Rear Camber Adjustments??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-26-2004, 08:08 PM   #1
Ford Freak 9603
Fan#: 8593
What I Drive: 2003 Focus ZTS
FF Reputation: 1 Ford Freak 9603 Good Standing Member
I did some searching and it seems that everyone is saying that with the Eibach Pro system, you would not need a rear camber kit. And, I also read that there is no rear camber adjustments on a Focus.
So then explain this. I have the Eibach Pro system (1.5" drop). And look at my camber on the rear tires... (Car has not been aligned yet) (Picture Below)
I do have the rear Camber kit, but does anyone have directions from them? All I have is the 2 bolts.
-J
Ford Freak 9603 is offline
Old 08-29-2004, 08:40 PM   #2
[ZX3]Brucity
[ZX3]Brucity's Avatar
Fan#: 4204
What I Drive: Silver 2000 ZX3
FF Reputation: 1 [ZX3]Brucity Good Standing Member
Have the car aligned first. They will adjust the camber accordingly as much as they can with the stock bolts. If there is still too much camber after the alignment then get a camber kit.
[ZX3]Brucity is offline
Old 08-30-2004, 01:09 PM   #3
scironzts
scironzts's Avatar
Fan#: 893
What I Drive: '04 ZTW
FF Reputation: 1 scironzts Good Standing Member
That's nothing compared to my camber issues I have on my sedan. LOL. But man, yeah, the camber bolts will help. Not sure exactly how to go about installing/adjusting them, but I will be putting them on real soon (as soon as I get my Steeda Toe adjusting arms).
04 ZTW | Wagons will rise again.
scironzts is offline
Old 08-30-2004, 06:20 PM   #4
Ford Freak 9603
Fan#: 8593
Well, I got it aligned and the specs should be between -2.3 +0.3 And right now I'm at -2.0
So its still within the specs, but I think I'm going to install the bolts and get it more towards the middle.
-J
Old 08-31-2004, 12:43 AM   #5
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,714, Level 78
Points: 14,714, Level: 78 Points: 14,714, Level: 78 Points: 14,714, Level: 78
Level Up 66% Completed
Forum Activity 14%
FF Reputation: 90 goinloco1 Excellent Standing Member
definitly camber bolts and fc adjustable toe links on the rear. after mine was lowered it ate the inside edges of new tire in about 2k. right now i'm running about 1 deg. of camber (bolts are maxed) and slight toe on each tire. can tell you it handles awsome and no tire wear so far (except what i ate off at the rushmore g2g ).
a side effect of the toe links is that they use heim jounts and no bushings. effectivly making the front lower control arm a solid piece with no flex side to side. does you're dog wag its tail in the wind or behind trucks? since i added these two, mine no longer does.
goinloco1 is offline
Similar Threads
rear camber ? blkZX32005 Brakes, Suspension & Body Chassis 11 07-04-2008 10:03 PM
Camber plates, and rear bar toeycrack Brakes, Suspension & Body Chassis 6 05-05-2008 03:48 PM
Rear Camber Bolt Install eurotrashvrt Brakes, Suspension & Body Chassis 5 06-11-2007 04:00 PM
Rear Camber input for Sedans BoneStockZTS Brakes, Suspension & Body Chassis 6 02-17-2005 08:44 AM
00' Wagon rear camber Dave U General Technical Chat 3 07-15-2004 09:39 AM
