what does a bad motor mount sound like? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-01-2010, 12:52 AM   #1
drostedrummer89
I <3 my SVT
drostedrummer89's Avatar
Fan#: 69059
What I Drive: 2002 Sonic SVT
Points 5,199, Level 46
Points: 5,199, Level: 46 Points: 5,199, Level: 46 Points: 5,199, Level: 46
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 8 drostedrummer89 Good Standing Member
Buy-Sell-Trade Rating: (10)
when i am starting off slowly, or am traveling at lower speds (25 mph and under) i hear a ticking when i hit the gas. i know its gotta be a mount, but which one and how do i test it while under the vehicle? i had it in gear on a hoist and couldn't replicate the noise for a mechanic at the shop i work at. thanks!
ps, thats the only time i have a problem, no rough idle or popping out of gear. my magnaflow takes over at speeds over 30, so i can't hear any noises in the engine bay.
matt
Posted via FF Mobile
drostedrummer89 is offline
Old 10-01-2010, 01:53 AM   #2
DueceCoupe
DueceCoupe's Avatar
Fan#: 32955
What I Drive: 07 Infra Red ST,2002 ZX3.
Points 7,298, Level 56
Points: 7,298, Level: 56 Points: 7,298, Level: 56 Points: 7,298, Level: 56
Level Up 74% Completed
Forum Activity 2%
FF Reputation: 5 DueceCoupe Good Standing Member
Buy-Sell-Trade Rating: (29)
Is this an automatic?
If so,make sure its not a leak at your flexpipe.
I had the exact problem.
If its a mount,you will experience some shaking.
Mine has a bad dog bone mount right now.....when I put it into gear it makes a crunch noise!
I used to be DueceCoupe,but now I gots a 4 door!
ST Crew Member # 666
DueceCoupe is offline
Old 10-01-2010, 04:05 AM   #3
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,060, Level 34
Points: 3,060, Level: 34 Points: 3,060, Level: 34 Points: 3,060, Level: 34
Level Up 7% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
Motor mount problems are low frequency. More felt as a vibration.
Ed
emsvitil is offline
Old 10-01-2010, 05:02 PM   #4
drostedrummer89
I <3 my SVT
Fan#: 69059
okay, well i'm sure its not an exhaust leak. i hear it tick when I lightly step and press off the gas pedal while cruising.
Old 10-02-2010, 12:07 AM   #5
Usagi
Usagi's Avatar
Fan#: 64712
What I Drive: 2002 SY ZX5
FF Reputation: 4 Usagi Good Standing Member
Could be a CV axle. they can click or pop under low-mid loads if bad.
2002 Focus ZX5 in Zinc Yellow: Steeda Strut Bar, Tom's Tune, Volant CAI with Aux Pipe Extension, SVT suspension, and ST200's.
Usagi is offline
Old 10-02-2010, 12:16 AM   #6
drostedrummer89
I <3 my SVT
Fan#: 69059
That would make me feel alot better, but I'm thinking its the trans to be honest. I just need to go pick up someone who knows diagnosing of drivetrain better than me. Cause I'm not sure, and it scares me to think it could be the trans going.
Old 10-03-2010, 04:22 PM   #7
DueceCoupe
DueceCoupe's Avatar
Fan#: 32955
Forum Activity 2%
So,what did you figure out?
Still,dont rule out the flex pipe leaking.
Mine is exactly as your describing.
Let us know what you come up with.
Old 10-03-2010, 04:27 PM   #8
svtdriver14
svtdriver14's Avatar
Fan#: 62269
What I Drive: 2002, black, svt
FF Reputation: 1 svtdriver14 Good Standing Member
I just blew my poly dog bone into peices, pop the hood, if the motor moves while barley blipping the gas check the mounts,
Keep in mind it could also be a lower control arm bushing as well.
svtdriver14 is offline
Old 10-04-2010, 01:58 AM   #9
mofocus
mefocuslongtime
mofocus's Avatar
Fan#: 5
What I Drive: Beltfed,extra pullified,weeemachine
FF Reputation: 6 mofocus Good Standing Member
Buy-Sell-Trade Rating: (17)
x2, youll notice the engine moving too much and then a slight knock as it hits metal to metal instead of being cushioned by the rubber insert. but also you should be able to see a messed up motor mount pretty easily by lifting the car and peeping at the drivers side under the bottom.
MAY 2007 ROTM WOOT [/COLOR][/B][/U]
my dyno video
mofocus is offline
Old 10-04-2010, 09:44 AM   #10
drostedrummer89
I <3 my SVT
Fan#: 69059
i originally thought it was that mount, but a mechanic looked at it and so did I, and all looked good. I think it's within the trans, because i can be going down a hill with my foot off the gas, and hit the brakes and when i let off it ticks again. but when the car is in neutral it makes no such noise. so no exhaist leak. its based on engine movement. i can be under the hood and rev it all day and the engine stays put. but then again I don't have much torque to begin with :P
matt
