bleeding the clutch - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-30-2010, 03:33 PM   #1
stevus prime
stevus prime's Avatar
Fan#: 66654
What I Drive: 2003 red svt
Points 2,075, Level 27
Points: 2,075, Level: 27 Points: 2,075, Level: 27 Points: 2,075, Level: 27
Level Up 50% Completed
Forum Activity 2%
FF Reputation: 1 stevus prime Good Standing Member
bleeding the clutch
anyone know how to do this??
stevus prime is offline
Old 05-30-2010, 03:45 PM   #2
Kal-EL428
Kal-EL428's Avatar
Fan#: 47337
What I Drive: 2002 SVT Sonic Blue
FF Reputation: 33 Kal-EL428 Great Standing Member
Its easy. To make it more easily accessible, I think you need to remove the battery and airbox (I could be wrong, I had them out when I changed my clutch master cylinder)
On top of the trans you will see a bleeder valve at the top of the slave cylinder. Remove the rubber cap and open that valve, attach a clear tube (so you can see the air in the fluid) and run it in to a catch can of some sort. Have a buddy push the clutch pedal as you maintain the fluid level in the brake fluid reservoir. (Make sure that you keep filling the reservoir with new fluid so that it does not become low and pull more air into the system) When you no longer see air in the fluid, close the bleeder valve and that its.
Have plenty of fluid on hand, it took a lot more than I thought it would.
02 Sonic Blue SVT
#2064 of 4788
Born on: 5-14-02
Kal-EL428 is offline
Old 05-30-2010, 04:19 PM   #3
Zab
Zab's Avatar
Fan#: 57586
What I Drive: Izzy's '03 Eclipse and my '03 SVT
FF Reputation: 2 Zab Good Standing Member
I was thinking about this also, we did it on my brothers eclipse, and my friends elantra, but both of those cars have their own reservoir tanks for the clutch as different from us we use the brake reservoir tank which I didn't know.
thanks Kal-EL428
'03 Silver SVT #1623 R.M.D.S.
Zab is offline
Old 05-31-2010, 12:00 AM   #4
stevus prime
Fan#: 66654
Forum Activity 2%
alrighty
thanks so much
Old 05-31-2010, 04:25 AM   #5
samus
Fan#: 53177
What I Drive: 2002 Pitch Black SVT
Points 126, Level 2
Points: 126, Level: 2 Points: 126, Level: 2 Points: 126, Level: 2
Level Up 52% Completed
FF Reputation: 2 samus Good Standing Member
also a tip if you get fluid in the trans housing (if it drips down the slave cylinder when you remove the tube) spray around in that area with some brake cleaner. the fluid is bad for the clutch.
samus is offline
Old 05-31-2010, 03:19 PM   #6
sully35rq
Fan#: 25198
What I Drive: 2001 zx3
FF Reputation: 1 sully35rq Good Standing Member
Bleed your clutch as if you were bleeding your brakes...work off the same system!!
matthew sullivan
sully35rq is offline
Old 05-31-2010, 03:51 PM   #7
stevus prime
Fan#: 66654
Forum Activity 2%
that sounds easy enough
Old 05-31-2010, 03:57 PM   #8
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Get yourself a Mity Vac, and pump away.
It didn't even take me 10 minutes to flush the entire reservoir with fresh fluid.
WD40 is offline
Old 05-31-2010, 04:13 PM   #9
mrford60
Fan#: 74987
What I Drive: 2011 blue SE & 2007 Expedition
Points 494, Level 9
Points: 494, Level: 9 Points: 494, Level: 9 Points: 494, Level: 9
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 2 mrford60 Good Standing Member
another way to bleed the clutch system is to take a gear oil bottle and clean it out real good then take a small rubber line from the bleeder screw to the nipple on the gear oil bottle put some brake fluid in the bottle and open the bleeder screw and slowly squeese the bottle and force the air out through the reservoir (take the lid off) it works for me every time.
mrford60 is offline
Old 05-31-2010, 10:47 PM   #10
nacnudv8
nacnudv8's Avatar
Fan#: 52725
What I Drive: former owner:Pitch Black '03 SVT 3D
FF Reputation: 7 nacnudv8 Good Standing Member
^^^ def agree with WD40 - a hand held vacuum pump is the way to go - so fast!
An eye for an eye makes the whole world blind.
Mahatma Gandhi
nacnudv8 is offline
