EGR Delete??? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-22-2013, 06:39 PM   #31
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,597, Level 62
Points: 8,597, Level: 62 Points: 8,597, Level: 62 Points: 8,597, Level: 62
Level Up 49% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
Interesting... not sure if it has. always thought the EGR needed to be under pressure....
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 03-23-2013, 03:40 AM   #32
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
It may work, only about 3-4 psi there............DPFE mainly looking for the DIFFERENCE in pressures. I don't agree with the later O2 sensor failing inspect statement though, they would automatically make up for the extra air. Only by checking for NOx could it be found.
amc49 is offline
Old 04-17-2013, 06:23 PM   #33
2002FordFocusZX3
2002FordFocusZX3's Avatar
Fan#: 102001
What I Drive: 2002 Black ZX3
FF Reputation: 1 2002FordFocusZX3 Good Standing Member
Deleting your egr valve will just give you worse fuel economy it only works while you are cruising anyway it is shut off at wot and idle and the egr also helps keep cylinder head tempuratures down
Ain't nothing but a peanut
2002FordFocusZX3 is offline
Old 04-18-2013, 12:55 PM   #34
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
What I Drive: 01 cd silver 3 door ztec
Points 7,680, Level 58
Points: 7,680, Level: 58 Points: 7,680, Level: 58 Points: 7,680, Level: 58
Level Up 65% Completed
FF Reputation: 2 sgtsmasher Good Standing Member
i dont see how at all, that it helps with cylinder head temps...what the egr does is, from my understanding. taking a half and half mix of burnt gas and unburnt gas from the engine, and returning it through the egr tube, into the ufo looking thing then to the intake manifold. which in turn is getting sucked back into the engine...and from the ufo looking thing, there is small rubber hose that goes to a sensor.
Hatch Nation #72
Call Me BRANDO COMMANDO
sgtsmasher is offline
Old 04-18-2013, 04:18 PM   #35
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,583, Level 58
Points: 7,583, Level: 58 Points: 7,583, Level: 58 Points: 7,583, Level: 58
Level Up 17% Completed
Forum Activity 25%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
I would like to know how much it is supposedly reducing temps since it is adding hotter air to the intake charge than ambient air temps. Only way I see it is if its reducing complete combustion of the mix.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is online now
Old 04-20-2013, 12:01 PM   #36
xsuicidesn0wmanx
xsuicidesn0wmanx's Avatar
Fan#: 65239
What I Drive: 2001 Black Ford Focus SE Sedan
Points 554, Level 11
Points: 554, Level: 11 Points: 554, Level: 11 Points: 554, Level: 11
Level Up 8% Completed
FF Reputation: 1 xsuicidesn0wmanx Good Standing Member
If you're going to have a bung welded on, make sure you get one first, I had a hell of a time finding one and none of the shops I went to had something I could use. Maybe the shops here just suck but to be safe, it isnt that hard to obtain one, apparently they just screw out of the oem header.
I originally had done the EGR Delete except for the tune, couldnt afford it. Had ended up throwing away the egr tubing & valve. Although I was able to find enough parts to put it back together, ended up costing almost as much as getting the tune would have.
I did however figure out that the egr tube from an 02 would work with the 01, I had read elsewhere it might not work but mine works fine.
xsuicidesn0wmanx is offline
