem. What you need to do is remove the air intake so you can see the butterfly valve in the TB. Now take some carburetor cleaner, or just simply alcohol, and a rag, and start cleaning. Clean all the black crud out of there. Work the throttle by hand so that you can clean the bottom side of the plate, and the top of the TB. Clean all that black stuff out of there, and it should solve the problem.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-26-2010, 08:46 PM   #3
Ryan03svt
Fan#: 62675
What I Drive: 2003 black focus svt
FF Reputation: 2 Ryan03svt Good Standing Member
Had the same problem on my 03 svt. Just give the throttle body a good clean and your problem should go away. mine did.
Ryan03svt is offline
Old 10-27-2010, 12:37 PM   #4
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
Points 18,461, Level 86
Points: 18,461, Level: 86 Points: 18,461, Level: 86 Points: 18,461, Level: 86
Level Up 23% Completed
FF Reputation: 352 NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member
the 2005s had a problem with the factory TB...the plastic compound shrinks too much in the cold, and it causes the plate to stick. cleaning will help, but when it gets really cold, like below freezing, it will become a bigger problem.
Ford issued a TSB on this, not sure if it reached the recall level, but when i brought mine in, they swapped in a new tb right away, no cost, and no questions. the new ones had a stronger/thicker wall so they did not constrict like the originals.
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 11-17-2010, 07:39 AM   #5
jdr00ejr
Fan#: 26295
What I Drive: 2005 Liquid Grey ZX4 SE
FF Reputation: 1 jdr00ejr Good Standing Member
I logged in here looking for this exact problem. Can you tell me more about the TSB? If I call ford and tell them my accelerator is sticking will they know?
Sorry - I'm mechanically ignorant - but always willing to learn. Can someone point me to a picture that shows what I need to take apart and clean?
Thanks!
Joshua Richardson A.K.A. The Flash
jdr00ejr is offline
Old 11-17-2010, 08:00 AM   #6
J-Town_2006ZX3
J-Town_2006ZX3's Avatar
Fan#: 77950
What I Drive: 2006 ZX3 R.I.P.-Currently 02'zx3
Points 1,230, Level 19
Points: 1,230, Level: 19 Points: 1,230, Level: 19 Points: 1,230, Level: 19
Level Up 30% Completed
FF Reputation: 3 J-Town_2006ZX3 Good Standing Member
I have the same problem on my 06 zx3. Now that it's getting pretty cold in Michigan, I'm sure it'll start acting up. Nice to see a solution for it, other than having to pop the pedal down fairly hard to get it going. They must not have issued a recall for this on the 06's.
The throttle body is where your air intake connects with the intake manifold right? (rookie here). Further explanation on where or pic woudl be great!
J-Town_2006ZX3 is offline
Old 11-17-2010, 09:21 AM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
TSB= technical service bulletin. These are often confused with recalls- but that's not what it is. It's merely an in-house method of sharing experiences with other repair techs that might be out of the ordinary. For example, some automatic transmission shifting problems were traced by a master tech to be a ground wire that was left disconnected by the factory. Now other techs who get baffled can look up this solution if the problem is similar. It's basically the same thing as this forum is for us- except everyone is a professional- LOL.
Whether or not you can get a new TB or not, I don't know. I don't even know if you can purchase a re-designed TB.
Oh, and yes, the throttle body is what holds the throttle plate that tilts and lets air into the engine. It is between the air intake and the intake manifold. It doesn't get cold where I live, so cleaning always worked for me.
I'd like to know if there is a re-designed factory TB, what the part number is, and what the TSB number is. That would be information that would speed things along for anyone going in for this repair.
Be eclectic.
Old 11-17-2010, 09:25 AM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,329, Level 75
Points: 13,329, Level: 75 Points: 13,329, Level: 75 Points: 13,329, Level: 75
Level Up 20% Completed
Forum Activity 99%
Posted via FF MobileRight location, look for the throttle cable connecting there and that`s the spot! hard to describe identifiers since much mechanical is hidden by covers, like the cover over the pulley the throttle cable moves to open the (internal) throttle plate (or butterfly valve). TB is sandwiched between intake air hose & intake manifold if that helps..... It`s there to "throttle" or "control" air flow at the last single pipe section of intake plumbing, B4 air enters the tuned intake manifold runners.
sailor is online now
Old 12-18-2010, 12:28 PM   #9
madisonHQ
Fan#: 81165
What I Drive: zx5
FF Reputation: 6 madisonHQ Good Standing Member
this thread was very helpful thanks yall !!!
Hatch Nation
Team Duratec
madisonHQ is offline
Old 12-20-2010, 12:54 AM   #10
PiSTOLpete717
PiSTOLpete717's Avatar
Fan#: 81212
What I Drive: 2002 Infra Red SVT FOCUS #2294
FF Reputation: 1 PiSTOLpete717 Good Standing Member
It sounds like your throttle body is full of carbon build up, clean it out and you should be okay..
I Got this On Lock
PiSTOLpete717 is offline
