Help! Water on DRIVER side footwell! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-03-2010, 05:22 PM   #1
F1SportsFan
F1SportsFan's Avatar
Fan#: 65473
What I Drive: 2002 Pitch Black SVT 3 door
FF Reputation: 3 F1SportsFan Good Standing Member
Unhappy Help! Water on DRIVER side footwell!
So I left my car sitting for a few days in the rain and when I came out to drive it I had ~1inch of water in the driver side footwell. I got it all dried out and tarped the car.
Today I changed out both of the cowling pieces since this seems to be the cause of most leaking Foci, but usually on the passenger side. Seemed like it went ok, so I dumped a few gallons of water on the windshield, and still everything was dry.
20 minutes later I jump in the car to take it through a much needed car wash and to test the seal. It's still dry when I start driving. While I'm waiting in line at the car wash I look down and see water all over the floor again!
So I skip the carwash and head home and get it vacuumed out as best I can. I crawled under the dash and cannot see any signs of water on the firewall and all the foam areas I can reach are dry. The heating/cooling area looks dry also. And the passenger side is still dry.
I'm stumped as far as what to look into next. Any ideas would be much appreciated!!!!
F1SportsFan is offline
Old 10-04-2010, 12:03 AM   #2
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
FF Reputation: 12 BowerR64 Great Standing Member
This may or may not be your problem but my last car leaked and it was comming in threw the window. The outside window seal was rotten and the way the window was slanted caused the water to hit the window and run down into the door then into the car. I can see rust now on the door after years of leaking down the window.
Check that and check that little gutter on the roof i think its designed to channel water from the roof down the front or back rather then run over the edge and down the window.
BowerR64 is offline
Old 10-04-2010, 02:52 AM   #3
tjboston5676
tjboston5676's Avatar
Fan#: 71200
What I Drive: 2004 Sonic Blue ZX5 SVT
Points 2,179, Level 28
Points: 2,179, Level: 28 Points: 2,179, Level: 28 Points: 2,179, Level: 28
Level Up 20% Completed
FF Reputation: 3 tjboston5676 Good Standing Member
make sure it isnt brake fluid coming from ur clutch master cylinder as that likes to fail on these cars
HATCH NATION #56
2004 Sonic Blue SVT!!! 2.5" orp and flex and trubendz catback, toms tune, steeda sts, custom intake, good ol motocraft copper plugs!
tjboston5676 is offline
Old 10-04-2010, 04:00 AM   #4
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
Sometimes, water leaking through the scuttle panel below the windscreen drops down into the fresh air intake. It then accumulates in the base of the heater housing and runs out when you move or are parked in a certain direction. Check the pollen filter if you have one, and see if it's wet. This will give you a clue.
If you think I've been able to help, just say
niggly51 is offline
Old 10-06-2010, 10:26 PM   #5
F1SportsFan
Fan#: 65473
Thanks guys, I'll check into these ideas!
Old 10-07-2010, 12:41 PM   #6
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Here is the full TSB 02-25-1:
WATER LEAK AT FRONT PASSENGER FLOOR AREA-SERVICE TIPS
http://www.focusfanatics.com/forum/s...52&postcount=7
WD40 is offline
Old 10-27-2010, 02:29 AM   #7
F1SportsFan
Fan#: 65473
Turns out it was a plugged sunroof drain that was causing the water to come in and soak the floor. Thanks everyone for your thoughts and ideas!
