Fan Won't Shut Off? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-01-2010, 03:20 PM   #1
Megotu
Fan#: 77258
What I Drive: 2003 blue focus se
FF Reputation: 1 Megotu Good Standing Member
Fan Won't Shut Off?
Hi, new member long time lurker. Got the 2003 Focus SE. Just survived the bad ignition cylinder episode. Ford dealership near couldn't get the work done for a week and went to a friend recommended local garage. They swapped out the ignition cylinder in 3 hours. Went to work last night, no problems. Drove home this morning and the fan was still going after I stopped. I know some cars, the fans keep going awhile but I hadn't noticed this before on my Focus. Anyway...went out there just now and the 2 month old battery is drained. Is THIS something that could have been related to the ignition cylinder change-out?
Megotu is offline
Old 08-01-2010, 03:27 PM   #2
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
What were they doing for the other two and a half hours?
It is a straightforward task to change the lock cylinder, but- was this all that they changed?
If you think I've been able to help, just say
niggly51 is offline
Old 08-01-2010, 08:29 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
Not if it locks up and won't turn, then you have to drill it out, and that takes time.
Now this might be an evil coincidence. Something goes wrong that is completely unrelated to some work that was done. Check the fan wiring harness, these are well known to melt, but we've never had one melt together and continue running although it is possible.
I'd consider taking it back to see what they say about it, but there shouldn't be any way that the engine cooling fan could continue to run as a result of something in the steering column.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-02-2010, 07:44 AM   #4
niggly51
niggly51's Avatar
Fan#: 74542
Whoops! Should have considered the captive key problem. I wrongly assumed it was a straight cylinder swap. What I was wondering was whether they had to replace any wiring associated with the switch or possibly altered some wiring to give a constant feed on a circuit that should be switched.
Posted via FF Mobile
niggly51 is offline
Old 08-02-2010, 09:23 AM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,809, Level 73
Points: 12,809, Level: 73 Points: 12,809, Level: 73 Points: 12,809, Level: 73
Level Up 90% Completed
Forum Activity 99%
Best guess for now is an unusual failure of a relay. Once in a while power contacts can "weld" themselves together, so it won't shut off.
Pull fan relays (2) 'till you find which one shuts off the fan when pulled, then swap with a good one from another circuit or a new one to check this possibility. (easier/quicker than trying to describe how to test the relay with VOM & test leads) OK with different relay - problem solved...
Luck!
sailor is online now
Old 08-02-2010, 09:45 AM   #6
Megotu
Fan#: 77258
Not a captive key Thank Ogem.But I assume they were also working on other cars as well...Possibly even driving to the store for parts. They might even have had lunch. They got the car at 0930 and called me at 1230 before they losed at 1300. I call that pretty good service.
Well got the car jumped yesterday afternoon, drove to work last night and drove home, no fan issue. Drove the wife to work and got home...The fan won't shut off. For now, I just disconnected the negative on the battery. No battery, no battery drainage. I waited a minute to see if it rebooted, it started back as soon as I reconnected the battery. Pulled the wire again and now I am off to bed. This can wait til my day off, but at least the battery should survive til then.
Megotu is offline
Old 08-02-2010, 10:00 AM   #7
niggly51
niggly51's Avatar
Fan#: 74542
When I queuried the time taken I was thinking chargeable time, not elapsed time. Sailors suggestion of the relay is good, but it does seem odd that it's started after the cylinder work was done.
niggly51 is offline
Old 08-03-2010, 07:28 PM   #8
Monoblanco
Fan#: 59784
What I Drive: 2002 bright yellow ZX5
FF Reputation: 3 Monoblanco Good Standing Member
I just took a look at the schematic - I'll bet on stuck relay contacts, just as sailor said.
Monoblanco is offline
