2008, 2009, 2010 A/C Recharge Specs? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-08-2010, 06:14 PM   #1
FocusRebuilder
Fan#: 62313
What I Drive: 2006 ZX5 SES, Silver
FF Reputation: 5 FocusRebuilder Good Standing Member
Hi Y'all, does anyone have the oil and R134a specs for the 2008-2010 Focus? I need to know how many ounces of oil and how many of R134a to charge an empty system in the new cars. And is the oil the same as in the older cars, or different? I looked through the A/C thread started by Whynot but didn't see this info. Thanks in advance.
FocusRebuilder is offline
Old 06-08-2010, 10:33 PM   #2
FocusRebuilder
Fan#: 62313
Found it. Advance said it's 18 oz. R134a and 4.5 oz of PAG 46.
Old 06-09-2010, 09:31 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
If you're tinkering, or fixing wrecks- have you considered trying hydrocarbon refrigerants? That's what Europe is using now to replace 134, and it's legal for use in the US in cars. I was just curious to see if anyone has tried to to find out how well it works. Supposedly it gets as cool as 12 did.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 06-09-2010, 11:00 AM   #4
FocusRebuilder
Fan#: 62313
I hadn't even thought about it, Whynot. I generally just put 'em back to stock. I had heard that the new refrigerant standard 5-6 years from now will be hydrocarbon, but didn't realize it's already available. Can it be used without any mods to the system?
Old 06-10-2010, 10:16 AM   #5
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
yes no mods, hang on, the link is at the end of the General AC thread. I'll go fetch it.
EPA page on it, and it gives the manufacturer's registered name "Duracool" for a search.
http://www.epa.gov/Ozone/snap/refrigerants/hc-12a.html
The only thing that is different is how much you'd use in a vehicle that was designed for use with 12. In other words if you had a 92 Aerostar converted to 134, you'd want to use the 12 chart for Duracool because your system is really a 12 system. I don't remember reading how the pressures correspond to ambient temps, but I'd guess that it's really similar. It might be that the old rule (psi, AC off= ambient temp in F) will still be true.
Be eclectic.
Old 03-14-2012, 10:37 AM   #6
ugabuga
Fan#: 96365
What I Drive: 2005 Ford Focus ZX4 ST
FF Reputation: 1 ugabuga Good Standing Member
hey guys. I am new on here and found this thread. I have a 2005 ZX4 ST, 2.3L and was wondering what the pressure should be on low/high when properly filled.
I don't have a vacuum pump but oh well.
Here's what I found online for someone whose A/C was working decent:
2007 Ford Focus SES - R134a
Outside temp was 100 degrees in the shade.
Idle RPM Reading - Idle was between 750 to 900 RPM's (hard to tell)
Low Side -54 PSI
High Side - 270 PSI
Idle RPM Reading - Raised Idle to 1500 RPM's
Low Side -50 PSI
High Side - 345 PSI
How do those numbers look to you?
ugabuga is offline
Old 03-14-2012, 06:22 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
If you don't have a vacuum pump, don't use a vacuum pump, and the system was drained- you're screwing up. Moisture will be in the system, and moisture + refrigerant= acid. Now I don't know how strong the effect will be- it will depend on how much moisture is in there, how long it sat, or what not. Vacuum pumps can be rented from parts stores.
As far as the oil needed, it's probably the same as previous years of Foci. Close enough anyway, then go by the pressure. If you're having problems lowering your pressure, then see if cleaning the condenser will help. You'll have to remove the radiator, but if cold air is what you want- nothing is too difficult.
Be eclectic.
Old 03-14-2012, 06:25 PM   #8
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
To add to what I wrote above DO NOT USE HYDROCARBON REFRIGERANTS! Yes it is what Europe uses, and it is more ozone friendly. It is not people friendly though. Although the flash point is lower- it's still combustible. A spark is all you need to start a fire if the concentration is high enough.
Sorry, I hadn't done enough research.
Be eclectic.
Old 03-15-2012, 09:10 AM   #9
ugabuga
Fan#: 96365
Yes, I know not using a vacuum pump is not by the book but I've been running my mother's camry like that for ... 10 years with no particularly ill effects.
I will ask around though to see if I can indeed rent a pump. I looked recently and couldnt find one.
by local parts stores, do you mean autozone, advance, etc? or some local brand stores?
ugabuga is offline
Old 03-15-2012, 06:29 PM   #10
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
Maybe the humidity is not that high there, or the system wasn't exposed for a long time. It's your car, go for it if you want.
Pressure = temp, the suction side= evaporator temp. 54 is ok for 100 in the shade, but I typically shoot for lower suction pressures. If you've got too little, it's easier to add than to subtract. There are charts available online for pressures relative to temperature for a properly charged system. Oil is just as important, and if the system is completely drained you should always replace the orifice tube before charging as well as find whatever your leak is. Usually it's an O-ring, and those are easy to replace.
Be eclectic.
