#1 | ||||
Aftermarket HU: Resistor for sub "pop"
Just installed a new Pioneer HU in my 05 /w Audiophile. I did my research and got all the right harnesses so everything works great, I love it. But im getting the popping sound from the sub whenever I turn on the stereo. I read on here that a 1k ohm resistor in the amp turn on lead will fix this, but my question is, is it a 1/8 watt, 1/4 watt, or 1/2 watt resistor? Or does it matter?
Thanks! |
Remove Advertisements |
Fan#: 1
#2 | ||||
Is Audiophile a factory amp/sub system? In any case I have used the PAC TR-4 turn on delay module with great results. It will delay the amp turn on 2 seconds and should get rid of that pop, ebay and sonicelectronix has them less than $20. Could you post up where you read about the resistor? I have only heard of diode isolating head units.
#3 | ||||
Post #5 http://www.focusfanatics.com/forum/s...light=resistor Post #4 http://www.focusfanatics.com/forum/s...light=resistor I work at Radioshack and can grab a 1k resistor real easy, would much prefer that to ordering a $20 part of ebay if I could. |
#4 | ||||
I see, I knew it was something about the factory stereo. Those things always need something wierd. Didn't know you needed to step down the voltage to the amp.
I am not an electrical engineer so you may want to wait for someone else to chime in. The way I understand it, the watt rating is the amout of heat the resistor can dissipate. The higher watt rating won't effect the resistance and just adds safety. http://www.bcae1.com/resistrs.htm Their calculator says 1000ohm @ 12v = .144 watts, so as long as you don't use the 1/8th it should be good. |
#5 | ||||
Love CA / Hate CARB
Yes, get a 1k ohm resistor that can handle a whole .144 watts of power without failing, and you'll be fine.
"My yellow, in this case, is not so mellow" -Jimi Hendrix Focus Fanatics Extremely helpful people I made a haiku |
#6 | ||||
Thanks again! |
#7 | ||||
You might want to read some more (on other forums, Mustang, etc.). I used the same harness with my 08 Sport Trac audiophile. I still had turn-on/off thump even with a 1K resistor. It wasn't horrible, and I could regulate it by turning the volume way down prior to stopping vehicle. Others recommended a different size resistor (I can't remember exactly). A voltage regulator would work better. This is just an FYI, that a 1K will help, but probably not eliminate the problem.
I quickly went all aftermarket, and sold the audiophile, so I didn't look into the problem any further, when I had my ST. |
#8 | ||||
Love CA / Hate CARB
Which is what I would recommend. I understand it's expensive, but you'll be much happier in the long run if you just replace the Audiophile setup.
#9 | ||||
I have always used a 1.5K resistor. You could also use a radio shack part # 276-1770. It is a 5 volt regulator that works perfectly, just a little tougher to install.
#10 | ||||
quinnjdogg: Could you give a quick description on how you wired your 5v reg up? Would help people finding this through google as well as me ;) Edit: Just got to work and checked out the 5v reg, it really doesnt look any harder to hook up, just in, out, and tap into the ground wire. I think ill just go that route so I can get it right the first time. Thanks! Last edited by FinalJenemba; 07-30-2010 at 02:35 PM. |
| Thread Tools | |
| Display Modes | |
