Want launch tips for BFG drag radials - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 08-29-2010, 10:13 AM   #1
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,970, Level 74
Points: 12,970, Level: 74 Points: 12,970, Level: 74 Points: 12,970, Level: 74
Level Up 30% Completed
Forum Activity 3%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Just bought a set of 225/50-15 BFG drag radials.
I know ALL drag radials, DOT slicks, and slicks launch differently and prefer a different heat/psi combo.
I've never run a drag radial, only ET Streets and that was a RWD car. (good burnout, low psi, and high RPM launch).
Who has run the BFG DRs and what do they like to hook well?
My car should put down appx 240 wtq if that helps.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 08-29-2010, 11:37 AM   #2
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
I had thos exact same DR and i ran them at 10psi and launched at about 4500 sometimes more depending on the track. do a good burnout with them they need it
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 08-29-2010, 12:33 PM   #3
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
Thanks that's what I needed to know!
Did you slip the clutch any or side-step it?
What kind of 60' times did you get with them?
Old 08-29-2010, 03:07 PM   #4
Roushturboedzx3
I Fab Too Much
Fan#: 42814
Deff slip the clutch a little. You don't want to get it to hot and have it slip. You will have to play with it a little. But slight slip of the clutch
Old 08-29-2010, 03:07 PM   #5
Roushturboedzx3
I Fab Too Much
Fan#: 42814
Also try 13psi tire press first
Old 08-29-2010, 05:57 PM   #6
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 15,038, Level 79
Points: 15,038, Level: 79 Points: 15,038, Level: 79 Points: 15,038, Level: 79
Level Up 38% Completed
Forum Activity 4%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
these are the G forces i guess? ive had best results between 10-12 psi. if we are thinking about the same tire then you do not need to smoke the crap out of them. causes grease pits to build up on the surface of the tire and will make them spin over easier than if they were just cold. a brief hazing is what BFG told me they needed when i called. so basically pull into the water box, 2nd gear burnout with the e-brake up. as soon as you start the burnout let the brake out and spin till they start to hook. i side stepped on a 100 shot out of the hole with pretty good results with the 2 step at 4200 and the nitrous coming on at 4600. i think my best 60ft was 1.7 before i got too aggressive and stripped the bolts out of the transmission case instead of breaking the tranny mount bracket so you definitely want to slip the clutch on the way out. dumping like a dummy is a bad idea lol
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 08-29-2010, 07:52 PM   #7
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
Haha yeah I was wondering what would go first with side-stepping. :)
Yes I have the g-force.
1.7 is fantastic on drag radials! I was hoping for a 1.8x at best, running my solid motor mounts and the Exedy stage 2 clutch.
Thank you for the detailed burnout too.
I hadn't even tried a 2nd gear burnout with the Focus... I wasn't sure it had the torque out of boost!
(I would do 3rd gear burnouts in the 'Stang with a 4.56 gear, but that's very different)
Old 08-29-2010, 10:17 PM   #8
focusmaniaczx3
Fan#: 55157
Forum Activity 4%
side stepping will get the best launch hands down but you risk breaking stuff. my car has always been a little weird with 60ft times. it seems to be faster out of the hole than it should be. i netted a 1.9 on street tires a few times. 18x7.5 heavy ass rims rolling on some bottom of the line corsa something or another street tires. those tires were the best ive ever had. better than kumho or dare i even say pirelli. and they were cheap! if i can find someone locally who sells them those are going back on and probably will be the only tires i run from now on. anyhow back on topic.
side stepping is best if you want the best time but you risk breaking axles, tranny mounts, the bracket the mount bolts to, stripping bolts from the transmission case, and breaking the transmission case itself. the last is only in an extreme case where all the other things have been beefed up.
if you want to play it safe then slip the clutch slightly on takeoff. when you are staged and waiting on the tree go ahead and get into the throttle, if you have 2 step then use it. pull the ebrake and wait. when the first yellow light comes on and they start coming down start easing out the clutch to the point just before you would start to drag the rear tires. on the last yellow release the e-brake and continue to slowly let out the clutch until you are on your way. if you have 2 step you want your foot on the floor from the start. this is the safest way to launch and even though it doesnt net the lowest 60ft it still does damn good. best i could manage was a 1.83 on this method. dont start slipping the clutch too soon or you will overheat it. this method does have its drawbacks. if you over heat the clutch too far the clutch CAN come apart. be careful and happy hunting on those low 60ft times!
Old 08-31-2010, 08:47 AM   #9
chris-13
chris-13's Avatar
Fan#: 20080
What I Drive: 2004 White Focus ZX3 2.3L
Points 5,635, Level 48
Points: 5,635, Level: 48 Points: 5,635, Level: 48 Points: 5,635, Level: 48
Level Up 43% Completed
FF Reputation: 1 chris-13 Good Standing Member
Buy-Sell-Trade Rating: (26)
I usually have 20 psi in them and get 2.1 60' times, but I am NA, definately do a good burnout to clean them and heat them up to stick to the pavement
Good Luck
CTZX3 from Focaljet.com
2007 Mazda 3i Touring
2004 White ZX3 2.3L
Pics & Videos --> http://www.flickr.com/photos/cgenus1/
chris-13 is offline
Old 08-31-2010, 08:54 AM   #10
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 3%
Good Luck
2.1 is not good for drag radials, no offense.
Drop your pressure to at least 15psi and try that.
I've seen your other threads and know your car runs well and you can drive it well too, so I just don't think you've found the sweet spot for your drag radials.
If I can't pull a 1.85 60' after practice then I'll just sell them.
