Swapped Interior bulbs with LEDs - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > MK2 Interior Mods & Upgrades
MK2 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2008-2011 Focus.
Old 08-29-2012, 12:45 PM   #71
turntablez
turntablez's Avatar
Fan#: 83139
What I Drive: 2003 Blue Focus SPI
Points 2,905, Level 33
Points: 2,905, Level: 33 Points: 2,905, Level: 33 Points: 2,905, Level: 33
Level Up 4% Completed
FF Reputation: 1 turntablez Good Standing Member
Does anyone know what kind of LED bulb I would need to replace the bulb in an automatic 2003 Focus Sedan gear indicator light in the center console? Thanks!
Todd
turntablez is offline
Old 09-20-2012, 09:22 PM   #72
burton560
Fan#: 74639
What I Drive: 2008 Vermillion SES
FF Reputation: 1 burton560 Good Standing Member
anyone with a write up on how to swap out the trunk bulb?
burton560 is offline
Old 05-09-2014, 11:36 PM   #73
Music
Music's Avatar
Fan#: 155618
What I Drive: 2008 Red Ford Focus SE Coupe PZEV
FF Reputation: 1 Music Good Standing Member
Originally Posted by CamoCustom View Post
I drive a 2010 Focus SE: FYI
What I bought and replaced:
Map Lights (194 style mini wedge base):
6 LEDs with a 30 degree Beam in "Cool White"
WLED-x6 (194 type) Wedge Base bulbs
Interior Dome (194 style mini wedge base, NOT 6411 festoon style):
5-Radially mounted LEDs with a total of 220 degree beam in "Cool White"
WLED-x5 (194 type) Wedge Base bulbs
**Note: I affixed a piece of tin foil for a temp. reflector on the inside of the dome light fixture.**
Trunk Light:(194 style mini wedge base):
5 High power LEDs w/ 360 degree beam in "Cool White" appears more natural white.
I originally got these bulbs for the dome, thinking it would match the brightness of the maps, well, the color is the same "cool white" but since these are high power, they seem whiter, So i just put this in the trunk with its 360 degree beams it really lights it up.
High Power SMD WLED-xHP5 (194 type)
360 degree Wedge Base bulbs
I wish I had read this before I ordered LEDs for the map lights and trunk lights... now I have bulbs that don't work in anything I know of. :(
Music is offline
Old 05-10-2014, 11:24 AM   #74
Music
Music's Avatar
Fan#: 155618
Returning the wrong bulbs to superbrightleds.com and ordered the 194 bulbs. *sigh*
I ordered 3 of these in white and 3 in green. High Power SMD WLED-xHP5 (194 type)
Music is offline
Old 05-16-2014, 01:36 PM   #75
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,431, Level 21
Points: 1,431, Level: 21 Points: 1,431, Level: 21 Points: 1,431, Level: 21
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 2%
FF Reputation: 2 Miztaken1312 Good Standing Member
I got one of these for the trunk. Plugged it in, and stuck it to the body. No issues and man is it bright. Much better then the dinky setup Ford had.
http://www.superbrightleds.com/morei...ase/1236/2886/
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 05-16-2014, 05:12 PM   #76
Music
Music's Avatar
Fan#: 155618
Did anyone have an issue where the remote start stopped working after doing replacing the bulbs with LEDs?
I get the 3 beeps after it fails to start that is supposed to indicate an open door, but the doors and trunk are closed, hood is closed - no door ajar light on.
I sprayed WD40 on the latches of both doors and the trunk, still no change so far. :(
Music is offline
Old 05-16-2014, 06:59 PM   #77
Music
Music's Avatar
Fan#: 155618
Hmm... this thread seems to indicate it may be the issue... bummer. :(
I don't have a dome light, and don't notice any light from the LEDs when they are supposed to be off..., but I guess I wouldn't unless I looked at the bare LEDs.
http://www.fordfusionclub.com/showthread.php?t=510306
Music is offline
Old 05-16-2014, 10:45 PM   #78
Miztaken1312
Fan#: 74993
Forum Activity 2%
I don't have a dome light, only map lights in my car. The LEDs stay on, albeit VERY dimly at all times. It's called power bleed. There is little to no resistance in an LED to make light, where as an incandescent bulb makes light purely through resistance. If current is moving, that's probably enough to stop the remote start system.
Old 05-19-2014, 05:34 PM   #79
Music
Music's Avatar
Fan#: 155618
Does anyone know if I switch this setting in the remote start programming from positive to negative, if it will allow the remote start to work with the LEDs (a door open) - or does it mean something completely different?
Door Ajar Switch Input Inverter - Positive - Negative
Music is offline
