Harmonic Balancer Bolt Stuck - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-26-2010, 11:29 AM   #21
sailor
Crankshaft
sailor's Avatar
Fan#: 57268
Points 11,770, Level 71
Points: 11,770, Level: 71 Points: 11,770, Level: 71 Points: 11,770, Level: 71
Level Up 30% Completed
Forum Activity 99%
Posted via FF Mobiledisciplerocks - if you`ve got time to burn, check out the thread mentioned earlier when doc spent weeks in his driveway on an issue that started out this way..... First post just asked if an electric impact might do the job, ended up with a LONG project Grumpy helped lead him through...
sailor is online now
Old 10-04-2012, 09:12 AM   #22
dapperzapper
Fan#: 104507
What I Drive: 2002 grey Focus SE
FF Reputation: 1 dapperzapper Good Standing Member
stuck harmonic balancer bolt
Thank God I just got this dreaded bolt off!!!
All it took was a long pry bar, a 3/4" socket, a hydraulic car jack and some wood jammed down through the now-empty cylinders to stop the crank shaft from turning. Yes this has turned into a total rebuild since a valve seat came loose and ruined the pistons.
dapperzapper is offline
Old 05-24-2014, 10:14 AM   #23
DangerRanger
Fan#: 165410
What I Drive: 2002 Ford Focus zx3
FF Reputation: 1 DangerRanger Good Standing Member
Balancer Bolt
Last time I had to deal with a balancer bolt it was by far the hardest part of the job. I found that the main part of it being so hard to untorque is that it has such a huge head on it which multiplies the friction. The threads are generally not tight it is the friction from the wide area of the head. If you were to grind the head off the bolt part would probably then screw right out with your fingers. I also made a special tool to hold the balancer . I was wondering if heating it a little would make it expand away from the surface or make it worse. I have to go do this again in a little bit and I hope it goes okay.
DangerRanger is offline
Old 05-24-2014, 02:46 PM   #24
DangerRanger
Fan#: 165410
Balancer Bolt Part 2
So I ccould not find the custom tool I made to hold the crank balancer the last time I did this job so I made another. Just a bar set up so I can put some 1/4 inch pins into the balancing holes drilled in the balancer to hold it good so I can torque it with a wrench and long pipe. Wouldn't you know it, after all that it only took about 40 - 50 lbs of torque to break it loose. Last time I did this it took about 200 lbs
Old 05-24-2014, 03:52 PM   #25
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 11,965, Level 71
Points: 11,965, Level: 71 Points: 11,965, Level: 71 Points: 11,965, Level: 71
Level Up 79% Completed
Forum Activity 99%
FF Reputation: 65 felixthecat Excellent Standing Member
Back to the top for Chris is rpm.
felixthecat is offline
Old 05-25-2014, 12:56 AM   #26
DangerRanger
Fan#: 165410
Balancer Holder Tool
Here's the second balancer holder tool I made to hold the balancer by the holes it has in it
