Clunking noise coming from front end? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-28-2010, 09:20 PM   #1
Lowtek
Lowtek's Avatar
Fan#: 44111
What I Drive: 2002 ZX3, 2012 Nissan Sentra SR
Points 4,277, Level 41
Points: 4,277, Level: 41 Points: 4,277, Level: 41 Points: 4,277, Level: 41
Level Up 64% Completed
FF Reputation: 12 Lowtek Great Standing Member
Buy-Sell-Trade Rating: (13)
Hello,
I recently started hearing a clunking noise coming from both sides (driver and passenger) of the front end when I drive. This mainly happens when I hit little bumps in the road and the noise gets louder when I hit slightly bigger bumps. Does anyone know what could be causing this? I replaced the sway bar endlinks about a month ago because the old ones were shot. I did some looking around in the front end and I found that this bushing or whatever (not sure what its called) looks worn out and flat. Can anyone help me out?
Here is a pic:
Lowtek is offline
Old 07-28-2010, 09:44 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
That's not a bushing in this case, its a dust boot that protects the tie rod end from getting contaminated with dirt, etc. How old are your shocks (mileage etc.)?
Geezer is offline
Old 07-28-2010, 09:54 PM   #3
Lowtek
Lowtek's Avatar
Fan#: 44111
The car itself has 107k on it but the shocks/springs (KW struts and Eibach Sportlines) have about 30k max on them.
Lowtek is offline
Old 07-28-2010, 10:08 PM   #4
GodLovesUgly
.Flat Out.
GodLovesUgly's Avatar
Fan#: 56705
What I Drive: ^^^ That!
Points 28,575, Level 99
Points: 28,575, Level: 99 Points: 28,575, Level: 99 Points: 28,575, Level: 99
Level Up 14% Completed
FF Reputation: 10 GodLovesUgly Great Standing Member
Buy-Sell-Trade Rating: (7)
could be the ball joint, do the ball joing test.
maybe strut bearing?
i hate front end clunks.. i had it once, turned out to be a loose lower ball joint pinch bolt..
The Rich Get Richer Until The Poor Get Educated.
Do Vegetarians eat Animal Crackers?
Moderator of Ford Focus Racing Discussions & Rocky Mountain Fanatics
GodLovesUgly is online now
Old 07-28-2010, 10:17 PM   #5
Geezer
Fan#: 1427
There are numerous things can cause front end clunks and you fixed one of the more common ones, the endlinks. Another possibility could be the springs binding (coils touching on compression) due to the shocks loosing some damping ability. This can happen with shorter springs with relatively soft rates like the Sportlines. The coils end up being closer together initially. Look at the tops and bottoms of the coils to any tell tale signs of rubbed of paint (eg bare metal).
Geezer is offline
Old 07-29-2010, 01:34 AM   #6
aTm Beaner
aTm Beaner's Avatar
Fan#: 21542
What I Drive: 2005 Ford Focus ST
FF Reputation: 5 aTm Beaner Good Standing Member
Buy-Sell-Trade Rating: (6)
I'm getting a clink but only when turning right over bumps. I'll occasionally hear it when backing up from my driveway as my car touches the street. I took it to a mechanic thinking it was the CV axle, but he said they were fine. I then took it to Sears who then told me it could be a strut. Any help would be great.
Posted via FF Mobile
aTm Beaner is offline
Old 07-29-2010, 02:28 AM   #7
Spinal
Spinal's Avatar
Fan#: 45687
What I Drive: 2007, Vermillion Red, ZX3 SE
FF Reputation: 29 Spinal Great Standing Member
well if it is the strut, easy test would be to push down on one side of your car and see if it does a bobble head type motion. my friend had the same issue with his car, FRPP suspension crapped out after a year (driver side front strut) and good god it was almost like the spring had no dampening what so ever, was funny when he came to a stoplight though, car kept bouncing back/fourth lol.
Go: Steeda SRI, MBRP 2.5'', CFM 67mm TB, F2 header, Toms Tune 91oct, FRPP drop, all stress/sway bars, CFM dogbone mount, 133whp, 134wtq
Last Of The Hatches #44
Spinal is offline
Old 07-29-2010, 08:34 AM   #8
jasonbi
jasonbi's Avatar
Fan#: 13305
What I Drive: 2002 SVT
Points 4,592, Level 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Level Up 21% Completed
FF Reputation: 3 jasonbi Good Standing Member
so how would someone perform such a test?
#3286 OF 4788
jasonbi is offline
Old 07-29-2010, 12:09 PM   #9
Lowtek
Lowtek's Avatar
Fan#: 44111
If this happens to be the problem, is there anyway to fix that?
I "tested" the struts by pushing on the fender/hood on each side of the car and it was stiff and not bouncy like you you described so I dont think my struts are bad but thanks for the suggestion
I am wondering the same thing lol. Maybe if someone could explain this, I will test the ball joints today.
Lowtek is offline
Old 07-29-2010, 01:06 PM   #10
B3NN3TT
B3NN3TT's Avatar
Fan#: 64245
What I Drive: 2003 CD Silver SVT
Points 1,329, Level 20
Points: 1,329, Level: 20 Points: 1,329, Level: 20 Points: 1,329, Level: 20
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
FF Reputation: 2 B3NN3TT Good Standing Member
What kind of end links did you use?
If you didn't get OEM Ford end links, go back in and make sure the nuts are all torqued correctly on them; the aftermarket links are known to work their way loose.
2003 SVT #2370 Hatch Nation #91 2000 Roush Cougar 2008 Mustang Bullitt #5389 2013 Fiat 500 Abarth
B3NN3TT is offline
