Zetec Turbo Build: 230-250whp, then 330+whp - Page 31 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
Old 03-08-2012, 11:18 AM   #301
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Nice , you will be fine with the worm clamps , those your using are red heads and I would put those up against any t-bolt if not better the t-bolts
t-bolts are over rated on most cars and worse over tightened , I have no problem running 25-30 psi with worm clamps , the biggest problem is when hoses are installed the hose and or the area the hose is going on isnt clean and free from oil , clean the hose and surface good and worm clamps will hold about anything
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-08-2012, 08:23 PM   #302
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
FF Reputation: 22 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (57)
Yeah, they are the good clamps, not the ones that cut into the hoses, either.
Many guys run the old stock ones on boosted cars no problem, so clean new silicone hoses with all new parts should do the job just fine. If it doesn't, I have about a dozen 2" T-bolt clamps anyways!
Daily: Audi S4 b5 | Project: Turbo ZX3
LED Conversions | Vinyl Carbon Wrapping | Powdercoated Valve Covers
starfuryt550 is online now
Old 03-13-2012, 01:20 AM   #303
starfuryt550
I Speed Often.
Fan#: 18440
Finally got my Mocal Thermostalic plate in.
Do I need to use teflon for the fittings? They do have the crush washers and the rubber gasket built into the washer...?
Photo edited with SnapSeed for iPhone. Kickass app, by the way!
Installing this and the remaining parts of the oil cooling system this weekend. Might tackle intake manifold install + vacuum lines if I feel like it, as well as the catch tank lines, running wires from gauges, and other minor stuff.
Old 03-13-2012, 06:25 PM   #304
starfuryt550
I Speed Often.
Fan#: 18440
I got the fittings they suggest on the site from Mocal, its all the Mocal parts.
http://www.racerpartswholesale.com/c...Sandwich_Plate
...and this is the exact one I got:
http://www.racerpartswholesale.com/p...Sandwich_Plate
...and the fittings:
http://www.racerpartswholesale.com/product/3282/s
Old 03-15-2012, 08:20 PM   #305
starfuryt550
I Speed Often.
Fan#: 18440
Doing this cuz I was bored and rainy:
Old 03-26-2012, 09:55 AM   #306
starfuryt550
I Speed Often.
Fan#: 18440
Does anyone know the size banjo fitting threads I would need for the t3 super 60 for the turbo coolant center housing? It's on of the last tid-bits I need to get before this can all be wrapped up and tuned!
Old 04-02-2012, 10:53 AM   #307
starfuryt550
I Speed Often.
Fan#: 18440
I have the worst luck ever. (This is my Mazda3, daily driver)
I went to change the front endlinks on my mazda before I worked on the focus...
Lo-and-behold, huuuuge problem. There was clanking in the front, and historically it's been from the endlinks. Well, not time time.
The front sway bar is warped and torqued. It's hitting the control arm on bumps on the passenger side as well as the front subframe support, and most importantly, it's been hitting/rubbing on the hard brake line going into the caliper. It's worn through the protective covering and now started to touch the line itself.
Needless to say, I am lucky I looked now before I had a car accident cuz my brake line broke.
I have some other issues as well. ALL the shocks and struts are leaking, badly. Pass endlink is toasted as well. The rear camber arms need to be changed. The hawk pads are near toast all the way around, etc.
So I ordered:
- Hawk HPS pads for all 4 corners
- Brembo blank front rotors
- H&R 24mm front sway bar
- KYB GR2 struts and shocks
- MassiveSpeedSystem rear camber arms
- MOOG front endlinks
Need to buy new strut plate bearing and 2 rear wheel bearings as well. Also need a set of summer tires.
FML. F it real hard. Blah..........
On a positive side, TopSpeed is almost done with my parts and I'll have those shortly to put the whole car back together!
Old 04-02-2012, 11:05 AM   #308
dougy fresh
Sooo Fresh
dougy fresh's Avatar
Fan#: 12780
What I Drive: 2000 zx3, 1978 mustang II 302
FF Reputation: 4 dougy fresh Good Standing Member
Dude that sucks but u drive it like a race car:):) so do I lol glad ur safe man
ZETECCREW#208
Hatch Nation # 74
dougy fresh is offline
Old 04-02-2012, 12:03 PM   #309
starfuryt550
I Speed Often.
Fan#: 18440
I'd like to point out my massive 25mm rear sway bar has blown 4 sets of endlinks.
Im also on my 4th set for the front lol.
Old 04-02-2012, 12:58 PM   #310
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Nice. I have a mazda3 as well. All thou cept for the stereo its all one hundred percent stock. Its just my DD at the moment
FF MODERATOR
RISE AGAIN EGGYOLK130 WHP 124 WTQ ZETEC CREW #271
RIFF CREW
TURBO DYNO COMING SOON
ZXthrizzle05 is online now
