cooling fans not working... already replaced resistor - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-09-2011, 08:26 AM   #31
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 1,010, Level 17
Points: 1,010, Level: 17 Points: 1,010, Level: 17 Points: 1,010, Level: 17
Level Up 10% Completed
Forum Activity 8%
FF Reputation: 4 Tiger-Heli Good Standing Member
Originally Posted by whynotthinkwhynot View Post
My point being- no matter what you do, it is a temporary fix. The longer you leave it like that, the more likely you are to have to spend several hundred dollars for new fans.
Agreed - Also, when the resistor fails, it almost always takes out the wiring plug with it b/c the fans come on so seldom that you typically don't notice the low speed fans failed until several months later.
I wonder if mounting the resistor in the fan shroud (High heat) contributes to the problem or not.
Tiger-Heli is online now
Old 03-09-2011, 05:40 PM   #32
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Insufficient feed wiring IMO, and yes, there is an ambient temp factor that affects conductor size. There just aren't enough engineers that realize this.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-17-2013, 09:08 PM   #33
cylenotkyle
Fan#: 107493
What I Drive: 2000 Red ZTS
FF Reputation: 1 cylenotkyle Good Standing Member
So if the port where the fuse goes isnt getting power chances are I have a bad port?
cylenotkyle is offline
Old 09-18-2013, 10:32 AM   #34
focus1980
Fan#: 119015
What I Drive: 2002 Grey zxs
FF Reputation: 1 focus1980 Good Standing Member
my2002 ford focus cooling fans are not working both of them, the fans don`t come on with A/C on,the A/C compressor start for 3 second and stop,when unplug the head sensor both fans start. Can somebody tell me what to do please!
focus1980 is offline
Old 09-18-2013, 12:04 PM   #35
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
This one is for the OP, are you interested in parting ways with that resistor you ended up not needing? I need one, and I'd rather help someone on the forum than go searching for a buy it now listing.
FoMoCus is offline
Old 09-19-2013, 02:59 PM   #36
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
hi and welcome to the forum. In the future, better to start a new thread than to glom on to an old one.
Before drawing any more conclusions about the temperature sensor, it might be worth your time & $ to reinstall the sensor and then start the engine with the odometer in test mode. To learn about that, click the "Stickied Threads" link at the top of this forum, and then click the "Complete HOW TO" link. Then, scroll down and click "Focus Test Mode". That will cause your odometer to read in degrees Celsius.
With the A/C off, the two fans should being operating in their low-speed mode around 110C and in their high-speed mode around 116C (although if your engine is just idling and the cooling system is working properly, then it should never reach 116C).
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 09-19-2013, 06:22 PM   #37
focus1980
Fan#: 119015
Tanks for help,the resistor was burn,now the car run good!
