Drive shaft axle hub nut 173, 233 or 290 Ft-lbs ? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-21-2010, 01:15 AM   #1
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
I was planning on reworking the front end with new:
- Brakes
- Struts
- Driveshafts
- Ball Joints/Control Arm
- Bushings
- Tie Rods, Inner/Outer
But will probably just do the brakes and Struts and a few other smaller things until I get more info on the Drive axle nut.
Concerning the Driveaxle/hub nut or Driveshaft/hub retaining nut as Chilton calls it - I've read a few threads here where the nut was stripped or the axle was sheared. Could this be the problem below?
Torque Spec's
Chiltons Section 8 'DRIVEAXLES'
Models through 2001 173 Ft-lbs
2002 and later models 233 Ft-lbs
Chiltons Section 10 'SUSPENSION AND STEERING'
233 Ft-lbs
Ford Tech Service Publication for 2000
233 Ft-lbs
Advance Auto
GSP Brand 290 Ft-lbs
I couldn't find anything on the Nut in FF's 'General Specs'.
Can you put 290 Ft-lbs on the front axle hub nut without damaging the hub/bearing? Is it different materials in the axle that call for different torque values?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 08-21-2010, 02:11 AM   #2
vaboom123
vaboom123's Avatar
Fan#: 73667
What I Drive: 2003 Euro Highlighter
Points 1,285, Level 19
Points: 1,285, Level: 19 Points: 1,285, Level: 19 Points: 1,285, Level: 19
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 1 vaboom123 Good Standing Member
I've been using the 233 ft./lbs. for the axle nuts. If I recall that's what they list on mitchellondemand. When I purchased my car someone stripped the threads on the left axle. I've had the axles in and out a few times without any issues. Hope that helps.
vaboom123 is offline
Old 08-21-2010, 09:29 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
I don't think you have to worry about damaging bearings by over torquing on FWD axles. It's not like with the old RWD designs with the bearings that fell out whenever you removed the brakes.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-21-2010, 03:21 PM   #4
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
Points 1,703, Level 24
Points: 1,703, Level: 24 Points: 1,703, Level: 24 Points: 1,703, Level: 24
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
I've replaced both front bearings before and both times I used a 200ft-lb torque wrench. Just tightened till it clicked and never had a problem since. Anything over 150ft-lb is probably more than sufficient.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
