Camber bolts or not? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-06-2010, 07:13 AM   #1
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,373, Level 47
Points: 5,373, Level: 47 Points: 5,373, Level: 47 Points: 5,373, Level: 47
Level Up 12% Completed
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
I've got the FRPP kit from Hilbish on my SVT and I've noticed the rear tires are wearing on the inside(cupping) more than usual. Should I get the Adj camber bolts or the adj upper control arms? I know one of these has to be the cause. I've had it aligned 3 times and each time the tech says it's good. Tires don't say so. It does lean in at the rear at tad, a smidgen, a skoshe, a RCH or whatever you want to fill in to estimate a little bit. So yeah, someone with experience and knowledge on this chime in if you don't mind.
Thanks
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 10-06-2010, 08:06 AM   #2
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
Level Up 0% Completed
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
I would get them and get another alignment done. Make sure to keep up on your tire rotations, as well.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 10-06-2010, 10:44 AM   #3
Missourileo
Captain Retard
Fan#: 55980
Them as in camber bolts or adj control arms.......or both?
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Old 10-06-2010, 11:37 AM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Bolts.
Way cheaper, and easier/quicker to adjust.
I opted for the arms, because I wanted a larger range of adjustment, but in your case I'm sure the bolts would be fine.
By the way, if you do get the bolts, here's some settings to shoot for to get minimal rear tire wear:
Camber: Keep it right around -1.
Toe: Have them set it at the MINIMUM recommened toe IN setting.
^^^.04 Total Toe IN (.02 each side)
See here:
http://www.focusfanatics.com/forum/showthread.php?t=231090
WD40 is offline
Old 10-06-2010, 11:49 AM   #5
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
^^^Dougs right on. I bet the camber isn't whats wearing your tires, its the toe setting. I have a 2" drop and have the bolts, there's plenty of adjustment there.
norcalfocus01 is offline
Old 10-06-2010, 01:05 PM   #6
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Thanks
The truth is that the tech DOES NOT KNOW WHAT THE CORRECT ALIGNMENT SPECS FOR A FOCUS ARE!!!!! He's simply confirming that it's within the spec range and that's simply not good enough. There are "allowable" spec combinations that WILL EAT TIRES. Please read the alignment specs in the stickies at the top of this page. You'll have to ask for them or you won't get them. In almost all cases you will need a rear camber correction devise to do it correctly.
I am concerned when you say the rear tires are "cupping" with new shocks installed. Most cupping is caused by worn shocks. That not being the case, you need to look for other items that may be worn such as control arm bushings etc. as well as tire balance.
Geezer is offline
Old 10-06-2010, 01:13 PM   #7
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,879, Level 59
Points: 7,879, Level: 59 Points: 7,879, Level: 59 Points: 7,879, Level: 59
Level Up 65% Completed
Forum Activity 14%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
I had to use camber bolts on my Focus when I got my suspension from Hilbish and not had any problems out of my tires wearing wrong yet .
But I do keep them rotated almost every other oil change .
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is offline
Old 10-06-2010, 09:30 PM   #8
Missourileo
Captain Retard
Fan#: 55980
Okay, so maybe cupping is the wrong term. I can see the tires wearing more on the inside and they do seem to have a roller coaster pattern going on there. I rotate and balance them every 3k like clockwork. I'm always checking air pressure and such. I appreciate the alignment advice and I'll definitely use it, as well as getting camber bolts. I hope this works, because these BFG KDWs are pricey...........Thanks for all the advice and I'll keep you guys posted as to how the outcome is.
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Old 10-06-2010, 09:46 PM   #9
02ZX5cominalive
02ZX5cominalive's Avatar
Fan#: 29946
What I Drive: 2002 Liquid Grey ZX5 w/S2 kit
FF Reputation: 3 02ZX5cominalive Good Standing Member
I installed the FRPP Kit this spring when I did the SVT rear sub frame swap. I was debating of I should install the camber bolts at the same time. I didn't and everything is fine for me. I did have a good alignment done and I think that is what it needed to keep everything in check.
K&N Intake, FC UDP, SpeedHut Guages, Diamond Plate Mats, iPhone thru DEH-P7900BT Power Bass, GPS, Euro Grills, S2 Lip & Skirts, O-Z Superturismo's, MBRP
FRPP Suspension, SVT Rear Sub-frame.
Totally parted and scrapped.
02ZX5cominalive is offline
Old 10-07-2010, 07:16 AM   #10
Missourileo
Captain Retard
Fan#: 55980
Well, I've had 3 good alignments done and still..........
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
