Go Back   Focus Fanatics > Exclusive Vendor Discussions > Focus-Power Tuning
Focus-Power Tuning Discuss about force induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Focus-Power
Old 06-06-2010, 05:34 PM   #11
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Originally Posted by MajicBlurpleSVT View Post
tom i understand what your saying and i know i need a wide band dont have the cash for it right now and no i wasnt running the retatarded timeing and uping the fuel at that time now i am the plug was an denso iridium itv22 that shatered and melted the ground strap and pieces of it were melted into the piston creating a few hot spots that melted through the piston withe constant use with the bad plug and hot spot and i have since got a new motor that i have bin useing the nos for 5k in with the right plugs uped fuel and retarded timeing when i do use the nos and bin checking reguarly with a borescope and checking the plugs after every run to make sure i dont make the same mistake again. and the op all ready has a wide band so hes way better off than i am i was just saying he could run the nos without it if he did the right things with the fuel timeing and plugs for now untill he gets a proper tune and everything.
NO ! The plugs didnt cause you issue , the parts of the plugs that burned of because excessice high CYL temp didnt create hot spots and burn the piston , bad, poor or lack f tuning did
You can install 2 steps hotter plugs and it wouldnt cause you to burn a piston
You will NEVER find an iridium plug that is colder then the sp463 and why would you be using that crap with nitrous anyway
Plugs that are Irid or Plat and a few others in most cases are as hot or HOTTER then stock because they need the hotter temps to keep the trash burned off to run 100,000 miles
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-06-2010, 06:20 PM   #12
KRYPTO
KRYPTO's Avatar
Fan#: 45267
What I Drive: 02 race car red SVT
FF Reputation: 1 KRYPTO Good Standing Member
This is a little off topic, but what plugs do you recommend to run in the SVT with your tune?
FF welder
Barely Rolling Racing
KRYPTO is offline
Old 06-06-2010, 06:32 PM   #13
MajicBlurpleSVT
MajicBlurpleSVT's Avatar
Fan#: 34980
What I Drive: 2002 Pitch Black SVT
FF Reputation: 1 MajicBlurpleSVT Good Standing Member
Buy-Sell-Trade Rating: (4)
most likely i was leaning out yes and thats what caused it but i know what i saw when i had the motor replaced and that was pieces of the plug melted into the piston and more holes forming from thoes pieces and that was B4 i started uping the fuel and retarding the timeing with the diff plugs and every thing has bin good for 5k doing it with the fuel+ and timeing -- with the itv27 denzo irid plugs and to get to the setup i run when useing the nos now i did use a friends wide band to set it up so i know im not running lean in all actuality im running way rich just dont have the money for my own wideband and he needed it for his car.
tom i know you know wayyyyy more than i do when it comes to things like this i was just letting him know he can do it for now untill he can get everything he needs
returning her back to stock body kit except for the skirts dam rocks in the middle of the highway going around a corner.
02-08 front conversion - sourcing parts as we speak
MajicBlurpleSVT is offline
Old 06-06-2010, 07:34 PM   #14
1turbofocus
FF Affiliate
Fan#: 1123
How do you know your timing is right ? How do you know your not bordering dangerous on your load , and many many other things . To say he can do it the way your getting by for now is just bad info and you shouldnt be telling people that it can be done that way
There is no doubt in my mind the parts from you plugs were stuck in your pistons for that to even happen your pistons had to be at the melting point for them to stick in the pistons
You need to loose those hotter plugs , get a wide band air fuel and some one to tune your car or you will be replacing another engine in time
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 06-06-2010, 10:16 PM   #15
KRYPTO
KRYPTO's Avatar
Fan#: 45267
So when I do the Nitrous I'll start with a 50 shot and work up to a 100 shot. I should be safe up to a 100 shot with a tune but dont recommend going higher with a stock motor?
I already have a wideband. I will be running a WET system with purge, bottle warmer, window switch, WOT switch, Fuel cut off switch, and a progressive controller. Also colder plugs?
What other type of components or gauges would you recommend.
Should I have a tune for each shot tell I get to 100?
FF welder
KRYPTO is offline
Old 06-06-2010, 11:52 PM   #16
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: modded 2000 zx3, stock 2002 SVTF
FF Reputation: 34 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (13)
you are also going to want to go one size larger on the fuel jet for the wet system. if it calls for a size 50 pill for fuel you use a size 51 pill. if it calls for a size 50 pill for nitrous you use a size 50 pill lol.
thats just a little extra something to help make sure you arent running lean during the tuning process
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 06-08-2010, 12:03 AM   #17
KRYPTO
KRYPTO's Avatar
Fan#: 45267
Thanks, picking up kit tomorrow
FF welder
KRYPTO is offline
Old 06-08-2010, 12:04 AM   #18
KRYPTO
KRYPTO's Avatar
Fan#: 45267
But it has a Throttle body plate?
FF welder
KRYPTO is offline
Old 06-08-2010, 07:38 AM   #19
focusmaniaczx3
Fan#: 55157
huh? you mean a TB spacer that fits between the throttle body and the intake manifold? that is most likely so you can sticker her in there without having to drill a hole into your intake. ive been tinkering with the idea of making my own TB spacer for this purpose.
Old 06-08-2010, 12:11 PM   #20
KRYPTO
KRYPTO's Avatar
Fan#: 45267
yeah for the nitrous
FF welder
KRYPTO is offline
