Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
Old 10-26-2010, 12:03 AM   #1
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
FF Reputation: 22 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (51)
Zetec Turbo Build: 230-250whp, then 330+whp
I thought I would finally post my plans as this is getting much closer to being all put together after a long time collecting parts:
* My goals are 300-330whp once I put in the new engine I am building.
* Current goals on the stock engine are 230-250whp.
I suppose I will start with a parts list, let me know if I am missing anything:
Vehicle:
- 2002 ZX3, manual tranny, 88k on clock.
INITIAL (on stock block):
- Turbonetics T3 super 60 .43 AR turbo, ceramic exhaust coating, polished.
- Turbonetics EVO wastegate (multiple psi springs)
- Custom manifold by TurboFab
- Custom DP and WG dump by Top Speed
- SVT 2.5" trubendz exhaust conversion
- Zetec 2.5" trubendz flex pipe
- 50lb injectors
- 2000 Intake manifold, ported
- Focus Central 70mm throttle body
- 180* thermostat w/new housing
- Lakewood traction bars --> might switch to TopSpeed's new design once out
- FS lower stress bar --> Will have to come off as the dp will not clear with it on
- CFM billet aluminum tensioner
- Massive 3 piece UDP
- Gates racing timing belt and acc belts
- Focus Power piping and intercooler
- Greddy type-S BOV
- Innovate wideband AF gauge
- AEM TruBoost turbo controller gauge
- Autometer digital oil pressure gauge
- STR high flow fuel rail
- EGR blockoff plate
- CFM breather plate
- SCT flash tuner
- TopSpeed battery tray/catchcan, slim battery, new terminals
- New much better conduction 1666 strand power cables, new grounds.
- stage3 coolant tank
- stage3 power steering tank
- JayRacing aluminum coolant junction
- New silicone vacuum hoses
- New billet aluminum vacuum junction
- ARP head studs
- New silicone coolant hoses
12/25/2010
* I am switching all of the cooling system including hoses to -an hoses from 16 for the largest, 12 for mid size, and -6/-8 for smaller lines. Dominic is going to make a me a new -16an billet flange and fitting to attach to the stock thermostat housing as well as fab up an aluminum radiator w/-an fittings and side tanks.
* I am converting the entire power steering system from the retarded rubber and hard lines passing over the header to complete -6an lines with a fluidyne cooler to replace the makeshift crappy stock cooler.
(Check posts on pgs 2-3+ for info on this and progress. It will soon be made as soon as the snow stops and I can go outside and take some measurements).
POST BUILT ENGINE:
- 2000 zetec block
- 9.0:1 Probe pistons
- Eagle Rods
- Stock bearings
- New svt oil pump
- new svt water pump
- Centerforce billet 9lb flywheel
- Torsen T2 LSD
- APR flywheel bolts
- ARP main bolts
* I may be missing things I have but I will try and remember...
* All of the above I have already bought and have installed some parts.
My questions are:
1) I need a clutch at some point, im sure it won't last long. I need some recommendations. I dont have a ton of money for this so an Exedy hyper-single for $1,100 isnt good lol.
2) I was going to have Terry Haynes from HMS install my LSD...he recommends getting the tower keyed, recommendations?
2.1) I was also thinking new shift forks in the tranny if i do a complete overhaul?
2.2) I wanted to lower my final drive gear to one from a duratec or zetec to a 3.41 (if i remember the num correctly) with pzev. Reason being to ease the power off the line for better traction.
3) I know my T3 super 60 is good for 325-330 if i remember correctly. What would be a good replacement after I want more power?
I'm gonna have more questions, but I will appreciate thoughts, comments, suggestions, criticisms!
FF Authorized Reseller
I do LED conversions: Focus / Cougar / Contour / Scion TC / Mustang / Fusion / Milan / Escape
http://www.focusfanatics.com/forum/showthread.php?t=299426
starfuryt550 is offline
Fan#: 1
Old 10-26-2010, 12:09 AM   #2
starfuryt550
I Speed Often.
Fan#: 18440
Old 10-26-2010, 01:39 AM   #3
Timmeh!
Rollin' in my Benz
Timmeh!'s Avatar
Fan#: 27514
What I Drive: '91 Red Miata, '85 Benz 300D
FF Reputation: 9 Timmeh! Good Standing Member
Buy-Sell-Trade Rating: (6)
sexy.
that's a REALLY nice build you got going on.
Wilhelm - 85 Benz Turbo Diesel - cruiser
Momo - 91 Miata - topless fun
Originally Posted by beat3rfocus View Post
Catia is a dirty tramp, until you figure out its sweet spots, and how to make it moan. Then its easy as apple pie on a fall afternoon.
Timmeh! is online now
Old 10-26-2010, 01:56 AM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
YouTube Video
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 10-26-2010, 03:19 AM   #5
SVTRSST
70 100 70 70 : (
SVTRSST's Avatar
Fan#: 50439
What I Drive: 2003 Sonic Blue SVT Focus
FF Reputation: 15 SVTRSST Great Standing Member
lookin very good, im subscribed
'03 SVT
0381 of 3985
SVTRSST is offline
Old 10-26-2010, 08:53 AM   #6
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 00 infared ZTS
FF Reputation: 12 Mike_Mac Great Standing Member
wow looks sick. what colour blue is that?
Mike_Mac is offline
Old 10-26-2010, 09:41 AM   #7
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: Miata, STi, GSXR1k
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (24)
your better off with stock coil over the msd
Turbo Turtle Garage
facebook.com/turboturtlefabrication
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 10-26-2010, 09:57 AM   #8
besthaticouldo
i wear no pants
besthaticouldo's Avatar
Fan#: 26970
What I Drive: '11 OBP WRX Sedan
FF Reputation: 104 besthaticouldo Excellent Standing Memberbesthaticouldo Excellent Standing Member
Buy-Sell-Trade Rating: (23)
i disagree, but i am sure the difference is minimal. i ran the MSD coil on both my nitrous zetec car and my SVT motor and it was perfectly fine. its a good coil, but so is the stocker.
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame.
besthaticouldo is offline
Old 10-26-2010, 01:34 PM   #9
starfuryt550
I Speed Often.
Fan#: 18440
Had to buy new rear discs and pads.
Dismantled all calipers and took them in for powder coating.
That was about it yesterday. Didn't get too much time for *.
also painted the front discs black so they won't rust.
I got for the rears:
- Hawk HPS pads
- Centric blank discs, black.
Old 10-26-2010, 01:37 PM   #10
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
What I Drive: '03 CD Silver SVT, '11 Mazda CX-9
FF Reputation: 112 Peregrine Excellent Standing MemberPeregrine Excellent Standing Member
Those are some sexy motor mounts
Peregrine is offline
