blower motor not working. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-28-2010, 06:30 PM   #1
ssvhto72
Fan#: 65145
What I Drive: 03, CD silver SVTFocus
FF Reputation: 1 ssvhto72 Good Standing Member
hi i have a 03 ford focus ZX3 its actually my mothers. the blower motor isnt working. now i checked all fuses checked out fine.
i didnt see a relay anywhere i looked in the owners manual didnt see anything about a relay for blower motor either. maybe im missing it?
anyways i have no power what so ever at the switch, or is there supposed to be power at the switch? i tested the switch that checked out fine.
anyone know if there is a relay another fuse hidden somewhere?
or even a wiring diagram would be good. im actually a truck mechanic so i could figure it out eventually just dont have the time to mess around, wondering if anyone had any ideas.
thanks
ssvhto72 is offline
Old 06-28-2010, 06:37 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Not to be an , but it should be in the owner's manual- use the index to find the fuses. IIRC it's in the fuse box under the hood, but you should check to be sure. I guess Ford decided to stop putting fuse labels on the box itself at some point, and now just puts descriptions in the owner's manual instead. When I read mine, it listed every device that was on a circuit.
There is an AC relay, but that's not for the van. AFAIK there is no relay for the cabin air fan, only the engine cooling fans.
You know that no power at the switch is a certain sign of a bad fuse unless someone has been in there trying to hook up a stereo recently.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 06-28-2010, 09:14 PM   #3
ctlynch
Fan#: 76319
What I Drive: 2005 Dark Shadow Gray ZX4
FF Reputation: 1 ctlynch Good Standing Member
well, pick a relay at this point. it'll be a lot of jumping terminals to find the bad one.
and it is the 2.0 non svt, correct? if so, the relays should be in the junction box in the left rear corner of the engine compartment, and all 5 pertain to the cooling fans. the svt and the 2.3 both have less relays, so it depends what you have. i wish i could load the diagram but i couldn't. so best bet would be to get hold of a diagram and go to town. and yes, fuses are a very good starting point!
ctlynch is offline
Old 06-28-2010, 10:08 PM   #4
ssvhto72
Fan#: 65145
i found one fuse its in the junction box. 40 amp fuse for the blower motor thats fine. i even went behind the junction under the fuse checked those terminals both have power one wire goes to a relay, so i checked the relay checked out fine even swapped relays around still nothing... i power probed the blower motor switch/plug... nothing, kept popping my breaker. i need a diagram is right so i can chase some wires se if something is chaffed or corroded.
its just a regular ZX3 model 03 2.0L 5 spd with out A/C.
there is relays in both the junction box in the engine compartment and under the dash.
im tempted to take apart my svt and see which wires at the plug do what. but i have A/C
oh ya and class 8 trucks are a hell of alot easier finding electrical problems then cars...
ssvhto72 is offline
Old 06-28-2010, 10:31 PM   #5
ctlynch
Fan#: 76319
Lol definitely. I can see if I can send it to you some other way tomorrow when I get back on that computer. Used Mitchell to pull it up. There are a bunch of relays in there somewhere for all of it. The junction box it was talking about had the five relays and a diode for I can't remember what. But most of those are running in series so disconnecting one and putting it in the other slot may not do anything since it's open from where you took it. But yeah, i'll see if I can do that somehow, if all else fails I can send it through email.
ctlynch is offline
Old 06-28-2010, 11:00 PM   #6
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Simple question for the OP: Does the blower work on position 4 (full blast)?
If the answer is yes, then your fan resistor pack needs replacing. It's located behind the passenger side glove compartment. Blower positions 1-3 slow fan speed by introducing a resistance into the circuit.
http://www.focusfanatics.com/forum/showthread.php?t=219723
BC_ZX3 is offline
Old 06-28-2010, 11:00 PM   #7
ssvhto72
Fan#: 65145
Oh that'd be great thanks.
Here's my e-mail if you can't send it any other way.
Mbergeron72@live.com
ssvhto72 is offline
Old 06-28-2010, 11:01 PM   #8
ssvhto72
Fan#: 65145
Ya your right about the relays.I wasn't thinking like that I'll try again after work.
ssvhto72 is offline
Old 06-28-2010, 11:27 PM   #9
ctlynch
Fan#: 76319
Yeah Bc zx3 is right, I'm thinking cooling fan motor instead of blower motor for some reason, but it still should be easy to narrow down. Very few things it should be, and none of them are too difficult, and there should be a blower relay. More than likely in a grouping somewhere. So it should only be limited to fuse (which is good), relay, resistor block, or the motor itself.
ctlynch is offline
Old 06-29-2010, 05:05 AM   #10
ssvhto72
Fan#: 65145
no blower motor does not work on either position. there isnt any power getting to the switch its self
ssvhto72 is offline
