General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
#1 | ||||
Focusless
Dyno'd with the nitrous, I've got questions! [DYNO CHART]
Here is the dyno chart:
![]() The first run is without nitrous. My mods are: SVT Header SVT Catalytic converter SVT Flex Pipe 2.5" OBX Exhaust SVT Intake with snorkel and K&N filter 9mm Ford Racing spark plug wires The second run is with an NX 50 shot (at ~1,000 psi) I'm happy with both runs and the numbers both ways. Although there are two things that I would like to fix. The first one is I am leaner than I would like to be with on the bottle. (The dyno guy said the ratio would read about 1 point higher than it actually is because I have a catalytic converter and a decent exhaust leak between the flex and exhaust) There are two things right away that I know I can change to help the problem. First, I can up the fuel jet and second, I can close the gap on the plugs. My question is, which jet should I use for fuel? Right now I'm using 35N/20F, so should I go up to a 22 fuel jet? I ask because I have a spare 22. Then for the plug gap, what should I be gaping these to with nitrous? Right now I have the colder Motorcraft coppers gaped at ~0.65. The dyno guy said I should gap them down to ~0.35-0.40, what do you guys think? And the second issue, as you can see if you look at the graph, the line with the nitrous on is bouncy. When it hits 3,000 RPM the nitrous kicks in and goes up but then drops back down a bit and continues to flow like that. The guy at the dyno said normally when cars are on nitrous it peaks up like that and stays that way as it caries over. Any idea why it is waving like this? The line was purged, so we're thinking the solenoids might be kicking in and out. Could the fuel pressure safety switch be causing this? Scott and I will be checking out the timing and knock with his scanner sometime within the next week just to make sure everything is alright. After I work things out, I'd like to get a tune, but that isn't in the price range right now. In the end, my questions are: What fuel jet should I go up to? What should I gap my plugs to? Any idea why the chart is wavy? Thanks for reading, constructive criticism is welcome
2002 Twilight Blue ZX3 - Sold 9/1/10 Now driving a Montego Blue Turbo 1996 Mazda Miata |
Remove Advertisements |
Fan#: 1
#3 | ||||
FF Affiliate
Your stock is rich , your nitrous is lean , and you better get a tune on that thing before many bottles
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#4 | ||||
Focusless
Should I put in the 0.022 fuel jet? And would it be good to gap the plugs at 0.40? If these sound good, I'm planning on doing this either tonight or tomorrow. I'm going to be very conservative on the bottle so it isn't too hard on the motor.
Also, any idea why the dyno chart is wavy?
#5 | ||||
March 2013 ROTM
Well the 50 shot is pretty accurate.
FocusXtreme - Hatch Nation #96 04 ZX3 5.0, T5, 4 lug 7.5 w/ 3.73s 12 SE Hatch Sport & Winter Package, ST Front End 91 Ranger XLT 3/4 drop 89 Bronco II XLT Well the body is still stock, what's left of it Last edited by disciplerocks; 07-16-2010 at 05:42 PM. |
#6 | ||||
FF Affiliate
Yes I would go up one fuel jet size that will add more fuel , you need to do a datalog to see what everything else is doing so you know if your safe , the AF is only a part of what info you need
#7 | ||||
Focusless
Right now I have a 0.020 in there. Should I go up to a 0.022?
I already have a 0.022, but I could buy a 0.021, it would just save me $10 if I could use the one I already have. I have no tuning stuff, I'd like to get it but it's like $650.
#9 | ||||
FF Affiliate
You dont have the cash to get your engine safe ? Do you have the 1000.00 for a new engine and install ?
I love building and selling engines to guys that dont want to spend on tuning , sold a $13,500 632 Inch to a guy that didnt want to use the dyno before going to the track , lost his Dart block , Crower rods , Dart big cheif heads , roller cam all from lean and spk knock Speed cost , Stupid cost even more Tom
#10 | ||||
Fully Built, Topspeed manifold, CompTurbo: 364hp, 317tq... ^old and Busted^ 2011 Mustang GT 5.0 Kona Blue: Bolt On's 440hp, 385tq ^SOLD^ '96 F-250 SCEB PowerStroke |
| Thread Tools | |
| Display Modes | |
