ford focus overheat - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-05-2010, 12:22 PM   #1
merkur
Fan#: 78072
What I Drive: 2002 white zx5
FF Reputation: 1 merkur Good Standing Member
ford focus overheat
So I think we found the overheating problem with my 2002 ford focus.
Removed the spark plugs, seemed fine. did a pressure test on the coolig system and found the plastic pipe running along the top of the radiator had cracked. Is this a common problem? Also, is this part only available through Ford and what is cost of the part?? haven't had a chance to check yet. Just wanted to say thanks to the guy in Memphis TN -you were right, apparently not a head gasket issue, thank god
Jeff
merkur is offline
Old 09-05-2010, 12:26 PM   #2
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
Points 1,641, Level 23
Points: 1,641, Level: 23 Points: 1,641, Level: 23 Points: 1,641, Level: 23
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
It's a very common problem. That poor little plastic pipe can only take so many years of heat cycling. I'm not sure if you can get that part at the auto parts store but I think the dealer price is very reasonable. Were you visibly leaking coolant?
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
Old 09-05-2010, 01:39 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
Yeah, he was spraying it all over the engine compartment, filling up the spark plug tubes, etc.
I'm not even sure what that is myself, but I don't have a Zetec. Hopefully someone else will know. Your problem with the parts guy is that he doesn't know what to call that part. They don't have exploded views like dealers do.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 09-05-2010, 01:44 PM   #4
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Where does that pipe connect to? Both ends please. I'm searching RockAuto, but I'm seeing a lot of different hoses, and no special names for any except the coolant bypass hose. I don't think that's it though as it is for bypassing the heater core if I understand it correctly.
Be eclectic.
Old 09-05-2010, 02:13 PM   #5
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 45,161, Level 100
Points: 45,161, Level: 100 Points: 45,161, Level: 100 Points: 45,161, Level: 100
Level Up 0% Completed
FF Reputation: 11 lhc_focus Great Standing Member
Corrections made after looking at it this morning.
It's a hard plastic tube about 18" long. On one end it has 2 connections one from the t-state and the other is connected to the firewall. The piece then widens out to the other end which dumps into the lower radiator hose. Mounted above the radiator. If your not gentle removing the hoses it will break. Mine is still good after 7 years and 200k.
lhc_focus is offline
Old 09-05-2010, 02:25 PM   #6
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Ok, hoses that go from the thermostat to the overflow are available at Rock Auto- fairly cheap too, but I'd get it locally because the shipping will likely cost you as much as the difference. You just need to find a better parts attendant who's willing to take the time to satisfy you.
Be eclectic.
Old 09-05-2010, 03:41 PM   #7
lhc_focus
Fan#: 42464
Looks like OEM to me.
Old 09-05-2010, 04:44 PM   #8
merkur
Fan#: 78072
Yeah
U might say it overheated -went to make a turn and coolant blowing out the back and coolant all over the engine compartment -car overheating. We thought headgasket because apparently coming out exhaust but I think it just leaked onto exhaust manifold. What a mess -try to get that pipe this week. other than that, car has been great, oil changes only!!
merkur is offline
Old 09-05-2010, 05:18 PM   #9
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Is this the problem part?
"Water Inlet Tube", part # YS4Z-8290-BA about $30 from Ford
BC_ZX3 is offline
Old 09-05-2010, 05:46 PM   #10
Trime2X1
Fan#: 77607
What I Drive: 2001 White ZX3
FF Reputation: 1 Trime2X1 Good Standing Member
I just ordered this part from PartsGeek this past week. They call this tube, "HVAC Heater Hose Outlet Tube", Part#: 902-206 Same part as pictured above by BC_ZX3.
Trime2X1 is offline
