General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
#11 | ||||
I'm working night shift or I would definitely be there!!!!!
SES #009 FR '11 FF Moderators pick Oct '11 ROTM FR '12 Carlisle Nifty Fifty Award/Best in Boost/Best 08-11/Finest Five Pick |
#12 | ||||
He'll be there in his 1000whp Camaro (still a 6-speed manual!). I think spectators are $5. I'll be running drag radials for the first time on the Focus. EDIT: the drag day was canceled. Sorry for the OT post.
2006 sonic blue zx5 GT2871r turbo.
#13 | ||||
Boost Junkie!
2. I just stuck a small breather on it. It's been doing fine, I just replace it every other oil change with a new one. That's not the best way to go about it though. The best way would be to use a catch can and run the hose from the valve cover to the catch can, and then to the intake piping somewhere before the turbo. Man, I would LOVE to get up to Mason Dixon Friday night to see Sporadic run. But the event would be over by the time I got off work and got up there. You and PSUrive should come out to our weekly meet in Glen Burnie once you get it done. We could always use a third turbo'd Focus at our meet. lol We should all get together one night for a boosted Focus track day. I've been meaning to see what time I'll run with the new, more aggressive tune and poly mounts. If you want, we could meet up one evening this week and I could show you how everything is run on my car and possibly answer anymore questions you might have.
2007 Focus ZX3 - FSW Stg 2, cams and cossie mani, stock motor, 7.74 @ 93mph (1/8th mile) w/ 1.84 60ft spinning Built motor on the engine stand! Shout out to FSWerks and Focus Rising 2012! |
#14 | ||||
i <3 my ST
My '05 2.0L had that little nipple on it but my 07 2.3L does not I thought the stock setup had the fresh air entering through the valve cover and then contaminated air exiting through the PCV valve into the intake manifold. As a result of the turbo pressure the PCV value would be forced closed forcing the contaminated air out the valve cover. Maybe I'm over thinking it. But how is Thursday after 7:30ish? It'd be sweet to take a look at your setup. Friday's event has been cancelled though.
'07 ST ; formally bewst'd '86 XR4Ti ; 2.3L Turbo, 15psi D23 Crew: #07 |
#15 | ||||
Boost Junkie!
Thursday evening is good with me. I'll be home about 5:30 so anytime after that. I'll PM you my number and you can text or call me. The other boosted Focus that comes out to our meet has the FSWerks Stg 2 on an 07 ST 2.3 Duratec but he's not on any of the forums though. I'll get in touch with him and see how he set his up.
#16 | ||||
i <3 my ST
I appreciate it man!
#17 | ||||
Fins Up!
on the pcv you can either leave the valve hooked to the IM and put a one way check valve in line and just put a small breather filter on the valve cover.
or you can take the guts out of the pcv valve and run a hose off of it and to a catch can and a hose from the valve cover to the catch can and put a breather filter on the catch can. this way no oil or oil fumes make it to the IM.
Turbo Turtle Garage facebook.com/turboturtlefabrication TurboTurtleFab@gmail.com |
#18 | ||||
FWIW I ended up running running 5/8" hose from my valve cover and PCV to under the car and behind the cross member.
Unless you have blow-by, nothing comes out except water depending on humidity. If the underside of your car gets covered with oil blowing out the hoses, time for a rebuild. Ask me how I know. :P
#20 | ||||
i <3 my ST
| Tags |
| bamf'n, custom, duratec, turbo |
| Thread Tools | |
| Display Modes | |
