cooling fans not working... already replaced resistor - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-25-2010, 04:37 PM   #21
4ST AIR
Fan#: 64583
What I Drive: 2004 Ford Focus ZTS
FF Reputation: 3 4ST AIR Good Standing Member
Glad I could help. I'm not much of a poster on here, more of a lurker looking for answers / ideas for the problems I come across from time to time...and I love a good build thread! I hope the other poster got some help too...
4ST AIR is offline
Old 05-25-2010, 04:40 PM   #22
4ST AIR
Fan#: 64583
Originally Posted by TheKid View Post
which are the fuses and resistors for the fans so i can check too?
Sorry I don't have the book with me, or i'd let you know. Your owner's manual has all that listed, I think like page 127 or something....If I get a chance tonight I'll look at mine.
4ST AIR is offline
Old 05-25-2010, 04:43 PM   #23
TheKid
Fan#: 65764
What I Drive: 2002 Infra Red Focus SVT
FF Reputation: 1 TheKid Good Standing Member
I got my car used, and i don't have a manual....
TheKid is offline
Old 05-25-2010, 09:42 PM   #24
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Owner's manuals:
http://www.focusfanatics.com/forum/s...ead.php?t=2280
BC_ZX3 is offline
Old 06-05-2010, 12:08 AM   #25
239rsw
239rsw's Avatar
Fan#: 15133
What I Drive: 2002 Yellow ZX3
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 3 239rsw Good Standing Member
Glad you fixed it. Mine was just the harness to the fan was not pushed all the way.
2002 ZX3 @ 333K
Last Update : 10/05/2014
239rsw is offline
Old 03-05-2011, 07:34 AM   #26
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 913, Level 16
Points: 913, Level: 16 Points: 913, Level: 16 Points: 913, Level: 16
Level Up 13% Completed
Forum Activity 8%
FF Reputation: 4 Tiger-Heli Good Standing Member
There you go. You should have power to that fuse, even cold.Pull the 30A fuse (also called the 2nd Fan Fuse).
This is also assuming you do this in conjunction with the resistor and plug, meaning you've taken them apart and confirmed they are not burnt!
4ST AIR helped me out a lot with various threads on here (My resistor was burned, and I wouldn't have known there was a resistor in the circuit, much less that it was a bad one), but the info above is incorrect.
I didn't have power on the second fan fuse, but the fuse and wiring looked fine. From the schematic in the Chilton's manual, the second fuse is only powered when the low-speed fan relay is active - so you would not see power at that fuse unless that relay was bypassed (jumpered across), or the engine was hot enough that the PCM was trying to turn on the fan.
Just to clarify for anyone else trying to troubleshoot the fans not coming on.
(Info is for a 2002 Focus SE, but I think should be good for most 2000-2004 Foci, not sure about an SVT).
Tiger-Heli is online now
Old 03-08-2011, 10:39 PM   #27
J-Town_2006ZX3
J-Town_2006ZX3's Avatar
Fan#: 77950
What I Drive: 2006 ZX3 R.I.P.-Currently 02'zx3
Points 1,230, Level 19
Points: 1,230, Level: 19 Points: 1,230, Level: 19 Points: 1,230, Level: 19
Level Up 30% Completed
FF Reputation: 3 J-Town_2006ZX3 Good Standing Member
This is going to sound weird but try turning on the AC( click the button on). My father in-law had an issue with his zetec anf a resistor and his fan will only come on when the AC is activated. Quick fix for him, but he'll have to eventually get it fixed.
"But if you do, one day you will look behind you and you will see we three. And on that day you will reap it. And we will send you to whatever god you wish."
Hatch Nation #26
J-Town_2006ZX3 is offline
Old 03-08-2011, 11:33 PM   #28
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
Yeah, I told a guy how to unplug his AC clutch and bypass the LP switch so he could get his fan running with no charge and a bad resistor.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-09-2011, 07:12 AM   #29
Tiger-Heli
Fan#: 12379
Forum Activity 8%
Okay - first off, the OP fixed his problem - I was just commenting for others trying to run through the same issue.
Second - the low speed fans (both fans) operate through the resistor - but the OP already replaced that.
The high speed fans operate when the A/C is on (and also based on the WOT setting according to the Haynes manual).
Rather than disconnecting the AC clutch, it is probably better and easier to bypass the relay (I think it's the high-speed one - not sure) like this. The fans run (high speed?) all the time when you do this, so you probably don't reach peak operating temperature, but the advantage is that you can still use your A/C.
Hope This Helps!!!
Old 03-09-2011, 08:21 AM   #30
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Either method has one major drawback: you fry your fan motors. Those fans don't generally run at all unless the vehicle is sitting still because you don't need fans when you're moving. When you continuously run the fans, then you wear out the fan motors sooner.
My point being- no matter what you do, it is a temporary fix. The longer you leave it like that, the more likely you are to have to spend several hundred dollars for new fans.
Be eclectic.
