HOW TO: 08+ F2 Header Install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 08-01-2010, 05:41 PM   #1
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,090, Level 55
Points: 7,090, Level: 55 Points: 7,090, Level: 55 Points: 7,090, Level: 55
Level Up 70% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
First, this is a HOW TO. This is for anyone who is interested in installing the F2 DURATEC header in their 08+. So, please, let's not make this thread into a F2 bashing contest.
I bought the header straight from F2 for $230.00 shipped. It is a REALLY nice piece for the price. It came with all of the hardware and gaskets needed for the install.
I also ordered a front pipe with a HFC installed from Trubendz:
http://www.mandrelexhaustsystems.com...W-fdsh-/Detail
I went with the stainless 2.5" dia. and a length of 30". I'm running the FSWerks 2.5" racing exhaust. I measured the front pipe to be about 29" so I figured an extra inch would be good to have and I could cut it down if I needed. However, the header and flex pipe seem to be a little shorter as compared to the stock manifold and flex pipe. So, having this extra inch worked out really well.
First, disconnect the neg. terminal on your battery. Next, If you have an upper strut bar, remove it. You will need the clearance to remove the manifold and install the header.
Next remove the little heat shield that covers the purge valve
[IMG]http://i295.photobucket.com/albums/mm150/PSUrivie
/IMG_3997.jpg[/IMG]
Disconnect all the lines so you can remove the bracket from the firewall
Unplug the o2 sensors from the harness and remove them from the exhaust manifold. In my case I have the 1st o2 for the ECU and then a wideband. Once this is done remove the heat shield from the exhaust manifold.
Now you can access the manifold bolts.
Unbolt the flex pipe from the front pipe and remove bolts from the exhaust manifold studs. Some studs came out with the bolts. So, don't freak out if this happens.
Install o2 sensors into header. I also checked the gasket to make sure the primaries lined up properly.
Install the header and 'snug' bolts. DO NOT torque yet.
HEADER/ALTERNATOR Clearance:
As can be seen in the following pics. The primary is a little close to my alt. for my comfort. For this reason I HIGHLY recommend header wrap. The plastic covering has not melted or anything as of yet. I will keep my eye on it and let you know if it does.
The header comes with directions that tell you the proper torque sequence for each stud. Do this now.
Next, install flex pipe and front pipe with cat. I loosened my whole exhaust to line everything up properly.
Re-install the purge valve and connect all lines. Plug in o2 sensors and reconnect the battery.
Final product minus strut bar:
CONCLUSION:
For the money this isn't a bad header. The primary is still a little close to the alternator. It sounds GREAT.
RECOMMENDATIONS:
Get a tune before adding this header. There are two reasons for this:
1). You're not playing around with the CEL fix, which according to some members doesn't always work.
2). You will use the potential of this mod
Use header wrap!!! I used the titanium wrap (Thanks SCRAMMER). Due to the close proximity of the alternator.
This took me about 2 1/2 hours to do. You may be able to do it faster, but I recommend TAKING YOUR TIME. I took my time and I'm not chasing exhaust leaks.
Is the Cossie and FSwerks header better?....Probably....Does this header suffice for what I use/drive my car for?...yes
Well, there it is. You can make you're own decision on taking this route or not. Hope this helps. --- Tom
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 08-01-2010, 06:26 PM   #2
InfraRedSVTF
InfraRedSVTF's Avatar
Fan#: 17442
What I Drive: 2013 Focus ST3/2015 Fiesta ST
Points 3,498, Level 36
Points: 3,498, Level: 36 Points: 3,498, Level: 36 Points: 3,498, Level: 36
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 2%
FF Reputation: 3 InfraRedSVTF Good Standing Member
Your primary is way further away from the alt than mine, mine sat directly on the plastic when I installed it.
I am sure you could feel a power difference right away, I know I did.
I <3 Bewst!
InfraRedSVTF is offline
Old 08-02-2010, 12:07 AM   #3
cpz1987
cpz1987's Avatar
Fan#: 69577
What I Drive: 2010,silver, SES
FF Reputation: 2 cpz1987 Good Standing Member
vid? sound clip. looks nice.
cpz1987 is offline
Old 08-02-2010, 07:38 AM   #4
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Nice write up dude. One of your pics isn't working though.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 08-02-2010, 10:28 AM   #5
Andrew
Andrew's Avatar
Fan#: 6565
What I Drive: 08 Caliber SRT4, 05 ZX5 SES
FF Reputation: 2 Andrew Good Standing Member
Buy-Sell-Trade Rating: (6)
Sound clip please! nice write up, thanks.
08 Dodge Caliber SRT-4
Andrew is offline
Old 08-02-2010, 12:49 PM   #6
voortrek3
Fan#: 487
What I Drive: 2009 Vista Blue SES Coupe
Points 6,370, Level 52
Points: 6,370, Level: 52 Points: 6,370, Level: 52 Points: 6,370, Level: 52
Level Up 10% Completed
FF Reputation: 3 voortrek3 Good Standing Member
Nice write up and I gave you some rep!
voortrek3 is offline
Old 08-02-2010, 08:07 PM   #7
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
I heard this header and exhaust combo in person today and IT SOUNDS AMAZING! AMAZING!
1988 F150 Custom
D23 Crew: #07
Old 08-02-2010, 09:55 PM   #8
Dung1sm
Atx PZEV FTW!
Dung1sm's Avatar
Fan#: 52323
What I Drive: 2005 Silver ZX4
Points 3,631, Level 37
Points: 3,631, Level: 37 Points: 3,631, Level: 37 Points: 3,631, Level: 37
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 6%
FF Reputation: 4 Dung1sm Good Standing Member
great post... very needed for some of us... thanks....
So Cal Crew#43
Sedan Revolution #130
Moderator for:
South West Fanatics
Ford Focus & General Car Chat
Ford Focus Build Showroom
Dung1sm is offline
Old 08-03-2010, 03:03 AM   #9
K26
K26's Avatar
Fan#: 51125
What I Drive: 2006, Red, turbo'd ST
FF Reputation: 8 K26 Good Standing Member
looks good. also my front sway bar looks good in there btw lol
FOCUS FACTOR
K26 is offline
Old 08-06-2010, 02:00 PM   #10
cpz1987
cpz1987's Avatar
Fan#: 69577
doesn't the HFC take power away?
cpz1987 is offline
