For Sale: 2000 Ford Focus ZX3 (Road Race or Auto-X) - Race ready! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-17-2010, 07:28 AM   #1
dhardison
Fan#: 50880
What I Drive: '06 SS Trailblazer (LS2 pwrd)
FF Reputation: 2 dhardison Good Standing Member
Buy-Sell-Trade Rating: (4)
Item Description: 2000 Ford Focus ZX3 - Race ready!
EVERYTHING you need to go racing!
Available as a "RACE READY package" or "RACE READY plus SPARES package" or "RACE READY plus MIX/MATCH SPARES".
- Current 2010 SCCA log book - car is legal for ITA/STL/STU (could also run NASA SpecFocus or PT).
- Car weighs 2350lbs with 3/4 tank of fuel, W/O driver (GCR minimum weight = 2400lbs).
- VERY EASY on tires & brakes. Car is VERY predictable, forgiving and well sorted.
- AMB TRANSPONDER INCLUDED!
- Car is solid, rust-free and looks great!
- In '08 & '09 the car was raced in ITE with a different engine/supercharger combination. Engine currently in the car is a fresh "IT" build and is naturally aspirated (obviously).
RACE READY Package
*ENGINE*
2.0L Zetec 16v DOHC (2005 Ford crate engine w/recent refresh)
9.6:1 compression
Cylinder head has been CNC port-matched per IT specs
OEM camshafts & cam gears with ARP hardware
NEW OEM front & rear main seals
NEW OEM oil pump
NEW OEM Zetec head gasket
NEW OEM water pump
NEW Gates racing timing belt
NEW Gates timing belt adjuster and billet idler pulley
NEW Gates accessory belt tensioner
NEW Goodyear Gatorback accessory belt
*TRANSMISSION/DRIVETRAIN*
MTX-75 5-speed (total rebuild early 2009 w/recent refresh)
Quaife differential (new with 2009 rebuild)
ACT clutch/pressure plate (new with 2009 rebuild)
OEM flywheel (new with 2009 rebuild)
B&M shifter with custom shifter riser brackets (stock shifter included for SCCA legality)
NEW OEM axle/output seals
NEW OEM clutch slave cylinder & input shaft seal
NEW OEM drivers & passenger front hubs & bearings
NEW drivers & passenger CV axles
NEW shifter cables
*EXHAUST*
SVT long tube header
NEW 2.5" stainless SVT off-road pipe w/wide-band and o2 bungs
2.5" exhaust exiting in the stock location
*FUEL*
NEW OEM SVT fuel pump
NEW OEM fuel injectors
NEW OEM fuel filter
NEW OEM fuel rail pressure sensor
*ELECTRICAL*
NEW OEM crank sensor
AMB transponder - hard-wired
SCT XCAL-II Flasher/Tuner
Ford Racing spark plug wires
NEW Motorcraft double-plantinum spark plugs
Stock replacement battery (1 year old)
*COOLING*
Fluidyne aluminum racing radiator
Samco silicone coolant hoses
NEW t-stat, t-stat housing and seals
Factory dual electric fans
*SUSPENSION*
Front - KONI race valved single adjustable dampers, shortened 1" with Ground Control coilover conversion
Rear - KONI race valved single adjustable dampers, shortened 1"
Front Springs - Eibach coilover race springs - 2.5" x 6" x 500lb
Rear Springs - Eibach coilover race springs - 2.5" x 6" x 700lb
Front Sway - 17mm (ZX3 stock bar = 19mm)
Rear Sway - Eibach 25mm, w/poly bushings
NEW front sway bar end links
FocusSport lower front stress bar
Progress front caster/camber adjustment kit
OEM front control arms
OEM rear lower control arms - with poly bushings
OEM rear upper control arms - with poly bushings
OEM rear upper dog bones - with poly bushings
Front hubs & rear drums are drilled for 9/16" extended race studs
*BRAKES*
OEM front calipers with brass slider bushing upgrade
OEM rear drums
NEW front rotors (2 sessions)
NEW Carbotech XP10 front pads (2 sessions)
Russell braided stainless steel brake lines (front & rear)
Brake ducts/hoses installed for front bearing/brake cooling
*TIRES/WHEELS*
(4) Toyo RA1 (205/50/15) mounted/balanced on Rota Slipstream wheels (13lbs-black) (wheels like new, tires used)
*SAFETY/INTERIOR*
SCCA-certified 8-point custom rollcage
MOMO Start FIA racing seat
Sparo 6-point belts (good through 2013)
Removable steering wheel
GForce left-side mesh window net
Safety Solutions right-side net
Aluminum pedal covers for easier heel-toe
Master cut-off switch (kills battery and alternator)
Hand-held fire extinguisher
