P0344 Camshaft Position Sensor - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2010, 01:09 PM   #1
cwhummel
Fan#: 75628
What I Drive: 2001 Silver Focus SE
FF Reputation: 1 cwhummel Good Standing Member
Hey guys, new to the forum.
My wife's car, a 2001 Focus SE, recently had the check engine light come on. I took it to autozone and had the code read, which came up with the P0344 Cam Position Sensor. I'd like to try and replace it before I take it somewhere, but have no clue where to find it or how to get to it. Can anyone help me out? Is there anything else involved in replacing this part (positioning, code resets....)?
thanks
cwhummel is offline
Old 06-05-2010, 01:21 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
It's a simple bolt on/off part. The only thing you'd need to do is find out where it is. Have you gone through our Complete How-To Archive linked in my signature? You might find something in there that shows a pic of where it is. Usually these are located at the rear of the engine (driver's side).
Which engine do you have- SPI or Zetec?
Also, before you go purchasing a new one, try finding the old one, removing it, cleaning the crud off of it, and re-installing it. Sometimes that helps. Usually cars don't run at all if the sensor goes completely out. Your code might simply be that it has a low signal reference- meaning that the connector is corroded or dirtied somehow and needs cleaning. I use windex and an old toothbrush to clean corrosion. The end of the CPS should be cleaned as well- it's a magnet, so it picks up stray metal.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 06-05-2010, 01:27 PM   #3
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
Take a look at the front of your motor, by either of the camshafts and where they exit the head(s). The sensor is either a optical or hall effect sensor, so try and find a housing that is near or around your intake or exhaust camshaft ( or just single camshaft). This is the camshaft position sensor.
Whoops- whynotthinkwhynot beat me to it!
niggly51 is offline
Old 06-07-2010, 09:48 PM   #4
cwhummel
Fan#: 75628
hey guys, sorry i didnt get back for awhile, I have had zero time since I first posted. Anyway, i have the zetec motor. A friend yesterday recommended changing the the spark plugs (whatever that has to do with it....) and they were pretty bad. Unfortunately, changing them did not help. Still have no clue where to find this sensor.
cwhummel is offline
Old 06-07-2010, 10:01 PM   #5
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
You may have to remove your air intake tube for proper access. From the front of the car, it's on the upper right hand side of the cylinder head. The arrow points to the electrical connector going to it held in place by the metal spring clip. A single bolt holds it in place.
BC_ZX3 is offline
Old 06-09-2010, 03:13 PM   #6
cwhummel
Fan#: 75628
thanks for the pic, but we gave in and took it in for service. turns out there's quite a bit more wrong with it than just the sensor.
cwhummel is offline
Old 06-09-2010, 04:02 PM   #7
niggly51
niggly51's Avatar
Fan#: 74542
Any ideas what else was wrong, it's always good to find out what's behind some of the issues folks are having.
niggly51 is offline
Old 01-22-2015, 02:21 PM   #8
hunnypot
Fan#: 216153
Points 1, Level 1
Points: 1, Level: 1 Points: 1, Level: 1 Points: 1, Level: 1
Level Up 0% Completed
FF Reputation: 1 hunnypot Good Standing Member
Hi we have a ford focus tdci 2 ltr that wont turn over. Been plugged to computer and showing no faults. Engine has good compression and tried with easystart but no go. Be grateful for any suggestion. Got camshaft sensor out of car and magnet seems weak but still works, could that be cause poss ? Thanks Helen
hunnypot is offline
