remote central locking not working. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-10-2010, 04:41 PM   #1
paulc33
Fan#: 75805
What I Drive: 2002 silver edition
FF Reputation: 1 paulc33 Good Standing Member
i have a 2002 3dr focus and have an issue with my remote central locking, the drivers door doesnt unlock....the passenger door intermitantly does though.
i have replaced the battery in the key fob but still no joy.
the central locking does work though with the key in the door.
does anyone have any ideas what might be the issue here??
paulc33 is offline
Old 06-10-2010, 04:57 PM   #2
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
More electrical gremlins eh?
You say the central locking works with the key. Is that locking ALL doors with the key? You only mentioned 'unlocking', can we assume you can lock the car OK with the keyfob?
niggly51 is offline
Old 06-10-2010, 05:13 PM   #3
paulc33
Fan#: 75805
Sorry the remote central locking doesn't lock or unlock, the remote will only pop open the boot using the boot pop button.
paulc33 is offline
Old 06-10-2010, 05:24 PM   #4
niggly51
niggly51's Avatar
Fan#: 74542
Could be a faulty fob. If you can obtain a new or good secondhand unit, they can be programmed to work with the car. It is unlikely you have faults with both the door motors, but stranger things have happened. Have you also checked the fuse? Sounds like the previous owner left a legacy of electrical problems for you!
niggly51 is offline
Old 06-10-2010, 05:46 PM   #5
paulc33
Fan#: 75805
It did work first time I test drove the car, I got it cheap through my work as a part x so don't mind doing a few bits to sort it out! How easy are the fobs to get coded to the car? And do the key fobs from eBay work??
paulc33 is offline
Old 06-10-2010, 05:51 PM   #6
niggly51
niggly51's Avatar
Fan#: 74542
They are very easy to code. A quick search on the Forum should get you a procedure- or try Google. Ebay- you can be lucky with what you buy, or not.
niggly51 is offline
Old 06-10-2010, 05:58 PM   #7
paulc33
Fan#: 75805
So they don't need to be taken to ford to be coded then?? That's good..
Maybe il look into getting a new fob then, and try that first !
By fob I take it you mean just the buttons part of the key?
paulc33 is offline
Old 06-10-2010, 06:07 PM   #8
niggly51
niggly51's Avatar
Fan#: 74542
Yes, as you know from changing the battery, the key part comes away from the electronics. You need not buy new ,if you can locate a good secondhand one to try. It may not be your problem- just one thing to eliminate. Good luck.
niggly51 is offline
Old 06-10-2010, 11:10 PM   #9
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,713, Level 73
Points: 12,713, Level: 73 Points: 12,713, Level: 73 Points: 12,713, Level: 73
Level Up 66% Completed
Forum Activity 99%
Posted via FF Mobile Fob prob mentioned because here in the states we DO have a separate "fob" for the remote 4 button box to hang on ring with key....
sailor is online now
Old 06-11-2010, 02:20 AM   #10
paulc33
Fan#: 75805
Ok thanks for that, in the uk the fob is part of the key, we hve 3 buttons on it too. The key blade it's self though is removeable
paulc33 is offline
