First race with new 213WHP NA Engine - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 09-20-2010, 11:59 PM   #1
tb1999
tb1999's Avatar
Fan#: 44261
What I Drive: '05 ZX3 D2.3 & '03 Jag S-TYPE 4.2L
Points 24,567, Level 95
Points: 24,567, Level: 95 Points: 24,567, Level: 95 Points: 24,567, Level: 95
Level Up 22% Completed
FF Reputation: 47 tb1999 Great Standing Member
Buy-Sell-Trade Rating: (7)
Cool First race with new 213WHP NA Engine
YouTube Video
This is a bitter sweet video. My first event with a freshly built highly modified engine (read more here >> http://www.focusfanatics.com/forum/showthread.php?t=220779 <<) turned out to be a weekend of frustrating ECU calibration issues.
First off, I have an issue where the ECU shuts down and needs the ignition to be recycled for a restart. It seems to happen if the engine exceeds the rev limiter by 'x' RPM's, or it's a hard coded limiter beyond the one I can set using the SCT software that I have been using to tune the car.
Second, I seemed to develop a power loss issue 1/2 way through the race on Saturday. I looked into this when I got home today, and think it's a failed O2 sensor causing the fuel trims to go way out of range. It came and went during the race, but it was idling poorly. If I forced it into open loop, it ran much better.
I'll have to get to the bottom of these issues before oct 3rd, as I will be trying to get out to the track for some more testing.
Good news is, the engine is mechanically sound, and makes good power when the ECU is not flaking out. I'm hitting a top speed of 122MPH going into the bus stop, a good 10MPH faster than last year at the glen.
While I did not have too many good clean laps to get into a groove and really take advantage of the new engine during the race, I did knock off a full 3 secs from my best laptimes last year during a practice session on Friday. (another video soon to come) I think if I spent 2 good days just doing a time trial/PDX with the ECU working correctly, I could easily break into the 2:19's with this car as it sits. I still have some chassis development to work on over the winter. There are plenty of improvements still left on the table within class rules. And I'm about 150lbs overweight for my displacement.
I withdrew from Sunday's race. Qualifying was cancelled due to fog, and since I was having multiple problems with the ECU, I decided that a 15 minute race that I had little chance of getting a podium finish in was not worth the $$. The event was fully booked, and the track was crowded, having a power loos at the wrong time might cause an incident on track. Besides that, I was sort of playing russian roulette with the new motor since I had to jack up the rev limiter just to minimize the chance of the ECU shutdown problem.
I had yet to complete a full session without having the ECU shut down at least once.
Can you say "beating a dead horse"?
It was clearly time to go home......
213 whp / 160 wtq D23 NA with stock intake and TB.
Inventor of "The $0 Thunder Throttle" & "Focuzdax-7" brake swap.
I like the same qualities in women and pistons; Lightweight, fast, and with the smallest skirts possible...
tb1999 is online now
Old 09-21-2010, 01:29 AM   #2
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
What I Drive: toxic waste
Points 8,010, Level 60
Points: 8,010, Level: 60 Points: 8,010, Level: 60 Points: 8,010, Level: 60
Level Up 30% Completed
FF Reputation: 106 SYZ Excellent Standing Member SYZ Excellent Standing Member
Buy-Sell-Trade Rating: (14)
do you think the ecu is sensing false knock and pulling timing?
2003 Ford Escape 4x4 Limited
On Order: 2015 Porsche Cayman S
SYZ is offline
Old 09-21-2010, 12:52 PM   #3
tb1999
tb1999's Avatar
Fan#: 44261
Yep, I'm pretty sure I'm getting some false knock, but that's already been dealt with in the calibration. I limited knock retard to 2 degrees, so I know that's not the source of the power loss.
I think the 02 sensor is going bad, and the fuel trims are wayy off. It ran much better at idle, snap throttle etc with th 02 unplugged running in open loop.
At this point I'll need to spend some time going over all the basics, and make sure all the wiring/grounds are good, and have a look at the inputs and outputs with an oscilloscope. I have no DTCs to work with, and the datalogger traces I have when the PCM shuts down are all cut short by about 2 secs.
I guess there is a data buffer that is lost when the PCM goes down, so the log is missing the data I need to show what is going on when the shutdown occurs.......
This sucks.
Old 09-21-2010, 01:09 PM   #4
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
are you running leaded fuel? I messed up an already-older o2 sensor when I started running leaded fuel though the motor.
SYZ is offline
Old 09-21-2010, 03:16 PM   #5
tb1999
tb1999's Avatar
Fan#: 44261
50/50 mix of sunoco 100 UNleaded and 112 leaded. I didn't expect it to poison the 02 in such a short time span. Guess it doesn't take much.
Old 09-21-2010, 07:38 PM   #6
JibLxA
JibLxA's Avatar
Fan#: 65903
What I Drive: 2003 Screaming Yellow SVT EAP #841
FF Reputation: 2 JibLxA Good Standing Member
So many Miata's! You owned them all though. But that looks so fun, wish I had a car to do that. I bet once you fix the ECU problems you'll be up there near the top. When you were running good you were just passing people left and right.
'03 Screaming Yellow SVT EAP #841 Built 04/01/2003
'01 Twilight Blue Sedan (SOLD)
Hatch Nation #04
JibLxA is offline
Old 09-23-2010, 07:42 PM   #7
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,295, Level 98
Points: 28,295, Level: 98 Points: 28,295, Level: 98 Points: 28,295, Level: 98
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
i enjoyed the hell out of that video.
hope you get the gremlins figured out
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 09-23-2010, 08:15 PM   #8
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
Damn that sucks. Hope you get all the bugs worked out before the next race.
norcalfocus01 is offline
Old 09-23-2010, 08:23 PM   #9
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,723, Level 94
Points: 23,723, Level: 94 Points: 23,723, Level: 94 Points: 23,723, Level: 94
Level Up 38% Completed
Forum Activity 13%
that sucks but DAMN that thing sounds amazing...... have any exhaust videos of it?
edit: oh wait I found it........YUM :)
mikebontoft is offline
Old 09-23-2010, 09:35 PM   #10
tb1999
tb1999's Avatar
Fan#: 44261
Hey, thanks for all the compliments. I'm working on fixing the bugs, but have not found an answer to the PCM shutdown problem.
I'm working on some leads, but no answers yet. I've got to know Ken @ Cosworth a bit over the past few months, so I might see if he has any info about this considering Ford owned Cosworth for a while.
I'll see if my account on FJ still works and see if I can get some answers there. The SCT Forum will not let individuals post, I can search but not post unless you are a SCT dealer.
Tags
2010 , race , video , watkins glen
