How To: EASILY remove Nite Shades - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-27-2010, 08:04 PM   #21
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Might do my tail lights now since I know I can remove the stuff. Good and simple info.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 12-01-2010, 10:49 PM   #22
HxCThumbs
HxCThumbs's Avatar
Fan#: 78852
What I Drive: 2005 White ZX4
FF Reputation: 1 HxCThumbs Good Standing Member
mine came off with gas just to redo it better and it worked! :0 Thanks for the wright up! i would have used paint thinner and that would have ended up well....
I has focus
HxCThumbs is offline
Old 12-01-2010, 11:46 PM   #23
theheat
I Nom Cones
theheat's Avatar
Fan#: 59123
What I Drive: 2008 Vermillion Red S Coupe
FF Reputation: 3 theheat Good Standing Member
acetone should be fine... i use it at work and have only melted thin plastice over time (cups and what not) i was spraying my emblems black and used acetone and they were fine... as long as you wipe it off you'll prob be fine... also you could try denatured alcohol... little nicer that acetone...
but if gas works, go for it, i hate sanding!!
Team Duratec # 219
2008 Coupe S:
Born on 12/17/2007
theheat is offline
Old 12-03-2010, 04:34 PM   #24
HxCThumbs
HxCThumbs's Avatar
Fan#: 78852
im not gonna lie gas took some work. lol sanding just sounds like a bad idea.
I has focus
Old 01-23-2012, 08:50 AM   #25
fast*st
Fan#: 93319
What I Drive: 1999 F350 Dually, 03 SVT ZX3
FF Reputation: 1 fast*st Good Standing Member
I suppose you could try some oven cleaner or paint stripper, though I'd try a spot on a spare or broken light just to be sure.
fast*st is offline
Old 09-21-2014, 09:04 PM   #26
JLokiG
Fan#: 172937
What I Drive: 2009 Silver Focus SE
Points 583, Level 11
Points: 583, Level: 11 Points: 583, Level: 11 Points: 583, Level: 11
Level Up 66% Completed
FF Reputation: 1 JLokiG Good Standing Member
Read this online. --- "In an effort to fight misinformation around the web regarding how to remove VHT Nightshades, I made this guide as a resource for those who want to do it right. I traded some 04/05 tails I had that weren't in the best shape for this pair that were tinted to hell, but I knew with some elbowgrease I could make these right.
What you will need:
1. Brake Fluid
2. A shop rag
3. Rubbing Compound
4. Patience
This is a warning: If you use acetone, nail polish remover, paint remover, or aircraft paint stripper, this can damage the tail light, creating pockmarks as it eats away at the plastic.
Step One: Remove tail lights as brake fluid will damage your paint.
Step Two: Douse your shop rag in brake fluid and start rubbin it out.
Almost immediately you will start seeing results after 5-10 minutes. Total cleaning time is about 20-30 min"
JLokiG is offline
Old 09-22-2014, 12:08 AM   #27
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,177, Level 34
Points: 3,177, Level: 34 Points: 3,177, Level: 34 Points: 3,177, Level: 34
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 11%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
If your going to be rubbing shit with gasoline wear rubber gloves also dont forget to huff some of them fumes lol
qweesy is offline
Old 09-22-2014, 11:21 AM   #28
FreeFocus
SPI Not Dropped Club
FreeFocus's Avatar
Fan#: 112674
What I Drive: 2002 SPI Focus
Points 15,769, Level 80
Points: 15,769, Level: 80 Points: 15,769, Level: 80 Points: 15,769, Level: 80
Level Up 84% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 3 FreeFocus Good Standing Member
Ive used gas from the gitgo when wanting to redo my niteshade on my tails. Wouldn't use anything else, doesn't damage the tail light or anything. Little bit of elbow grease is all you need. Glad to see someone else does the same.
Originally Posted by A1_Fares View Post
2000cc Naturally Aspirated Split Port Injected Single Overhead Cam Hemispherical Combustion Engine.
Originally Posted by Xx09xX View Post
if i ever get the ability to defecate currency
Focus TakeOver#001 -- SR#289
FreeFocus is online now
Old 09-26-2014, 01:02 PM   #29
JLokiG
Fan#: 172937
So you all know... If you're like me and prep didn't work on your fake plastic trim and you wanted dark chrome... Make sure to do a light wet sand with high grit... Then apply adhesive promoter... Then spray vht. I ended up not doing this and it came out bubbly.
After I ended up removing the Ford badge blue color on purpose :) I like the chrome badge. Next is the inside lettering to be painted.
JLokiG is offline
Old 10-07-2014, 11:23 PM   #30
Pist0n
Pist0n's Avatar
Fan#: 175305
What I Drive: 2007 Silver ZX4
Points 174, Level 3
Points: 174, Level: 3 Points: 174, Level: 3 Points: 174, Level: 3
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 Pist0n Good Standing Member
Ive always used Carb Choke and Throttle Body cleaner. Comes with one of those little straws to spray through, and it literally starts coming off with each spray.
It pretty much slops right off the lights. Its kinda gross
Dude, I almost had you! -Paul Walker
-Chicagoland Focus Crew-
K&N Typhoon CAI | 8000K HID Headlights | Sony GS600BT Bluetooth Audio System | Kenwood 5x7 Ovals | DynoMat
Pist0n is offline
