Vibration in my 2003 ZTW - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-25-2010, 05:58 PM   #1
kkspeed
Fan#: 51109
What I Drive: 2003 Ford Focus ZTW
FF Reputation: 1 kkspeed Good Standing Member
Like other members, I'm experiencing weird vibrations in my 2003 ZTW / Auto with 66K.
1. Vibration after cold start-up.
2. Vibration when turning left after cold start-up
3. Part-Throttle vibration when warm
4. No CEL's
I changed the following:
1. Passenger's side motor mount (OEM Ford Part).
2. DFTP Sensor
3. Plugs (Motorcraft Copper w/.050 Gap)
4. Factory plug wires
5. Coil Pack
6. Both O2 Sensors (Bosch)
I'm frustrated. I like my ZTW and it runs fine when operating normally, but this vibration is driving me crazy.
kkspeed is offline
Old 10-25-2010, 07:47 PM   #2
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
Posted via FF Mobile
Did you check the other 2 mounts ?. Also make sure that the engine is aligned
Properly. Try moving the pass side mount fwd or backwards. To alleviate the vibrating.
iroc34 is offline
Old 10-25-2010, 09:34 PM   #3
spiller
spiller's Avatar
Fan#: 75607
What I Drive: 11 Sangria SE sed, 01 Wht SE Wagon
FF Reputation: 1 spiller Good Standing Member
I fixed my similar symptoms with just the RH mount, but research did show the dog-bone (bottom or rear mount) to also be an issue. Also had found a few reports of issues with new RH mounts. Pull off cover of mount and feel the top of the rubber bellow. I believe that it should still be firm.
I coupled my RH mount with a timing belt change, and plan on the dog-bone next month with changing the struts. I have the steering wheel shimmy and can bounce the front left fender.
spiller is offline
Old 10-26-2010, 03:05 AM   #4
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
^^^ Yes, I have had problems with the inner fender liners rubbing as well...
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 10-26-2010, 08:24 AM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Bosch!! NO. But should be ok anyway.
DPFE- it usually causes a miss in the engine, as well as at least a misfire code. This is what makes the determination to open the EGR valve.
As far as plug wires go, I recommend the closest national chain store with lifetime warranty plug wires. That way you can change them any time you want- or have any related problem- without costing any more money. We don't really benefit a lot from expensive plug wires- not like a Porsche 911, where you should buy the $900 plug wires.
I digress.
We generally recommend to replace all motor mounts at the same time for this reason after it's been determined that motor mounts are the cause. You've been throwing money at your engine like it has a running problem- does it?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-26-2010, 09:32 AM   #6
arlenn
Fan#: 67609
What I Drive: 2002 Silver ZX5
FF Reputation: 16 arlenn Great Standing Member
how should that bubble on the engine mount feel? firm, or squshy? I have heard both now. Mine is swishy, but is not empty as the dome does not collapse when poked with a finger.
"CD" Silver, 2002 ZX5, SVT Airbox.
arlenn is offline
Old 10-26-2010, 09:52 AM   #7
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
What I Drive: 2003 Liquid Grey ZX3
Points 2,453, Level 30
Points: 2,453, Level: 30 Points: 2,453, Level: 30 Points: 2,453, Level: 30
Level Up 2% Completed
FF Reputation: 1 03FocusZX3 Good Standing Member
Posted via FF Mobile well my bad pass. Side motor mount felt firm and the new one felt squishy, if that helps lol...
03FocusZX3 is offline
Old 10-26-2010, 10:08 AM   #8
spiller
spiller's Avatar
Fan#: 75607
Your RH sounds good. You need to inspect the dog-bone and the transmission mount. The increased vibration in RH turns...should be loading up the left side mount (transmission mount.)
Its way too early as far as mileage goes, but if you get past the remaining motor mounts and still have the vibration I would be checking cam timing. Checking it requires the timing pin tool and removal of the valve cover (use a new gasket when putting back on.) There was another FF who indicated when he changed his, he discovered that cam-timing was off (way off), but had no CEL. When I did mine, cam timing was off just enough I wasn't going to set the cam timing tool without unbolting the cam gears. Of course that's part of the procedure.
Since I did both belt and RH motor mount at the same time, I can't say that the vibration was solely from the motor mount failure.
Were there any other reasons you changed those ignition components?
spiller is offline
Old 10-26-2010, 07:37 PM   #9
kkspeed
Fan#: 51109
The weird thing about my vibration issue is that it is intermittent. Sometimes it goes away when the engine warm and runs real smooth. That is why I thought it was in the EGR system.
Secondly, the engine idles differently when the heater is set to defrost with the heat on.
I suspect the AC turns on automatically when the defroster is turned on to prevent the windows from fogging up.
kkspeed is offline
Old 10-26-2010, 07:38 PM   #10
kkspeed
Fan#: 51109
How do I check that the engine is aligned correctly?
kkspeed is offline