Wink-type rear view mirror
Ford Racing oil pressure gauge
AEM AFR gauge (wide-band)
Adjustable shift light
*BODY/EXTERIOR*
All stock panels (silver - excellent shape)
Ford Racing vinyl graphics
Front bumper cover has a few scrapes/indentions
Rear bumper cover - stock, excellent shape
*Misc*
COMPLETE set of FACTORY Ford Focus manuals (like new)
Haynes Ford Focus manual (like new)
SPARES Package
- All parts listed as 'like new' and/or 'used' are good/useable parts, no junk
- Remaining spares will be sold/parted out ONLY after car sells
*SPARES - Tires/Wheels*
(4) BRAND NEW, SHAVED (4/32") Toyo RA1s (205/50/15) mounted/balanced on factory aluminum wheels (15x6.5)
(4) Hoosier DOT Radial WETS (205/50/15) mounted/balanced on OEM aluminum wheels (2 heat cycles - like new)
(4) Avon Tech RA DOT radial (205/50/15) mounted/balanced on OEM aluminum wheels (2 heat cycles - like new)
*SPARES - Aero*
(1) Custom aluminum front splitter - attached to front bumper cover (works GREAT but easily removed - like new)
(1) ARP aluminum rear wing with two sizes of CF end plates and custom CF rear stress bars (works great, but all easily removed - like new)
*SPARES - Exterior*
(1) Rear bumper cover (grey - like new)
(1) Front bumper cover (silver - used)
(1) Rear bumper cover (silver - used)
(1) Front fender - driver - (used)
*SPARES - Brakes*
(1) Hawk Blue racing brake pads - front (like new)
(1) Porterfield R4 racing brake pads- front (like new)
(1) Hawk Black brake pads - front (used)
(1) Hawk HPS brake pads - front (used)
(1) Rear brake shoes - Duralast (new)
(2) Front brake rotors - slotted (like new)
(1) Front brake pads - stock (used)
(1) Rear brake shoes - stock (used)
(4) Front brake rotors (used)
(2) Front brake calipers - stock (used)
(2) Rear complete brake assemblies - drums/bearings/pads/spindles/backing plates (used)
*SPARES - Suspension*
(2) Eibach race spring - 2.5" x 6" x 600lb (like new)
(2) Hypercoil race spring - 2.5" x 5.5" x 425lb (new)
(2) Hypercoil race spring - 2.5" x 5.5" x 300lb (new)
(1) Front spindle - driver - w/bearing & hub (like new)
(1) Front spindle - passenger - w/bearing & hub (like new)
(1) Koni yellow single adjustable strut (like new)
(1) Eibach rear sway bar - 25mm w/poly bushings (like new)
(1) Front sway bar - 19mm - stock (used)
(2) Adjustable front sway bar end links - custom (used)
(1) Rear shock tower stress bar - custom aluminum - 22mm - single adjustable (like new)
(2) Inner tie rods - front (new)
(2) Outer tie rod ends - front (new)
(1) Lower control arm - drivers front (new)
(1) Front spindle - driver- w/bearing (used)
(1) Front spindle - passenger - w/bearing (used)
(1) Tie rod end - passenger outer (used)
(4) Rear spindles (used)
(1) Lower control arm - rear (used)
(2) Front struts w/springs installed - factory (used)
(2) Rear springs and shocks - factory (used)
(1) Front sway bar - factory (used)
(1) Rear sway bar - factory (used)
Misc. axle nuts & lug studs/nuts
Misc. suspension fasteners
*SPARES - Engine*
(2) Accessory belt idler pulley (new)
(1) Engine gasket set - partial (new)
(1) Cam/Timing alignment kit (like new)
(1) Timing belt tensioner (like new)
(1) Timing belt idler (like new)
(2) Timing belt (like new)
(2) Accessory belt tensioner (like new)
(1) T-stat housing w/tstat (like new)
(2) Accessory belt idler pulley (used)
(2) Water pump (used)
(1) PCV valve (used)
(1) Radiator - factory (used)
*SPARES - Transmission/Drivetrain*
(2) Front wheel bearings - Timken (new)
(1) Front hub - Timken (like new)
(1) Clutch slave cylinder (like new)
(1) Half-shaft - driver (used)
(1) Half-shaft - passenger (used)
*SPARES - Fuel/Electrical*
(1) OEM crank sensor (used)
(1) OEM fuel rail pressure sensor (used)
(1) Ignition coil (new)
(1) Mass air flow sensor - MAF - (new)
(1) Spark plug wire set (new)
(1) Venom fuel pump (like new)
(8) Fuel injectors - Ford - stock - (used)
(1) Factory fuel rail w/fuel pressure gauge - (like new)
RACE READY package only - $4750 OBO.
