Clunking noise coming from front end? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-05-2011, 07:51 AM   #31
B3NN3TT
B3NN3TT's Avatar
Fan#: 64245
What I Drive: 2003 CD Silver SVT
Points 1,329, Level 20
Points: 1,329, Level: 20 Points: 1,329, Level: 20 Points: 1,329, Level: 20
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
FF Reputation: 2 B3NN3TT Good Standing Member
TZT Performance has them too.
2003 SVT #2370 Hatch Nation #91 2000 Roush Cougar 2008 Mustang Bullitt #5389 2013 Fiat 500 Abarth
B3NN3TT is offline
Old 09-18-2013, 03:18 PM   #32
GEORGE@GMLLC.COM
Fan#: 119048
What I Drive: 2008, Red Ford Focus SES
FF Reputation: 1 GEORGE@GMLLC.COM Good Standing Member
My 2008 SES was doing same thing - just changed out the sway bar ends - problem resolved. Torqued to 41ft lbs - got them at autozone $19 ea. lifetime warranty.
Thanks to all who posted solutions...
Last edited by GEORGE@GMLLC.COM; 09-18-2013 at 03:19 PM. Reason: incl original msg
GEORGE@GMLLC.COM is offline
Old 09-18-2013, 03:24 PM   #33
GEORGE@GMLLC.COM
Fan#: 119048
Smile 2008 Focus SES - Front end clunking bumps hard turns
Just replaced the sway bar ends on 2008 Focus /SES - 88K miles. Took care of the clunking noise I was hearing - both lower joints on ends were sloppy..
Got new ones at Autozone - $19ea - torqued to 41ft lbs - took me 45min in my garage (included looking for tools).
Thanks to all who posted problem / solutions.
Old 01-26-2014, 11:55 PM   #34
JEDI 2.0
JEDI 2.0's Avatar
Fan#: 127626
What I Drive: 2001 Pitch Black ZX3
Points 687, Level 13
Points: 687, Level: 13 Points: 687, Level: 13 Points: 687, Level: 13
Level Up 74% Completed
FF Reputation: 2 JEDI 2.0 Good Standing Member
I am JUST NOW getting the clunking sound, but I just lowered my car a week ago. ...Eibach Pro-Kit springs, and upon install I noticed my struts were poor. ... will be replacing those and the swaybar end links (initially I thought an end link came loose, but it hasn't). Clunk is intermittent but since my commute is 9 miles mostly one straight road, waiting til payday to fix, will report progress.
JEDI 2.0 is offline
Old 01-27-2014, 09:17 PM   #35
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,387, Level 75
Points: 13,387, Level: 75 Points: 13,387, Level: 75 Points: 13,387, Level: 75
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 99%
Moved to "Brakes Suspension & Chassis", this area split off the wheels & tires section a while ago...
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-18-2014, 11:00 AM   #36
JEDI 2.0
JEDI 2.0's Avatar
Fan#: 127626
So, my terrible front end clanking is GONE!! One of 2 things may have caused it, IMO: my struts were dead, and I noticed fresh scratches on the first and last coils of my lowering springs (Eibach pro-kits). ...so, the noise was either the spring coils slapping against each other, or the dead struts were allowing freedom-of-movemenet of the springs, and may have been slapping the top and bottom strut plates that hold the spring. .... what I did was, bought clear tubing at Home Depot, and sheathed the first and last coil only, and switched to new struts. :) Problem solved.
JEDI 2.0 is offline
Old 02-18-2014, 08:00 PM   #37
photn02
Fan#: 116617
What I Drive: Silver
Points 549, Level 10
Points: 549, Level: 10 Points: 549, Level: 10 Points: 549, Level: 10
Level Up 98% Completed
FF Reputation: 1 photn02 Good Standing Member
Hi All,
I hope you dont mind me posting in this thread rather than starting my own thread.
I have a 2003 Zetec focus, its lowered on Eibach Springs and Eibach Shocks with Eibach Sway bars.
These where done about 2 years ago now, about 40,000 km ago. I am getting what feels like a bouncing/rubbing sound from the front. It happens when im cruising on the highway, but the moment i accelerate it does away. Its getting worse and im not sure what the problem is. I fitted Moog sway bar end links as Ford said they where shot.That didnt fix the problem though.
Short of replacing the Strut Top mounts, tie rods and other parts im not sure what to do.
Should the front sway bar slide from side to side after it has been installed? when i changed the Sway bar links i noticed that the sway bar will slide within its mounts. it doesnt vibrate from what i can tell, but it does slide a bit.
Any help is appreciated.
photn02 is offline
Old 02-18-2014, 08:17 PM   #38
seraniko
seraniko's Avatar
Fan#: 121529
What I Drive: svtf svtf civic tacoma valkyrie
Points 261, Level 5
Points: 261, Level: 5 Points: 261, Level: 5 Points: 261, Level: 5
Level Up 22% Completed
Forum Activity 2%
FF Reputation: 1 seraniko Good Standing Member
Check your fender liners
seraniko is offline
Old 02-28-2014, 08:54 PM   #39
photn02
Fan#: 116617
Thanks, i checked them. but the car is no where near low enough and i see no rubbing.
I went over the car again yesterday and ive done some tests whilst driving.
Seems the sound is more evident when the car is under load. if im traveling and i clutch in and the revs drop, the sound disapears.
Could this mean its the engine mounts that needs replacing?
photn02 is offline
Old 02-28-2014, 10:17 PM   #40
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
^that's a good call. Most of us with Focii as old as yours have had to replace the engine mounts due to various noise/vibration symptoms. We generally recommend buying the Ford mounts - more expensive but most folks have found aftermarket mounts to fail within months. Use the forum search box above for more comments on the matter than you have time to read.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
