Duratec manifold spotters guide. - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 02-21-2014, 05:31 PM   #31
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Forum Activity 99%
Tx - it helps others to hear from someone who's done it!
Seems to me that some got the impression just removing the flaps would help with low speed power & economy.
Feedback that it doesn't helps avoid the mistake of doing it for that reason.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 10-20-2014, 06:15 PM   #32
Red_Sonja
Red_Sonja's Avatar
Fan#: 53953
What I Drive: 2006 ZX4; 03 Infra-Red ZX3 SVT, RIP
Points 1,143, Level 18
Points: 1,143, Level: 18 Points: 1,143, Level: 18 Points: 1,143, Level: 18
Level Up 44% Completed
FF Reputation: 1 Red_Sonja Good Standing Member
Sorry for the resurrected thread... but i just purchased a D23 focus and wonder why the Escape D23 can run OK without these tumbler flaps? I don't think the Ranger D23 has them either, not sure about the D25. Seems to me that mid to high rpm they are a real restriction.
Red_Sonja is online now
Old 10-21-2014, 04:35 AM   #33
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
FF Reputation: 12 BowerR64 Great Standing Member
I thought the larger engine has a different intake that changes runner lengths? Read through more posts on this intake to find more info about it. The cheaper 2.0 engine they try to make up for the single length intake with the flaps. The 23 intake is a way better design but its a more advanced system and im sure more cost.
One length helps the power in lower RPMs and the other in the upper RPMs.
Or maybe they remapped the way the fuel is delivered?
I think Tom could of fixed my issue in the lower RPMs but i had a second issue deleting the PCV valve caused an oil smell inside my cabin and i couldnt stand it so i ditched everything and went back to the stock one.
If i could of fixed the oil smell in the car i may have stuck with the flapless intake but i was worried it wasnt good for my health so i removed it.
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 10-21-2014, 09:33 AM   #34
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,944, Level 74
Points: 12,944, Level: 74 Points: 12,944, Level: 74 Points: 12,944, Level: 74
Level Up 24% Completed
Forum Activity 99%
Talking
The escape 23 is the only 23 that doesn't have imrc (tumble flaps) for some reason. The ranger 23 uses a 20 head w/ the 20 single runner i/m as the other 20's. If you want to see how your 23 runs w/ the flaps open, remove the vacuum line coming off the i/m feeding the passenger side solenoid & plug it off. You'll see the actuator linkage behind the t/b stay in the upright position, meaning the the flaps are open. When you do this the cel will illuminate. Once you do that, see how it runs & what you think. You'll notice it at off idle. The cel will go off when you reconnect the vacuum line.
felixthecat is online now
Old 10-21-2014, 08:50 PM   #35
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
When mine were intermittently malfunctioning (bad vacuum hose) the effect I noticed was a definite loss of power at very low throttle openings.
Red_Sonja - to relate this to your Escape question, I might guess that when used in that larger vehicle the engine isn't operating in that same range often (if at all). Combine a larger vehicle with an automatic transmission & I doubt it spends much time in the low rpm range I often use with a manual trans in a Focus. Automatic would let it rev higher to get similar acceleration in the heavier vehicle.
"Rubber Side Down"
Old 10-22-2014, 03:21 AM   #36
BowerR64
BowerR64's Avatar
Fan#: 78699
My car ran very bad since the day i got it shifting way early ad as often as it could i hated it. Sure it helped fuel economy but it had little to no power ever.
Finally Tom tweaked the transmission and now its better then its ever been. The weird part is my fuel economy got better. All the mods i did i think change the power curve of my engine and the shift points of the stock transmission reduced my economy and power. Once Tom moved the shift points now it seems to be shifting more in its power curve and it helped everything.
BowerR64 is offline
Old 10-22-2014, 07:37 AM   #37
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
It helps to have the shifts right to begin with. Comparing a mtx to atx w/ intake mods your going to have different results.
Old 10-22-2014, 09:13 AM   #38
BowerR64
BowerR64's Avatar
Fan#: 78699
Well they were when it was stock but i slowly upgraded everything and the last few tunes were with the transmission and that IMO made the biggest gain so far.
BowerR64 is offline
Old 10-22-2014, 10:39 AM   #39
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
Yea, it does help to have the shifts sorted out 1st.
Old 10-22-2014, 01:21 PM   #40
Red_Sonja
Red_Sonja's Avatar
Fan#: 53953
So does all this mean that the Cosworth IM with no imrc circuit and just short (high speed) runners will make very poor power below say 5000rpm? I was looking for a set but not if they are for basically race mode only.
Tags
design , duratec , identify , intake manifold , specs