or
RACE READY + FULL SPARES package - $5500 OBO.
or
RACE READY + MIX/MATCH SPARES - Make offer
Limited distance enclosed delivery available for the right price (pre-paid)
PICS:
On Track:
http://www.danhardison.com/focus/4sale/1.JPG
http://www.danhardison.com/focus/4sale/2.JPG
http://www.danhardison.com/focus/4sale/3.JPG
http://www.danhardison.com/focus/4sale/4.JPG
http://www.danhardison.com/focus/4sale/5.JPG
http://www.danhardison.com/focus/4sale/Scan1-a.JPG
http://www.danhardison.com/focus/4sale/Scan2-a.JPG
ITA (current configuration):
http://www.danhardison.com/focus/4sale/new/DSC04638.JPG
http://www.danhardison.com/focus/4sale/new/DSC04639.JPG
http://www.danhardison.com/focus/4sale/new/DSC04640.JPG
http://www.danhardison.com/focus/4sale/new/DSC04641.JPG
(w/splitter & wing - illegal for ITA):
http://www.danhardison.com/focus/4sale/new/DSC04611.JPG
http://www.danhardison.com/focus/4sale/new/DSC04612.JPG
http://www.danhardison.com/focus/4sale/new/DSC04613.JPG
http://www.danhardison.com/focus/4sale/new/DSC04614.JPG
http://www.danhardison.com/focus/4sale/new/DSC04615.JPG
http://www.danhardison.com/focus/4sale/new/DSC04616.JPG
http://www.danhardison.com/focus/4sale/new/DSC04617.JPG
http://www.danhardison.com/focus/4sale/new/DSC04618.JPG
http://www.danhardison.com/focus/4sale/new/DSC04619.JPG
http://www.danhardison.com/focus/4sale/new/DSC04621.JPG
http://www.danhardison.com/focus/4sale/new/DSC04622.JPG
http://www.danhardison.com/focus/4sale/new/DSC04623.JPG
INTERIOR
http://www.danhardison.com/focus/4sale/new/DSC04600.JPG
http://www.danhardison.com/focus/4sale/new/DSC04601.JPG
http://www.danhardison.com/focus/4sale/new/DSC04602.JPG
http://www.danhardison.com/focus/4sale/new/DSC04603.JPG
http://www.danhardison.com/focus/4sale/new/DSC04604.JPG
http://www.danhardison.com/focus/4sale/new/DSC04605.JPG
http://www.danhardison.com/focus/4sale/new/DSC04606.JPG
http://www.danhardison.com/focus/4sale/new/DSC04607.JPG
http://www.danhardison.com/focus/4sale/new/DSC04608.JPG
http://www.danhardison.com/focus/4sale/new/DSC04609.JPG
http://www.danhardison.com/focus/4sale/new/DSC04610.JPG
http://www.danhardison.com/focus/4sale/new/DSC04624.JPG
http://www.danhardison.com/focus/4sale/new/DSC04625.JPG
http://www.danhardison.com/focus/4sale/new/DSC04627.JPG
http://www.danhardison.com/focus/4sale/new/DSC04628.JPG
http://www.danhardison.com/focus/4sale/new/DSC04629.JPG
MISC
http://www.danhardison.com/focus/4sale/new/DSC04630.JPG
http://www.danhardison.com/focus/4sale/new/DSC04642.JPG
http://www.danhardison.com/focus/4sale/new/DSC04643.JPG
http://www.danhardison.com/focus/4sale/new/DSC04644.JPG
http://www.danhardison.com/focus/4sale/new/DSC04645.JPG
dhardison is offline
    Quick reply to this message
Old 08-20-2010, 01:36 PM   #2
dhardison
Fan#: 50880
bump - This is a great way to go racing for minimal dollars!
Old 08-20-2010, 04:43 PM   #3
LongDucDong
LongDucDong's Avatar
Fan#: 59052
What I Drive: 2003 SVTF 3 door
Points 9,500, Level 65
Points: 9,500, Level: 65 Points: 9,500, Level: 65 Points: 9,500, Level: 65
Level Up 50% Completed
FF Reputation: 10 LongDucDong Great Standing Member
Bump
"I will cast you down at the foot of the cross He hung from." -For Today
LongDucDong is offline
Old 08-21-2010, 12:03 PM   #4
iamasped96
iamasped96's Avatar
Fan#: 69623
What I Drive: 2001 black zx3 aka black christmas
FF Reputation: 1 iamasped96 Good Standing Member
Question
yo wen you sell your car how much u want for fuel pump. and will it fit 01 zetec
also rear stress bar and Eibach rear sway bar - 25mm w/poly bushings
iamasped96 is offline
Old 09-13-2010, 07:20 AM   #5
dhardison
Fan#: 50880
Sold!!
