Head Gasket Leak - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-15-2010, 07:37 PM   #11
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
I havent had to retorque any myself, but theres always the chance it could need doing.
You may have stretched the bolts or the threads on the block..... there are several things that could cause it.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 09-16-2010, 12:28 AM   #12
bradshsi
bradshsi's Avatar
Fan#: 58770
What I Drive: 2002 Sonic Blue Turbocharged SVT
Points 342, Level 6
Points: 342, Level: 6 Points: 342, Level: 6 Points: 342, Level: 6
Level Up 84% Completed
FF Reputation: 6 bradshsi Good Standing Member
Buy-Sell-Trade Rating: (4)
In the interests of full disclosure, I'd point out I have no personal experience of how much the Cometic gasket will relax on the Zetec.
However hopefully its just relaxation you are seeing. I'd retorque to the ARP spec with the engine cold and see if that fixes your leak.
I assume you did you lubricate the threads on the studs/nuts when you fitted them ? The choice of lubricant is really important, as is the thread quality and surface finish.
Other reasons for leakage could be:
Defective gasket
Cracked block/head
Gasket fitted incorrectly or out of position
Remachined surfaces uneven or having excess runout (i.e not flat enough)
Remachined surfaces too rough or too smooth (gaskets are happiest with a specific roughness, typically in the range 125 to 250 micro inch)
Sona si latine loqueris
bradshsi is offline
Old 09-16-2010, 08:39 AM   #13
cbman
Fan#: 52592
What I Drive: 1999, Black, Zetec Cougar
Points 320, Level 6
Points: 320, Level: 6 Points: 320, Level: 6 Points: 320, Level: 6
Level Up 40% Completed
FF Reputation: 2 cbman Good Standing Member
I did use the ARP lube when it was assembled, but I don't have any now. So, I was thinking of just using motor oil. Is using the moly lube that big of a deal?
I took the torque wrench to the stud nuts last night and all but three of the nuts moved at 60ft-lb. Although the ARP person said to back them out 1/4 - 1/2 a turn, and then re-torque them. So, once I figure out what lube I'm going to use I will do the re-torquing.
cbman is offline
Old 09-16-2010, 03:08 PM   #14
bradshsi
bradshsi's Avatar
Fan#: 58770
Points 342, Level 6
I looked at the ARP website and they offer something called ARP Ultra-Torque Fastener Assembly Lubricant™
http://arp-bolts.com/UT_detail.pdf
Of course their brochure makes it look super good, but the graphs they provide do make a good point. Different lubricants will yield different preloads for the same torque.
Moly is normally a decent choice, although there are others based on graphite, copper or PTFE that can work well. I'm not sure what the ARP Ultra lubricant is based on but my guess is PTFE.
Personally I'd stick with the lube ARP provided to you.
bradshsi is offline
Old 09-14-2011, 05:22 PM   #15
cbman
Fan#: 52592
Points 320, Level 6
Well, its been around a year since I re-torqued my ARP studs using the ARP Lube, and my coolant leak is back. So, the plus side is that the re-torque fixed the leak for one year. I've been running 13-18 psi boost for about 1,000 miles in that time.
Its very interesting that I don't have any oil in my coolant reservoir and I don't have any coolant in my oil. The leak occurs even after the engine is off. After having the starting issues again I decided to pull the plugs after the car sat for a day and there was a "pool" of coolant in cylinders 2 and 4. Apparently my coolant system is getting pressurized and leaking into the cylinders after the engine is turned off. Since water is non-compressible I would imagine there could be some catastrophic issues if I have been starting my car when there is coolant in the cylinders.
Here is a list of things that I wonder if they could be part of the issue:
1. I have a cometic head gasket that is 0.014" thicker than stock. Could that require a higher head stud torque.
2. I can hear coolant boiling in the turbo after the engine is off.
3. My large log manifold seems to put out a lot of heat.
If anyone has any advise please let me know. At this point I imagine I'm going to have to pull the head off.
cbman is offline
Old 09-14-2011, 05:55 PM   #16
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
FF Reputation: 2 bespurcell Good Standing Member
I have no personal experience with cometic but it seems like several people have had probs with that gasket.
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
Old 09-14-2011, 06:27 PM   #17
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
I would pull it apart check the deck and head for flatness. If all good throw a new gasket on and torque to the right specs the first time.
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 09-14-2011, 06:54 PM   #18
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Check for a clogged radiator or stuck thermostat as well. While the engine running are there any hoses inflating or getting sucked (before and after the rad)?
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 09-14-2011, 10:12 PM   #19
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,496, Level 100
Points: 52,496, Level: 100 Points: 52,496, Level: 100 Points: 52,496, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
If you have a turbo on this car I would loook at the tune , fuel and timing
Head gaskets dont last a year then blow , if you had a head or block issue or cometic issue it wouldnt of lasted a year
Whats you air fuel under boost , what is your knock sensor doing , how much total timing is the engine seeing ,
Thats where I would start
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 09-14-2011, 11:05 PM   #20
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
I just went through the same exact thing you did on my engine just a month ago. Use the ARP assembly lube. Get a stock Ford head gasket. My cometic did the same thing on #4 . Pressurized the coolant tank. Once you get to the torque specified. Let the engine set for a little while and retorque again .I went over mine 3 times at 65ftlbs. (IIRC) and each time it went just a fraction more until it clicked. Seems it continues to crush as soon as pressure is applied. And there were 3 steps to get to final torque . Mine has been on for awhile now, and regularly gets flogged to 22 -23 psi. OH and the studs are installed hand tight into the block. Also if you have used your torque wrench for a while, get it calibrated. You wouldnt believe how far off they can be. I had mine checked and it was good.
iroc34 is offline
