Seat belt/AirBag warning light - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-07-2010, 01:13 PM   #1
royo58
Fan#: 75659
What I Drive: 2004 focus estate
FF Reputation: 1 royo58 Good Standing Member
Hello
I've just replaced the existing passenger seat with a disabled persons rotating seat.
The orange connector has been re-connected and the warning light on the dash stays is on.
How can this be remidied?
By the way the yellow connector is completely removed as it is with the original seat.
Thanks for your help
Roy
royo58 is offline
Old 06-07-2010, 01:21 PM   #2
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
I suspect the ECU has detected the absence of the sensor attached to the seat and connected to the yellow connector. You should contact the people that supplied the seat conversion and ask their advice.
niggly51 is offline
Old 06-07-2010, 11:02 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,312, Level 75
Points: 13,312, Level: 75 Points: 13,312, Level: 75 Points: 13,312, Level: 75
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 99%
Posted via FF MobileAfter thinking on how this switch may work, decided to one-up Niggly (pardon me, grin) and suggest that provision for an appropriate switch SHOULD be included with such a conversion, as the person transported deserves the std. safety equipment to be functional, barring any specific reason why it should not be...
sailor is offline
Old 06-08-2010, 06:35 AM   #4
royo58
Fan#: 75659
Seat belt warning light
Thanks niggly & sailor
I've contacted the seat makers and apparently there should be some sort of resistor but in the yellow socket. I'm trying to find out the value of the resistor or if they will supply one.
royo58 is offline
Old 06-08-2010, 06:52 AM   #5
niggly51
niggly51's Avatar
Fan#: 74542
Posted via FF MobileI agree with sailor-they should keep the supplied safety feature not simulate it with a dummy load resistor. Apparently the connector goes to the seatbelt pretensioner- an important part of the cars safety system, that presumably did not get transferred to the special seat. Not ideal but I can see it may have been an engineering problem on a rotating seat.
One to you sailor old chap!
niggly51 is offline
Old 06-09-2010, 06:35 AM   #6
royo58
Fan#: 75659
Thanks again chaps. The pre-tensioner was re-attached to the rotating seat and the 'orange' plug re-inserted. However the 'yellow' plug which I think served the seat heater was left empty. It seems that this socket therefore has to have a 'load' in order to complete the circuit to the air bag & the pre-tensioner. In other words it was to 'dummy' the seat heater not the safety feature!
This is my best guess of the situation.
Regards for your attention
Roy
royo58 is offline
Old 06-09-2010, 07:34 AM   #7
niggly51
niggly51's Avatar
Fan#: 74542
I think you may be wrong here. I see no reason that Ford would include the seatheater as part of the safety equipment warning circuits. I'm sure the yellow connector is seatbelt pretensioner.
niggly51 is offline
Old 06-09-2010, 10:05 AM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Posted via FF Mobile My bet is on sensor for passenger in the seat, used for belt unused warning & arming pass. air bag when seat occupied. With most these days, putting a load on the seat will cause the car to demand a belt be used, and arm all safety systems for that side... Some even have a weight cutoff for 2 stage airbag, this may be disappearing as kids in the back has become the std. recommendation...
sailor is offline
Old 06-09-2010, 10:12 AM   #9
niggly51
niggly51's Avatar
Fan#: 74542
Unlikely to be that sailor, as a simple switch would not trigger an error by its absence. Do a quick Google and you will find the yellow connector is seatbelt pretensioner.
niggly51 is offline
Old 06-09-2010, 12:27 PM   #10
royo58
Fan#: 75659
No Niggly/Sailor, the pre-tens. connects to the orange plug. The yellow plug cable runs underneath and then into the inside back of the original seat (although my car didn't have a heated seat, I wonder if the heating element was fitted, hence the need for a resistor when the seat is removed? )
I agree though, I can't see how this should affect the airbag/seat belt warning light.
Could it be that although the warning light is showing, the airbag & pretens will still function. I think the removal of the seat and non-connection of the yellow con. must have caused the light to come on. Do either of you know how to stop this without recourse to the Dealer?
royo58 is offline
